Designing the exposed set
The assistant writes the annotations and works out which identifiers they belong on. You decide what belongs in the exposed set and whether what it wrote is correct. Annotating your model lists what it cannot work out from the model and has to be told.
Start from the questions users ask
Do not ask the assistant to go through the model and expose what looks important. That produces a large exposed set and worse answers.
Write down five questions planners ask about the application. Give it those, one at a time, and let it work out what each one needs. Some will need a procedure that does not exist; ask for it and review what the assistant writes. Others can be answered from data the model already holds.
Expose fewer identifiers
Expose fewer identifiers and make sure each description is right.
The assistant carries every exposed description into every conversation, so forty procedures leave less room for the ones that matter and make its choice harder. Three procedures with clear descriptions answer better than forty with weak ones.
When it proposes exposing something, ask which question that identifier answers. If there is no clear answer, leave it out of the exposed set.
Reviewing descriptions
Descriptions account for most of the quality difference between two applications. Review them closely.
Exposing procedures and data sets out what a good description contains. Two of those things are ones the assistant cannot get right on its own, and they are what to look for when you read its drafts:
The words your users use. If the business says “hold volume”, the description should say hold volume, whatever the identifier is called.
Which of two similar procedures planners mean. The assistant knows what each one does. It does not know which one the question is about.
Correct those, and leave the mechanics alone.
Ask it to review its own descriptions as well:
Read the descriptions on everything you exposed and tell me which ones would be hard to choose between.
Start read-only, then allow writes narrowly
Reading is low risk and answers most questions. Start there, and add writes once the questions work.
When you do allow writes, allow them narrowly. Ask for a procedure that applies one specific, checkable change and expose that, instead of exposing the identifier for writing. The procedure can validate the input, keep related identifiers consistent, and refuse a change that makes no sense. It also gives better results, because the assistant calls one thing rather than assembling a change itself.
Check every safety marking the assistant sets. It infers them from the code, and Exposing procedures and data explains where that inference is least reliable.
One assistant or several
Do not start with agents. A single well-described set of tools is sufficient for most applications.
Add an agent when the instructions pull in two directions — reporting work calling for terse answers, data-entry work calling for the assistant to guide the user through a form. Two agents with overlapping descriptions are worse than one agent, because questions then land unpredictably.
Procedure, skill, or flow
Prefer a procedure, then a skill, then a flow. Skills has the full comparison.
A procedure is checkable, fast, and behaves the same every time; the assistant writes it and you review it. Use a skill when the work recurs and needs judgment, and say in the skill where the judgment is. Use a flow when the order must not vary. A flow takes more effort to write and maintain, so use one only where the fixed order is required.
Build it with your users
Ship a small exposed set early. The questions users ask determine what to expose next.
Let the assistant test itself between rounds. See Testing and troubleshooting.
Write skills from real sessions. Do the task once through the assistant, ask it to write down what it did, then correct that. See Skills.
Plan for a second round. The first version shows what users ask. Use that to build the second.
Keep the model compiling
The assistant cannot help with a model that crashes or fails to compile. Model stability is a prerequisite, independent of the annotations.
Before you expose more, check that the procedures already exposed behave correctly when run repeatedly and in any order.
See also
Annotating your model — what you have to tell the assistant.
Exposing procedures and data — what each annotation means.
Testing and troubleshooting — checking the result.
