AIMMS PRO REST API Updates
The AIMMS PRO REST API is available only on the AIMMS Cloud Platform; it is not supported on on-premise PRO installations.
Task Scheduler (Version 26.2.1.0 - September 1, 2026)
  • Resolved Issue
    • Task sessions now use the correct account-specific pro-aimms-session bootstrap artifact, matching the one used by the Session Manager for interactive sessions, instead of a single static default. This ensures accounts pinned to a specific session artifact (e.g. one with a custom injected DLL) get consistent behavior across task and interactive sessions.
Task Scheduler (Version 26.1.3.0 - June 29, 2026)
  • Resolved Issue
    • Task Scheduler now downloads the bootstrapper from the correct regional CDN.
Task Scheduler (Version 26.1.2.0 - March 24, 2026)
  • Resolved Issue
    • Fixed an issue where recurring tasks could fail with error - Downloading request blob failed with a 403 status and 0 error code due to an expired request SAS URI. The Task Scheduler now automatically renews the SAS URI on each scheduled run, which resolves the issue.
Task Scheduler (Version 26.1.1.0 - February 3, 2026)
  • Improvements
    • Added support for binary input in task requests.
    • Increased the bearer token time-to-live (TTL) to 3 minutes to improve request reliability.
Secret Manager (Version 26.2.1.0 - January 29, 2026)
Improvements
  • Added support for sorting items and introduced additional item metadata.
Secret Manager (Version 26.1.1.1 - January 9, 2026)
The AIMMS PRO REST API is extended with the secret-manager service, enabling secure management of customer and user secrets within the PRO environment.
Please see the documentation and API Specs for more details.
Session Manager (Version 25.6.1.0 - December 12, 2025)
New
  • Session ID retrieval: New procedure pro::sessionmanager::GetSessionId allows programmatic access to the active AIMMS session ID.
  • Unified service access: pro::sessionmanager::GetServiceAccess now provides both the service URI and bearer token in a single call.
  • Service URI API: New endpoint GET /pro/session-manager/v1/sessions/{session_id}/{service}/uri to retrieve service endpoints via REST.
  • Token exchange API: New endpoint POST /pro/auth/v1/token/exchange for obtaining scoped bearer tokens with configurable path and access level.
Improvements
  • Streamlined, consistent workflow for accessing cloud-hosted services (session → URI → token → access).
  • Support for predefined services such as WebUI and Dex.
Please refer to the detailed documentation for usage instructions.
Use Case
  • These enhancements directly support MCP, which relies on the new session-based access flow to securely obtain service URIs and bearer tokens. MCP can now interact with AIMMS cloud services using the standardized and fully supported API workflow. A key example of this is the upcoming release of SENSAI Pro in AIMMS SCNavigator, where these improvements enable seamless and secure integration.
Session Manager (Version 25.2.1.0 - April 15, 2025)
  • Solve Sessions Support
    • The Session Manager REST API now supports Solve sessions, extending its capabilities beyond WebUI and Task sessions.
  • Endpoint Enhancements
    • The DELETE endpoint is now split into two distinct actions: terminate and delete, allowing for more granular session control.
    • Endpoints for retrieving session logs have been updated for improved clarity and consistency.
Task Scheduler (Version 25.1.1.0 - April 15, 2025)
  • Endpoint Update
    • The appName and appVersion parameters in the GET /tasks endpoint are now optional. This allows more flexible queries when retrieving tasks owned by the user.
    • GET and POST endpoints now include two new response fields: userName, userEnvironment
Task Scheduler (Version 25.2.1.0 - May 15, 2025)
  • New Endpoint
    • GET /tasks/{id}/logs: Introduced a new endpoint to retrieve task logs.
