DOCUMENTATION
  • AIMMS optimization tooling introduction
    • AIMMS Developer & Deployment Platform
    • Comparison with other tools
    • Technical Specifications
    • Solvers
      • Solvers availability
      • Advanced Algorithms for Mathematical Programs
      • AIMMS Outer Approximation (AOA)
      • BARON
      • CBC
      • CONOPT
      • COPT
      • CP Optimizer
      • CPLEX
      • Gurobi
      • IPOPT
      • Knitro
      • MINOS
      • ODH-CPLEX
      • PATH
      • SNOPT
    • Mathematical Programming
      • Linear Programming
      • Mixed Integer Programming
      • Nonlinear Programming
      • Mixed Integer Nonlinear Programming
      • Constraint Programming
      • Other Mathematical Programming Types
  • Function Reference
  • User's Guide
  • Language Reference
  • Modeling Guide
  • webui
  • SENSAI
    • How SENSAI Apps works
    • Getting started
    • Designing the exposed set
    • Annotating your model
      • Exposing procedures and data
      • Agents
      • Skills
      • Flows
      • Annotation reference
    • Testing and troubleshooting
    • Using the assistant
  • python-bridge
  • PRO Platform
    • Introduction to the AIMMS PRO Platform
    • Installation
      • System Requirements
      • Installation and Configuration of the License Server
      • General Architecture
      • Installation of AIMMS PRO on Windows
    • The AIMMS PRO Configurator
      • Configuring the configurator
      • Various sections of the configurator
      • Setting up an AIMMS PRO Cluster
      • Server-side Logging
    • Server Administration
      • AIMMS Application Management
      • AIMMS Version Management
      • User Management
      • Monitoring
      • Configuration
        • AD Settings
        • Retention Settings
        • Portal Customization
        • Tunnels
        • Queue Priorities
        • Log Management
        • Active Data Sessions
        • Seats Management
      • Linking Environments to Active Directory Domains
        • Link to Active Directory for AD Member Servers
        • Link to Active Directory for Non-AD Member Servers
      • SAML Support
      • Tunneling support
      • Commonly Encountered Errors
      • Miscellaneous
    • AIMMS PRO End-User Portal
    • MFA for AIMMS PRO Portal
    • Project Setup
      • Adding PRO Libraries to your Project
      • Basic AIMMS PRO Workflow
      • Conversion Guidelines
      • AIMMS PRO and Data Management
      • Advanced AIMMS PRO Workflows
        • Determining the Application State to Transfer
        • Advanced Usage of pro::DelegateToServer
        • Communication Between client-side and Server-side Sessions
        • Using Messages in Your PRO Applications
        • The PRO Progress Window
        • Using Solver leases instead of DelegateToServer
      • Debugging PRO-enabled Projects
    • AIMMS PRO Java/C# API
    • Release Notes
  • Cloud Platform
    • Introduction to AIMMS Cloud Platform
    • AIMMS Cloud Portal
      • Apps (AIMMS Application Management)
      • Sessions
      • Usage
      • Tasks
      • Legacy Sessions
      • Secrets
      • SENSAI in the Portal
      • AI Skills
      • AI Memories
      • User Settings
      • User API Keys
      • Users (User Management)
      • Configuration
      • Security Events
      • Sign-ins
    • SENSAI on AIMMS Cloud
    • App Development & Publishing
      • Getting the latest AIMMS Releases on AIMMS Cloud Platform
      • Basic AIMMS Cloud Workflow
      • AIMMS Cloud and Data Management
      • Advanced AIMMS Cloud Workflows
      • Debugging Cloud-enabled Projects
    • AIMMS PRO REST API
      • Managing Environments, Groups and Users
      • Managing Apps
      • Managing Sessions
      • Managing Tasks
      • Managing Secrets
      • Managing API Keys
    • Integrations & Configuration
      • SAML Support
      • Tunneling Support
      • Login Protection for AIMMS PRO Portal
      • Gurobi Support on AIMMS Cloud Platform
      • Workflow for accessing cloud-hosted services
    • Privacy Statement
    • Release Notes
      • AIMMS Cloud Portal Updates
      • AIMMS PRO REST API Updates
      • AIMMS PRO Cloud Updates
  • Data Integration with AIMMS
  • Library Repository
    • Getting Started with AIMMS Library Repositories
    • AIMMSXL Library
      • Using the AIMMSXL Library
      • Example
      • AIMMSXL Documentation
      • AIMMSXL Library Release Notes
    • CDM Library
      • Introduction
      • Installing AIMMS CDM
      • Configuring your model for CDM
      • Dealing with external and derived data
      • Day-to-day CDM operations
      • Callbacks and hooks provided by CDM
      • CDM Authentication and Authorization
      • CDM implementation details
      • Low-level CDM API
      • CDM Library Release Notes
    • Data Exchange Library
      • Using the Data Exchange library for communicating data
      • Data Exchange Mappings
      • Standard Data Exchange formats
      • Application Database
      • Consuming REST APIs
      • Generating API client code from an OpenAPI specification
      • Providing REST APIs
      • Azure Data Lake Storage
      • Data warehouses
      • Methods provided by the Data Exchange library
      • DEX Troubleshooting
      • DataExchange Library Release Notes
    • DataLink Library
      • What is DataLink?
      • The Data Map
      • Read and Write
      • Source Information
      • Data Map Automation
      • Tips and Tricks
      • Providers
      • Examples
      • DataLink Library Release Notes
    • Email Client Library
      • Introduction
      • Email Client API
      • EmailClient Library Release Notes
    • Forecasting Library
      • Introduction
      • Notational Conventions
        • Simple Linear Regression
        • Time Series Forecasting
      • Functions
        • forecasting::ExponentialSmoothing
        • forecasting::ExponentialSmoothingTune
        • forecasting::ExponentialSmoothingTrend
        • forecasting::ExponentialSmoothingTrendTune
        • forecasting::ExponentialSmoothingTrendSeasonality
        • forecasting::ExponentialSmoothingTrendSeasonalityTune
        • forecasting::MovingAverage
        • forecasting::WeightedMovingAverage
        • forecasting::SimpleLinearRegression
      • Forecasting Library Release Notes
    • GuardServerSession Library
      • Introduction
      • Error and Profiling Results as Data
      • The GSS End User interface for end-users
      • The GSS User Interface for specialists
      • The action log
      • Investigate state solver session
      • Integrate GuardServerSession library with your AIMMS Application
      • Install GSS interface for end-users
      • Install UI of GuardServerSession Library
      • Install UI Request manager
      • Install UI Inspect Running Solver Sessions
      • GuardServerSession Library Release Notes
    • HTTP Client Library
      • Introduction
      • What is HTTP?
      • Using the HTTP Client
      • HTTP Client API
      • HTTPClient Library Release Notes
    • RLink Library
      • Setting up RLink
      • Using RLink
      • Iris Example
      • RLink Library Release Notes
    • Snowflake Library
      • Introduction
      • Snowflake API
      • Snowflake Library Release Notes
    • Unit Test Library
      • Creating unit test suites
      • Running test suites
      • Automated testing
      • AIMMSUnitTest Library Release Notes
      • New Features and Bug Fixes
  • AIMMS Network License Server
    • Introduction
    • Linux Setup
    • AIMMS Network License Server Release Notes
  • AIMMS Information Security
    • Information security for the AIMMS Cloud Platform (on Azure)
    • Information security for AIMMS Developer (the software)
    • Information security for the AIMMS AI-powered features
    • AIMMS Responsible Disclosure Policy
  • AIMMS Release Notes
  • AIMMS Cloud Platform Release Notes
  • AIMMS PRO On-premise Release Notes
  • AIMMS PRO Release Notes Archive
  • AIMMS Product Lifecycle
AIMMS Documentation
AIMMS Logo
  • Documentation »
  • Cloud Platform »
  • App Development & Publishing »
  • Edit on Github
Advanced AIMMS Cloud Workflows
The basic Cloud workflow described in Basic AIMMS Cloud Workflow can be extended to suit the particular requirements of your application. This section describes the capabilities offered by the AIMMS PRO framework for setting up customized workflows. The underlying code and API are the same as for AIMMS PRO on-premises; the difference is that all portal UI interactions reference the Portal.
    • Specifying Case Content
    • Optional action to be taken after case load
    • Saving Log Files
    • pro::DelegateToServer arguments
    • Timing out Requests
    • Timed-out Sessions
    • Asynchronous…
    • …Versus Blocking
    • Using a Shared Input Case
    • Distributing Work
    • Overriding the License Profile
    • Adjusting the Job Priority
    • Scheduling a Session in the Future
    • Bidirectional Communication Between Sessions
    • Current Session Info
    • Message Flags
    • Waiting for Messages
    • Implementing a Message Bus
    • Creating a Queue
    • Connecting to a Queue
    • Communicating the Queue to Other Users
    • Sending Messages
    • Preparing the Use of the PRO Progress Window
    • Opening the PRO Progress Window
    • Implemented Using Messages
    • Solver lease concepts
    • Limits and best practice
    • Specifying the solve using solver leases
Last updated: Oct 12, 2026
Help & Feedback
Docs
Edit this page to fix an error or add an improvement in a pull request
Create an issue to suggest an improvement to this page
Product
Create a topic if there's something you don't like about this feature
Propose functionality by submitting a feature request
Support
Not what you where looking for? Search the docs
Remember we also have Community support
Still having trouble? Reach out to us
Next Previous
AIMMS Logo
Disclaimer Privacy Policy © 1989 - 2026 AIMMS B.V.
