Gantt Chart V2 Widget
This Gantt Chart V2 widget type is the redesigned and enhanced version of the Gantt chart widget type available in the AIMMS WebUI.
Introduced in the WebUI 25.8 release, this version is released as an Experimental Feature. To enable it, open the Experimental Features menu and activate “GanttChart V2”.
This widget type is supported only on pages with a grid layout and is not compatible with Classic pages.
If a Gantt Chart V2 widget is placed on a Classic layout page (for example, through copy and paste), it becomes inactive and displays an incompatibility message.
Overview
The Gantt Chart V2 widget provides an interactive, timeline-based view of tasks and resources, enabling users to plan, schedule, and monitor activities effectively. Tasks (jobs) appear as horizontal bars along a time axis and are organized vertically by resource (such as machines, operators, or vehicles). Each bar reflects a task’s start time and duration, making it easy to review, compare, and adjust schedules directly from within the AIMMS WebUI. This widget is particularly well suited for project management, production planning, workforce scheduling, and other resource allocation scenarios.
In the example Gantt Chart shown above, several key features of the widget are illustrated:
  • Pivoting of indices
    Based on the configured pivot, the indices in the resources pivot order appear as rows. The corresponding tasks (jobs) are rendered as bars with their associated start and duration values.
  • Clear representation of overlapping tasks
    When tasks overlap, partially or fully, the chart renders them in a way that makes the overlap unambiguous and easy to see.
  • Default or custom tooltips
    Hovering over a task displays a tooltip (either default or customized) containing detailed task information.
  • Text displayed inside task bars
    Additional inline text can be shown inside bars to clarify task information. Long text will be clipped if it does not fit within the task’s width.
  • Adaptive top X-axis
    The top time axis automatically selects appropriate time units based on the visible time range. For shorter durations, it may show hours; for longer horizons, it will switch to days, weeks, or months.
  • Contextual bottom X-axis
    The bottom axis always shows the overall start and end dates of the chart. This helps users interpret the hours or more granular units shown on the top axis.
This widget is optimized to handle large datasets efficiently by loading only sparse, and non-zero data. In practice, this means that only tasks with a positive (non-zero, non-negative) duration are rendered in the chart. This approach significantly improves performance and responsiveness when working with large or complex Gantt chart data.
Gantt chart Settings
Contents
The Gantt chart requires Start and Duration values for each task. In the Contents tab of the widget options editor, you can specify the identifiers that provide this Start and Duration data. Within the same tab, you can also configure the Display Domains for both, which determines which tasks or data points are included in the chart, similar to other widget types.
_images/gantt-chart-v2-contents-optioneditor.png
The following requirements apply:
  • The Start and Duration identifiers in your model must share the same index domain, which should include at least one task index.
  • The Start identifier must represent the number of hours relative to the Gantt Chart Reference Time.
  • The Duration identifier must represent the duration in hours of each corresponding task.
  • To support vertical dragging (moving tasks between resources), the Duration identifier in the AIMMS model must be updatable.
  • To support both vertical dragging and task modification (resizing), the Start and Duration identifiers must be updatable.
When using the display-domain option, please ensure it is configured thoughtfully. If no domain conditions are applied, the underlying identifiers may still process very large datasets, which can negatively affect the performance and responsiveness of the Gantt chart.
Even when the visual output appears unchanged, unnecessary data processing in the background can still slow down and impact the performance. To ensure optimal performance, always apply domain conditions that restrict the data to only what is relevant.
For example, use domain conditions like: MyDisplayDomainIdentifier(index1, index2) | JobDuration(index1, index2)
Gantt Chart Settings
Along with specifying each task’s Start and Duration values, the Gantt Chart includes several additional configuration options available in the Gantt Chart Settings tab of the widget options editor.
_images/gantt-chart-v2-gcsettings-optioneditor.png
The available Gantt Chart settings are described below:
  • Reference time (required)
    Sets the reference point from which each task’s Start time is calculated.
    This can be specified using either a literal date/time value or a scalar string parameter.
    Accepted formats are %c%y-%m-%d and %c%y-%m-%d %H:%M:%S.
    Examples:
    2025-01-31
    2025-06-05 09:00:00
    Note: Do not use quotes when entering a literal date value.
  • Time resolution in hours (required)
    Determines the smallest time increment for dragging or resizing tasks.
    Examples:
    A value of 1 → drag/resize in steps of one hour
    A value of 0.25 → drag/resize in steps of 15 minutes
    Note: Must be a positive number greater than 0.
    This value defines the final position and duration of tasks when adjusted.
  • Job Height (optional)
    This option allows you to override the default dynamic job height behavior of the Gantt chart.
    By default, the height of jobs is determined dynamically based on the available widget area, the number of jobs, the number of resources and whether jobs are overlapping. When fewer jobs and resources are displayed, the job height increases so that all jobs fit within the visible widget area. Once a minimum job height is reached, if there are still more jobs than can fit in the widget, a vertical scroll is introduced to allow access to all jobs.
    When the Job Height option is set, the job height becomes fixed and no longer depends on the number of tasks, resources, or the widget size.
    The setting can be configured via a literal numeric value or a scalar parameter.
    Note: The value must be a positive number greater than 0.
    Job Height Calculation
    The actual job height in pixels is calculated as follows:
    pointPadding and groupPadding are small adjustments based on whether the Non-Overlapping Jobs option is enabled.
    This formula ensures consistent spacing between tasks while respecting the configured job height.
    // ``nonOverlappingJobs`` indicates whether the ``Non-Overlapping Jobs`` option is enabled.
    pointPadding = nonOverlappingJobs ? 0.1 : 0
    groupPadding = nonOverlappingJobs ? 0 : 0.2
    finalJobHeightInPixel = jobHeight * (1 - (2 * groupPadding)) * (1 - (2 * pointPadding))
  • Non-Overlapping Jobs (optional)
    By default, overlapping tasks within the same resource are displayed on top of each other.
    Enabling this option moves overlapping tasks to separate rows within the same resource, improving readability.
    The setting can be configured via a literal binary switch or a scalar binary parameter.
  • Show Now/Today (optional)
    Enabling this option displays a visual indicator of the current day and time within the chart, helping users quickly identify where tasks fall relative to the present moment.
The “Now/Today” indicator uses the local browser time, based on the system clock of the user’s machine.
The “Now/Today” background indication is only visible when the Gantt chart’s time horizon spans more than 24 hours.
  • Double Click Action (optional)
    By default, a single click or double click on a task selects it. This option allows you to execute a model procedure when a task is double-clicked.
    The option is set by specifying a procedure in the model. Once configured, the procedure is executed on every double click of a task.
On every double click of a task, the store-focus information for that task is captured, regardless of whether the Double Click Action option is set.
Combined with the store-focus information, the double click action can be used to perform task-specific operations — such as deleting a task or opening a dialog to edit its properties.
  • Viewport Settings
    • Viewport start time (optional)
      Specifies the leftmost visible time in the chart. Typically used with Viewport end time to define a display window.
      Can be set using a literal date value or a scalar string parameter.
      Accepted formats are the same as for Reference time.
      If left unset, the option appears empty, but internally the chart determines an appropriate start time to ensure all tasks are visible.
    • Viewport end time (optional)
      Specifies the rightmost visible time in the chart. Typically used with Viewport start time to define a display window.
      If left unset, the option appears empty, but internally the chart determines an appropriate end time to ensure all tasks are visible.
  • X-Axis (optional)
    By default, the chart automatically determines appropriate X-axis time intervals based on the tasks’ Start and Duration data, as well as the Viewport settings, ensuring an optimal, readable timeline display.
    For scenarios requiring custom control over how the X-axis and gridlines appear, the X-Axis option allows you to define multiple time intervals, specify the step size and display format for each interval, and configure the corresponding gridlines. Refer to this section for more details.
Pivoting
In the Pivot tab of the widget options editor, you can define how the data dimensions are organized in the chart. The dimensions shown correspond to the union of the domain indices of the Start and Duration identifiers configured in the Contents tab.
The Gantt chart displays a task for every index (or combination of indices) specified in the Jobs part. Each task index must be present in the Jobs section.
Similarly, the chart displays a row for every index (or combination of indices) specified in the Resources part. If no index is assigned to the Resources section, the chart will display a single row.
_images/gantt-chart-v2-pivot.png
Index Settings and Store Focus
In the Index Settings tab of the widget options editor, you can specify, for each index, an element parameter of the same underlying set, super-set or a sub-set.
When the user interacts with a job (task), by selecting/clicking it, horizontally dragging it or vertically dragging it, the corresponding job becomes selected and highlighted, and the configured element parameter is updated with the appropriate element information.
This functionality can be leveraged to build an interactive user flow within the application.
Select, Hover and Tooltips
When the user interacts with a job (task), by selecting/clicking it, horizontally dragging it or vertically dragging it, the corresponding job (horizontal bar) is visually highlighted, while all other jobs become slightly transparent. This makes the job interacted with stand out clearly.
When hovering over overlapping jobs, the job under the cursor is brought to the front. The hovered job retains full opacity, while the others are slightly faded, making inspection easier.
Hovering over a job also displays a tooltip. The tooltip may be:
  • the default tooltip, which shows detailed information about the job, or
  • a custom tooltip, defined using a webui::TooltipIdentifier annotation on the Duration identifier configured in the Contents tab of the widget options editor.
Starting with WebUI 26.3, HTML tags are supported in Gantt Chart V2 tooltips. Instead of treating HTML tags as literal text, the WebUI will interpret them as markup instructions, allowing you to format the tooltip content with rich HTML (e.g., tables, bold/italic text, lists) for better readability.
As a precaution, any content enclosed within <script> tags or image tags containing onerror or javascript attributes will be removed before rendering. This ensures that arbitrary JavaScript code cannot be executed within the application, mitigating potential security risks.
Even when a job is selected, the user may hover over another job and view its tooltip. Hover behavior works the same way regardless of whether a job is currently selected.
Starting with WebUI 26.9.1, clicking a non-interactive area within the Gantt chart widget clears the current job selection, providing a quick way to deselect all selected jobs. Individual jobs can also be deselected by clicking them again.
Selection is only cleared by a regular click on a non-interactive area within the widget. Ctrl+clicks, double-clicks, clicks on widget header buttons, and clicks outside the widget leave the selection unchanged.
In all cases, deselecting a job only removes its visual highlight. The stored focus value is not cleared or reset.
Inline Text
By default, no inline text is shown for jobs. Although default or custom tooltips show relevant information when hovering over a job on the chart, it is often more intuitive to display key information directly within the job’s horizontal bar.
By specifying a webui::ItemTextIdentifier annotation, as explained in the Identifier Annotations section for the Duration identifier configured in the Contents tab, you can configure the text to appear inline within the corresponding jobs.
Vertical Scrolling
The chart automatically adjusts the height of the jobs to display all resources and jobs within the available widget area.
A default minimum height is used for the jobs. When the Non-Overlapping Jobs option is enabled, or when there are many jobs that require a height greater than the minimum, the chart automatically enables vertical scrolling.
Custom Styling
By specifying a webui::AnnotationsIdentifier annotation, as described in the Identifier Annotations section, and by applying the techniques outlined in Custom Styling, you can define custom visual styles for jobs in the chart.
For example, in the current sample application, jobs with a duration greater than 5 days (120 hours) can be styled differently. An illustration of this modelling and styling is shown below:
_images/gantt-chart-v2-annotationidentifier.png
.chart-item.annotation-RedFlag{
    stroke: black !important;
    stroke-width: 2px !Important;
    stroke-dasharray: 5,3;   /* dotted or dashed */
    stroke-linecap: round;   /* optional, makes dots rounded */
    fill: red;
_images/gantt-chart-v2-CustomStyling.png
Aligning Resource Labels
Starting with WebUI 26.9.1, the resource labels displayed in the column to the left of the chart area are rendered as HTML elements. This makes it possible to customize their horizontal alignment using CSS.
By default, the resource labels are right-aligned, placing them closest to the chart area.
To change the alignment, add a rule for the .axis-label-text class to a CSS file in the Application Specific Resource (ASR) folder MainProject\WebUI\resources\css, as outlined in Custom Styling.
The alignment is controlled by the justify-content property, which supports the following values:
  • flex-start
    Left-aligns the resource labels within the column.
  • center
    Centers the resource labels within the column.
  • flex-end
    Right-aligns the resource labels within the column. This is the default setting.
The following example centers the resource labels:
.tag-gantt-chart-v2 .y-axis .axis-label-text {
    justify-content: center;
_images/gantt-chart-v2-resourcelabel-alignment.png
The following example left-aligns the resource labels:
    justify-content: flex-start;
        padding-left:3px;
_images/gantt-chart-v2-resourcelabel-left-alignment.png
The width of the resource label column cannot currently be configured through CSS. When the chart is loaded, the column width is automatically sized to fit the longest resource label.
Support for user-resizable resource label columns is considered for a future release. If this functionality would be useful for your application, please let us know through the AIMMS Community Ideas page.
Widget Extensions
In the Widget Extensions tab of the widget options editor, you can add the string parameters associated with the Widget Actions.
Once the Widget Actions option is configured with an identifier containing the appropriate data, the corresponding widget actions become available via the icon displayed in the widget header.
Likewise, the Widget Extensions tab also allows you to add the string parameters linked to the Item Actions.
Once the Item Actions option is set with an identifier containing the required data, you can access the related item actions by right-clicking on a job (task).
Miscellaneous
In the Miscellaneous tab of the widget options editor, several additional options can be configured. These include:
  • the Title of the widget, which appears in the widget header, and
  • a Visible option, which determines whether the widget is displayed on the page.
Both of these settings may be specified directly as literals or through model identifiers.
Starting with WebUI 26.3, each resource row is now displayed uniquely based on the indices pivoted into the Resources area.
Previously, multiple resources sharing the same display name would be grouped together in a single row. With this update, even if multiple resources have identical display text, they are no longer grouped and are shown as separate, unique rows.
This change ensures that every individual resource is represented distinctly in the chart, improving clarity and avoiding ambiguity when resources share the same name.
Customizing X-Axis Intervals
By default, the Gantt chart automatically determines appropriate X-axis time intervals based on the tasks’ Start and Duration data, along with the Viewport settings. This ensures a clear, readable timeline. However, these default intervals provide limited control over the X-axis configuration, such as interval selection, label formatting, and the display of gridlines.
For scenarios that require more precise control, you can configure custom X-axis intervals through the X-Axis section in the Gantt Chart Settings tab of the widget options editor. This allows you to define multiple time intervals, customize the step size and label format for each interval, and determine whether gridlines in the main chart area should be displayed based on those intervals.
Adding and Configuring X-Axis Intervals
By default, a single pair of Time Interval, Step Size, Label Format, and Show Gridlines options are displayed. You can click the “+” button at the bottom to add multiple pairs and configure additional X-axis settings.
Multiple X-axis settings can be added and they will be plotted in ascending order as they appear in the options editor. You can reorder them using the up-arrow or down-arrow buttons on the option pair headers. To remove a pair, click the delete button.
Each pair includes the following options:
  • Time Interval (optional)
    You can select one of the predefined time intervals:
    • Year
    • Quarter
    • Month
    • Week
    • Day
    • Hour
    Alternatively, you can provide a string parameter whose value matches (case-insensitive) one of the supported options.
  • Default chart behavior: the chart automatically determines the most suitable intervals to display based on the available horizontal space. As a result, certain intervals may be skipped or merged to ensure the timeline remains readable and well-fitted within the chart.
  • You can use either the default interval or custom intervals, but not both simultaneously.
  • Multiple custom intervals with the same interval type are supported.
  • When other custom intervals are configured, leaving this option unset in a pair causes that pair to be ignored.
  • If a string parameter does not match any supported interval, an error message will appear, and the X-axis interval will be ignored.
  • Step Size (optional)
    When the Time Interval option is set, a step size of 1 is applied by default, so every interval is displayed on the X-axis. However, depending on the available space, not all labels may fit and some may be hidden. Use this option to space out the intervals shown on the X-axis and in the gridlines by defining a step size for the time interval.
    You can provide either a literal positive integer or a scalar parameter that resolves to a positive integer. If a value other than a positive integer is provided, the chart displays an appropriate error message.
    Time Interval
    Step Size
    Examples
    Day
    1
    Day 1, Day 2, Day 3, Day 4, …
    Day
    7
    Day 1, Day 8, Day 15, Day 22, …
    Hour
    8
    00:00, 08:00, 16:00, 00:00, …
    Week
    2
    Week 1, Week 3, Week 5, Week 7, …
    The step size is applied relative to the first interval on the axis (the anchor point): the first interval is always rendered, and each subsequent interval shown is the first plus a multiple of the step size (first + N × step size).
  • Label Format (optional)
    By default, labels are automatically determined based on the selected Time Interval and available space. The Label Format option allows you to customize how time intervals are displayed on the X-axis.
    You can provide either a literal string or a scalar string parameter, which can include static text and specific format keywords that are replaced with corresponding values.
    Examples of format usage:
    %d %b → 12 Nov
    %b %y → Nov 2025
Supported Time Interval Label Formats
Key
Locale Notes
%q
Quarter number
%W
Week number (01-53)
%A
Full weekday name (e.g., “Monday”)
%a
Abbreviated weekday name (e.g., “Mon”)
%E
Narrow weekday (single letter)
%d
Two-digit day (01–31)
%e
Day (1–31)
%w
Day of the week (1-7)
N/A
%b
Abbreviated month name (e.g., “Jan”)
%B
Full month name (e.g., “January”)
%m
Two-digit month (01–12)
%o
Month number (1–12)
%y
Two-digit year (e.g., “25” for 2025)
%Y
Four-digit year (e.g., “2025”)
%H
Hour (00–23)
Locale may display in 12-hour format
%k
Hour (0–23)
%I
Hour (00–11, 12-hour format)
N/A
%l
Hour (1–12, 12-hour format)
N/A
%M
Minutes (00–59)
%p
Uppercase AM/PM
Locale-dependent
%P
Lowercase am/pm
Locale-dependent
%S
Seconds (00–59)
%L
Milliseconds
Example Label Formats
You can combine multiple format keys to fully customize the X-axis label appearance. Formatting follows standard C-style conventions and supports locale-aware names for weekdays, months, and time indicators.
Format String
Example Output
%b %Y
Nov 2025 — abbreviated month and four-digit year
%A, %d %B
Wednesday, 12 November — full weekday and month name
Week %W, %Y
Week 01, 2026 — week number and year
Day %w of W%W
Day 1 of W01 — day number and week number
%d-%m-%y
12-11-25 — numeric date format
%H:%M
14:30 — 24-hour format
%I:%M %p
02:30 PM — 12-hour format with AM/PM
Q%q %Y
Q4 2025 — quarter and year
%b %e, %H:%M
Nov 12, 09:15 — abbreviated month, day, and time
  • The chart automatically adjusts the time interval labels to fit within the widget’s width.
  • If a label is too wide to fit within its allocated space, it may not be displayed.
  • Show Gridlines (optional)
    By default, when no custom X-axis intervals are configured, gridlines in the chart area follow the automatically determined X-axis intervals. When custom X-axis intervals are defined, gridlines are disabled by default for those intervals.
    The Show Gridlines option allows you to control whether gridlines are displayed in the chart area based on the corresponding custom time intervals.
    You can enable or disable gridlines for a specific interval using either a literal binary switch or a scalar binary parameter.
Gridlines can be enabled for one or more custom time intervals. However, enabling gridlines for multiple intervals especially fine-grained intervals may clutter the chart area and impact rendering performance.
It is recommended to enable Show Gridlines for only one custom interval at a time to keep the chart clear and maintain optimal performance.
Adding, Deleting and Modifying Tasks
Adding Task
Direct addition of tasks from the Gantt chart is not supported.
Deleting Task
Direct deletion of tasks from the Gantt chart is not supported.
Tip
To provide a more intuitive and streamlined user experience, consider leveraging modern workflow capabilities for task management:
  • Create - Launch a dialog page from the Gantt Chart widget action or page action to create new tasks.
  • Modify - Configure an item action or double-click action to edit task details, optionally opening a dialog page with the task properties.
  • Delete - Implement an item action or double-click action that opens a confirmation dialog before removing a task.
Modifying a task
Horizontal Dragging
When hovering over a job, drag handles appear near the edges of the task bar, while the mouse pointer indicates that it can be moved around.
Dragging the handle on the left adjusts both the start time and the duration, while dragging the handle on the right only adjusts the duration.
You can adjust the start time of a task by dragging the task horizontally to a new position.
Vertical Dragging
Users can reassign a task to another resource by dragging it vertically.
For vertical dragging to work:
  • the Duration identifier must be editable.
  • when a task is dragged to a resource that already contains a task with the same index combination, the existing task is replaced, and the newly dragged task is retained.
  • if the last remaining task in a row is moved away, the original row will disappear, because WebUI displays data sparsely.
Multiple Task Selection
Starting with WebUI 26.6.1, multiple tasks can be selected simultaneously in the Gantt chart. This enables bulk operations such as moving or resizing several tasks in a single action.
Selecting tasks
  • Single selection: Click a task bar to select it. Any previously selected tasks are deselected.
  • Multi-selection: Use Ctrl+Click to add tasks to the current selection.
    Multi-selection supports:
    • Multiple tasks within the same resource row.
    • Multiple tasks across different resource rows.
    Selected tasks do not need to belong to the same resource.
Block selection
To select multiple tasks at once, press and hold the mouse button on an empty area of the Gantt chart, then drag to draw a selection rectangle.
Any task touched by the rectangle is selected, even if the rectangle overlaps only part of the task. The selection can span multiple resource rows and a wide time range, making it an efficient way to select a large group of tasks.
  • Drag without a modifier key: Replaces the current selection with the tasks inside the rectangle.
  • Ctrl + Drag: Adds the selected tasks to the existing selection. You can repeat Ctrl+drag to build multiple separate groups. Tasks that are already selected remain selected.
  • Esc while dragging: Cancels the selection in progress and restores the previous selection.
Tasks selected using block selection behave the same way as tasks selected with Ctrl+Click. They can be moved or resized together.
Block selection is supported only with a mouse. There is currently no keyboard or touch equivalent.
Block selection does not change the store focus, because it does not involve clicking an individual task. Store focus changes only when you click or drag a task.
Deselecting tasks
Clicking a task without holding Ctrl clears the current selection and selects only the clicked task.
Starting with WebUI 26.9.1, clicking an empty area inside the Gantt chart widget clears the entire multi-selection at once, as described in the Select, Hover and Tooltips section.
Dragging a selection rectangle over an empty area without holding Ctrl clears the selection in the same way.
Visual feedback
Selected tasks are visually highlighted with a border, making the active selection clearly visible.
Moving Multiple Tasks
Dragging a Task Bar
Dragging the bar of any selected task moves all selected tasks by the same time offset.
The time intervals between the selected tasks are preserved.
Moving Tasks Between Resources
When a multi-selection is dragged and dropped onto a different resource row:
  • All selected tasks are reassigned to the target resource.
  • The dragged task is positioned at the drop location.
  • The time intervals between the selected tasks are preserved.
  • Each task retains its duration.
  • Resource assignments are updated to the target resource.
As with single-task vertical dragging, if a task already exists at the same tuple combination in the target resource row, it is replaced by the moved task.
Resizing Multiple Tasks
Adjusting Start Times
Dragging the left resize handle of any selected task applies the same start-time offset to all selected tasks.
Each task’s start time is shifted by the same amount, and durations are adjusted accordingly.
Adjusting End Times
Dragging the right resize handle of any selected task applies the same end-time offset to all selected tasks.
Each task’s end time is shifted by the same amount, and durations are adjusted accordingly.
Multi-task operations respect the same constraints as single-task operations. For example, tasks marked as read-only through a webui::FlagsIdentifier annotation cannot be moved or resized.
If a task in the selection cannot participate in an operation:
  • The constrained task remains unchanged.
  • Other eligible tasks are updated normally.
During resize operations, a task is excluded if the resulting duration would become zero or negative. In that case:
  • The task’s start time and duration remain unchanged.
  • All other selected tasks are resized as requested.
Snapping to time resolution while dragging
During both horizontal and vertical dragging, the time resolution defined in the widget properties is respected. Tasks will “snap” to the nearest configured time unit.
Restricting Tasks Movement
All Tasks Read-Only
To make the task start and duration values read-only, remove the corresponding identifiers from the built-in AIMMS set CurrentInputs:
CurrentInputs := CurrentInputs - 'TaskStart' - 'TaskDuration';
where TaskDuration and TaskStart are your task duration parameter and your task start parameter respectively. Obviously, start or duration parameters with a definition in AIMMS are also read-only.
Cherry-Picking Read-Only Tasks
By specifying a webui::FlagsIdentifier annotation, as explained in webui::FlagsIdentifier for the Start and Duration identifiers configured in the Contents tab, you can make specific task properties read-only.
  • If the task’s Start property is read-only, the task cannot be moved horizontally, but its duration can still be modified using horizontal dragging.
  • If the task’s Duration property is read-only, the task cannot be resized.
  • If both the Start and Duration properties are read-only, the task cannot be moved or resized, and the drag handles will not be displayed when hovering over the task.
Custom Horizontal Scrolling or Zooming Behavior
You can implement custom scrolling or zooming behavior in the Gantt chart by using AIMMS string parameters to specify the viewport start time and viewport end time.
Typically, a procedure will convert the string into a moment, perform arithmetic on the moment, and then convert it back into a string. The following example demonstrates identifiers and procedures that allow scrolling the Gantt chart to the left or right.
StringParameter ViewportStart;
StringParameter ViewportEnd;
Procedure MoveDate {
    Arguments: (dateString, numHours);
    Body: {
        moment := StringToMoment("%m-%d-%c%y %H:%M", [hour], "2016-01-01 00:00", dateString);
        moment += numHours;
        dateString := MomentToString("%m-%d-%c%y %H:%M", [hour], "2016-01-01 00:00", moment);
    StringParameter dateString {
        Property: InOut;
    Parameter numHours {
        Unit: hour;
        Property: Input;
    Parameter moment {
        Unit: hour;
Procedure ScrollViewport {
    Arguments: (numHours);
    Body: {
        MoveDate(ViewportStart, numHours);
        MoveDate(ViewportEnd, numHours);
        Unit: hour;
        Property: Input;
Procedure ViewportScrollToTheRight {
    Body: {
        ScrollViewport(1[hour]);
Procedure ViewportScrollToTheLeft {
    Body: {
        ScrollViewport(-1[hour]);
The AIMMS function StringToMoment is used to convert a date string into a numeric moment, which allows easy date arithmetic. After calculations, the number is converted back into a date string using MomentToString.
Developer Settings: Adjusting the Tasks Count Threshold
This widget has been optimized to efficiently handle large datasets by selectively loading only sparse, non-zero data. By default, it will process and fetch up to 1,500 tasks (jobs). If this limit is exceeded, an error message similar to the one below will be displayed:
_images/gantt-chart-v2-tasks-overload-error.png
We recommend configuring the Gantt chart to display only the most relevant information to avoid overwhelming users with excessive data. By default, a threshold of 1,500 tasks is set.
However, we recognize that there may be use cases where more tasks need to be visualized. A custom option is made available for app developers to control the threshold for the number of tasks retrieved and displayed on the chart.
This option can be configured through the Application Specific Resource (ASR) file, located at MainProject\WebUI\resources\javascript\webui-options.js. If this file does not already exist in the resources subfolder, it will be automatically created when WebUI is launched in developer mode.
To adjust the task count threshold, edit this file and set the webui_ganttchart_jobs_overload_threshold key to the desired value.
/* Configure the Gantt Chart widget's task overload threshold */
webui_ganttchart_jobs_overload_threshold = 2000;
The setting shown in the example above means that any Gantt chart in the WebUI will display a maximum of 2,000 tasks in it.
Guidelines and Recommendations
  • While the Gantt chart may display only a few tasks, it might still be processing a large amount of data in the background. This can negatively impact the chart’s performance and responsiveness. When using the display-domain option, we recommend applying domain conditions on the display domain identifier to limit the amount of data being processed. For example, including the Duration identifier as a domain condition ensures that only jobs likely to appear on the chart are considered, improving overall efficiency.
  • Similarly, for identifiers used in tooltips, inline text, annotations, and other chart elements, we recommend including the Duration identifier as a domain condition. This ensures that only relevant data is evaluated and helps maintain efficient data modelling.
  • Avoid adding highly granular X-axis intervals when the viewport spans a large time range (for example, a full year or multiple years). Defining intervals at a very fine resolution, such as minutes or days over such a wide range can significantly degrade chart performance.
  • To prevent a job from being added outside a specific time range, apply the appropriate index domain condition on the Start and/or Duration identifier. This ensures that the job can only take values within the allowed range.
