WebUI Resources
This section describes the various application specific resources (ASR) for an AIMMS WebUI app.
Before going into each specific resource, please note that it is a best practice to store only those resources which are actually needed/used by the project. In particular, you should not store in your final project version any files which have a “test” substring in their name, i.e., which are intended for intermediate testing purposes for your app. Storing the needed resources only may contribute to a more efficient delivery of the WebUI components of your application.
Adding the resources folder
In order to use any of the following listed features, you will need to create a new folder called resources (case sensitive), located in:
<.aimms Root folder> > MainProject > WebUI > resources.
This folder is loaded each time the WebUI starts up or at every reload (F5) of your WebUI browser page.
Images
Application-specific images should be stored in the resources/images subfolder. This folder is not created by default, so you need to create it yourself the very first time that you need it.
JavaScript
Application-specific JavaScript files (e.g. widget [add-ons] ) or Unit Support files should be stored in the resources/javascript subfolder.
Please note that in your final project version you should not include in this folder any file with a “test” addition to its name, for example, like theme-switch-addon.test.integration.js
. Such files may have a negative impact on the performance of delivering the WebUI components en therefore, they should be removed when the application is being deployed. Currently, AIMMS does not skip any files; it just wraps those files with some try/catch checks in order to avoid JS errors. Please note that AIMMS may skip such files which use the word “test” in the future.
CSS
It is possible to (re)style your web application by providing custom Cascading Style Sheets (CSS). Application-specific CSS files should be stored in the resources/css subfolder of the WebUI subfolder of your project folder.
For more info on CSS in general, see this Wikipedia article.
Load ordering
The feature described in this section was available in AIMMS versions up to 4.77. Starting from AIMMS 4.78 this feature is no longer supported.
By default, resources are loaded in alphabetical order. You can influence this loading order by putting a package.json
file in the folder alongside the resources to be loaded and specify a specific loading order in it.
An example package.json could be:
"name": "my-application-specific-resource",
"version": "0.0.1",
"config": {
"aimms:asr": {
"files": [
"b.js",
"a.js",
"c.css",
Your project can have multiple
package.json
files.All resources loaded explicitly by a
package.json
file will no longer be loaded through alphabetical order.The loading order of the same file specified in multiple
package.json
files is undefined and is best avoided.
