Miscellaneous Application Settings
The application options under the Miscellaneous tab of the Application Settings are explained below. Please note that some of these options may no longer be available in the latest AIMMS versions, but may be still visible in apps running under some older AIMMS versions.
_images/AppSettings_snap2.png
Use Classic Theme
From AIMMS 4.59 onwards, the look and feel of the WebUI has been upgraded to a more modern look and a consistent styling. However, for app developers who need more time to make sure their customized application looks as required with this new theme, the WebUI will offer you the choice which theme you want to use. More specifically, if you open an entirely new WebUI application, you automatically get the new look and feel (because there cannot be any backward compatibility issues in that scenario). If you open an already existing WebUI, however, you are offered the choice to try the new theme or to keep the old one for the time being. Should you want to toggle between the two, after having made this choice, we offer the ‘Use Classic Theme’ option in the ‘Miscellaneous’ tab. Simply set the switch to ‘on’ for the old theme, or to ‘off’ for the new theme:
_images/use_classic_theme_on.png
Besides this, we offer a ClassicTheme.css file, which you can use to adjust some settings when you choose to retain the classic theme. The comments in this file should provide pointers on what to change. When adjusted, the file should be copied into the resources/css folder of your WebUI project. Furthermore, make sure you do use the new page navigation menu, as released with AIMMS 4.53.1.
When opting to use the new theme, we offer two .css files, which you can use to easily add a logo to the header bar of your WebUI pages and to change the color of the horizontal line below the header bar. The ReadMe file offers guidance on how to do this. If you indeed start using the new theme, we strongly advice you to ‘start from scratch’, in case you are using lots of customized css for your model. If you want a more extensive change, we suggest to connect with our support team. Please also make sure to remove any ‘ClassicTheme.css’ file, as described in the previous paragraph, in case you have copied it to your css folder.
Note: The styling for the Classic Theme was removed with AIMMS 4.84. Using the Classic Theme option will present you with a warning, when using that or a more recent AIMMS version. Styling will revert to what we now call our default theme (and might not be 100% compatible with your needs and custom styling any more).
UI Editable
This is a logical condition which determines whether or not the user interface is editable when the application is run under the AIMMS PRO platform.
When this condition evaluates to “true” and the value of the “Limited Options Editor” (see also below) evaluates to “false”, then all editing options available in developer mode are also made available to the end-user who runs the application in AIMMS PRO/Cloud. For example, the end-user can change the order of the widgets on a page in this case.
When the “UI Editable” condition evaluates to “false”, then the end-user running the application in AIMMS PRO/Cloud is no longer allowed to edit the user interface, but only to use the pages and widgets as they are, i.e. as provided by the app developer. More specifically, the Application Settings, Page Settings, Widget Manager and Page Manager icons are no longer available in the Menu Bar. The latter (the Page Manager) is never displayed when run under the PRO platform.
Moreover, the “cog wheel” Settings icon is no longer available for any of the widgets, so the widget options are no longer editable.
The UI Editable setting defaults to True. When left unchanged, it allows end users to modify the user interface when the application is deployed on the AIMMS PRO platform.
For end users, even when the UI Editable option is enabled, the following Application Settings are always hidden and not accessible: Application Defaults, Workflow Settings, Application Extensions, Menu Hidden, and Data Manager Hidden.
Limited Option Editor(1/0)
This is a logical condition which determines whether or not the PRO user of the app gets limited access to the options in the widget/page editor.
Please note that, when the “UI Editable” option value evaluates to “false”, then the value of this “Limited Options Editor” is not relevant.
When the “UI Editable” option value evaluates to “true” and the value of the “Limited Options Editor” evaluates to “true” as well, then the editing options available in developer mode are made available to the end-user who runs the application in AIMMS PRO/Cloud. For example, the order of the widgets on a page in the Widget Manager can still be changed in this latter case.
However, in this latter case there are also some limitations, such as the following:
  • The Application Settings are not available for editing
  • In widget options editor only the following sections are shown: Pivoting, Contents, Change Type, and Totals. So, in particular, the Miscellaneous and Advanced sections are not available for editing in the settings of any widget.
  • Starting from WebUI 26.11.1 the “End User Widget Controls” feature is enabled by default. This makes the “Limited Option Editor” option obsolete: it is removed from the Miscellaneous tab, and any value previously configured there is ignored.
  • If your application relied on Limited Option Editor to restrict the option editor categories accessible to end users, you must reconfigure that access using End User Widget Controls instead. Until you do so, all option editor categories are accessible to your end users by default.
Data Manager Hidden
This option allows you to control whether the “Data Manager” button is visible on the application header bar.
Enable SENSAI Chat
This option allows you to control whether the “SENSAI” button is visible on the application header bar.
Default value is off and the button is hidden. When enabled, the “SENSAI” button is visible, and clicking it opens the SENSAI chat panel on the right side of the WebUI application.
The setting can be configured via a literal binary switch or a scalar binary parameter.
Starting with WebUI 26.13.1, the SENSAI chat panel can be resized by dragging its left edge.
The panel opens at a width of 400 pixels, which is also its minimum width, and it can be widened up to half of the browser window width. These limits cannot be configured.
While you drag, the page content, the side panel, the page actions and any open widget options dialog move along with the edge of the panel, so they stay visible next to it. On classic pages, the page content scales down to fit next to the open panel.
If the browser window becomes smaller, the panel narrows so that it never takes up more than half of the window.
The panel keeps its resized width when you navigate to another page. When you reload the page or start a new session, the panel opens again at its default width of 400 pixels.
Licenseinfo
This a string option for some text about the used license which may be placed on the top of the menu bar.
Page Manager Hidden
This is a logical condition which determines whether or not the Page Manager button on the menu bar is visible or is hidden.
Starting from AIMMS 4.78 this option is no longer available.
