WebUI Release Notes
All WebUI release notes of AIMMS versions older than AIMMS 24.4 can be found here. From AIMMS 24.4 onwards, the WebUI can be added to your AIMMS project as a repository library from the Library Manager in AIMMS (see here).
WebUI 26.13
WebUI 26.13.1 Release (October 23, 2026).
Improvements
  • For apps that have enabled AIMMS SENSAI, the SENSAI chat panel can now be resized by dragging its left edge. The panel opens at a width of 400 pixels and can be widened up to half of the browser window width, while the page content moves along so it stays visible next to the panel. The resized width is kept when you navigate to another page, and is reset to the default width when you reload the page or start a new session. See Enable SENSAI Chat for details.
WebUI 26.12
WebUI 26.12.6 Release (October 22, 2026).
Resolved Issues
  • Tooltips on workflow steps, table headers and charts could intermittently show the text of another element, or disappear altogether, after moving the mouse between elements.
  • A page added as the first change after the application was started was not added to the page identifiers in the model, such as webui::AllPageIds, until another page was added, renamed or removed. As a result, navigating to such a page showed the error Unable to map '<pageId>' to an element within the range of set 'webui::AllRegularPages'.
  • With WebUI State Support enabled, navigating to the editing page of a dialog or side panel showed an error. The webui::TargetPageId WebUI identifier now keeps its previous value in that case, consistent with webui::CurrentPageId.
  • Upon Change procedures with (hasChanged, oldValue) arguments did not work for identifiers declared in the private section of a library.
  • In Table V2, filters were not cleared when the table contents were added, removed, reordered or changed to a different identifier. Filters are now cleared in these cases, as they already were in the earlier Table version.
  • In a Multiselect widget on a multi-dimensional identifier with one index fixed by an element parameter or a fixed element, the SELECT (n) and DESELECT (n) buttons now show the correct count when a search query is entered. Clicking them selects or deselects exactly the filtered elements for the current value of the fixed index.
  • Since the introduction of rounded corners in the WebUI, Button widgets on dialog pages were shown with an unexpected grey rectangular border around them. They now follow the rounded style, like Button widgets on other pages.
WebUI 26.12.5 Release (October 1, 2026).
Resolved Issues
  • Changes made by an Upon Change procedure to restore a job’s previous start time or duration are now immediately reflected in the Gantt Chart v2, without requiring the chart to be redrawn.
WebUI 26.12.4 Release (September 24, 2026).
Improvements
  • Based on customer feedback, the cardinality of the webui::ExtensionOrder set has been increased from 100 to 1,000. This provides greater flexibility when configuring WebUI extensions such as Workflows, Page Actions, Widget Actions, Item Actions, Status Bar messages, and Tabbed widgets.
Resolved Issues
  • We improved the error message for the situation that the app developer tries to include a page with a Tabbed widget on it into a Tabbed widget.
  • The performance of the webui::GetAllPages function has been improved in developer mode. On the cloud, its performance was already fast.
WebUI 26.12.3 Release (September 17, 2026).
Resolved Issues
  • Table filtering was not applied correctly when a table contained ‘-’ in a row or column header and a filter was applied to a nested row or column header associated with the ‘-’ cell.
  • In a table showing several identifiers side by side with store focus configured, clicking a cell moved the focus back to the first identifier’s column whenever those identifiers had a display text differing from their identifier name.
WebUI 26.12.2 Release (September 8, 2026).
Resolved Issues
  • Node labels were displayed behind arcs on the Map widget. In situations with multiple arcs crossing or running from/to a specific node, this could make the node label unreadable. Now the node labels are displayed on top of any arcs.
  • When resizing a job on the Gantt chart to a size of zero, any upon change procedure in the model (on the associated duration parameter) would not trigger.
WebUI 26.12.1 Release (September 1, 2026).
Improvements
  • We added an Application settings option, “Enable SENSAI Chat,” so you can control whether the “SENSAI” button appears on the application header bar.
Resolved Issues
  • Rows at the opposite end of the Gantt chart from the current scroll position could intermittently disappear.
WebUI 26.11
WebUI 26.11.1 Release (August 26, 2026).
Improvements
  • Table V2, Highlight Annotations, WebUI State Support, Compact Scalar, and End User Widget Controls features are now enabled by default. These remain experimental, release-candidate features — we welcome your feedback and will take it into account as we work to promote them to fully supported status by the end of the year.
  • You can now dynamically update your WebUI app’s CSS styling and apply the changes without requiring an end user page refresh, giving you more flexibility to customize the look and feel of your apps at runtime. See the documentation for details.
  • The Gantt Chart v2 widget now supports selecting multiple tasks at once via click-and-drag block selection, hold Ctrl while dragging to add disjoint groups, with automatic vertical scrolling as you drag.
With the End User Widget Controls feature enabled, the older Limited Option Editor option becomes obsolete: it is removed from the Miscellaneous tab, and any value previously configured there is ignored.
If your application relied on Limited Option Editor to restrict the option editor categories accessible to end users, you must reconfigure that access using End User Widget Controls instead. Until you do so, all option editor categories are accessible to your end users by default.
Resolved Issues
  • Uploading a file whose name contains special characters no longer results in a “path cannot be found” error.
  • Reverse store focus set while a page was still loading was previously ignored — the table now highlights the focused cell and scrolls it into view.
  • The Slider widget’s validation message now displays correctly when the value range contains negative values.
WebUI 26.10
WebUI 26.10.1 Release (August 6, 2026).
Improvements
  • WebUI is now built with the same toolchain as AIMMS: Microsoft Visual C++ 194 on Windows and GCC 11.5 on Linux. Because WebUI contains binaries that are loaded into AIMMS, this version of WebUI can only be used with an AIMMS release built for that runtime (AIMMS 26.3.1 or higher), and a WebUI version built for the previous runtime cannot be used with such a release. Please update WebUI and AIMMS together.
  • The third-party components that WebUI ships have been reviewed and brought up to date, resolving several reported vulnerabilities.
WebUI 26.9
WebUI 26.9.1 Release (August 6, 2026).
Improvements
  • Based on customer feedback, we have introduced the following enhancements to the Gantt Chart v2 widget:
    • Task deselection is now more intuitive. Click anywhere within the chart, except on a task or other data element, to clear the current selection.
    • Resource labels are now rendered as HTML instead of SVG, making it possible to customize their horizontal alignment (left, center, or right) using ASR custom CSS. By default, resource labels remain right-aligned.
WebUI 26.8
WebUI 26.8.1 Release (July 27, 2026).
Improvements
  • The Gantt Chart now supports a configurable step size for X-axis intervals, allowing greater control over the granularity of the timeline (e.g., every 8 hours, 2 days, or 2 weeks). For details, see the documentation.
  • WebUI now exposes the new webui::TargetPageId identifier, which captures the target page whenever a page navigation is initiated, so PageLeave procedures can act conditionally based on the destination. Available as part of the WebUI State Support experimental feature. See the documentation for details.
Resolved Issues
  • Clicking an empty header cell (displayed as ‘-’) in a table with a store focus setting no longer results in the error “Unable to map ‘-’ to an element within the range of set…”.
  • Table data no longer intermittently disappears when the combined column width exceeds the visible viewport.
WebUI 26.7
WebUI 26.7.1 Release (July 13, 2026).
Improvements
  • The appearance of the workflow panel has been improved as part of our overhaul of the look and feel of the WebUI.
Resolved Issues
  • The Gantt Chart v2 widget’s guideline was misaligned during a bar drag/resize in non-UTC timezones. The snap indicators did not match the committed drop position.
  • When selecting multiple Jobs in the Gantt Chart v2 widget and changing their duration, the ‘hasChanged’ parameter only showed one change at a time, re-triggering the ‘uponchange’ procedure multiple times.
  • The webui::CurrentPageId element parameter referenced the previous pageId instead of the current one when accessed in an OnPageLoad procedure.
WebUI 26.6
WebUI 26.6.4 Release (July 2, 2026).
Resolved Issues
  • Using a filename with non-ASCII characters could lead to error message when using the download functionality in the WebUI.
WebUI 26.6.3 Release (June 30, 2026).
Resolved Issues
  • Re-saving a case that you had marked yourself as a shared case gave an incorrect error that the file was read-only.
WebUI 26.6.2 Release (June 25, 2026).
Resolved Issues
  • Editing a webui.json file in the AIMMS IDE could result in file corruption.
  • Option editors with many identifiers in it could take quite long to open. This is now much quicker. We also introduced a loading spinner to provide feedback while the options are loading.
  • When showing an indexed element parameter in a Selection Box widget it showed all the elements of its associated set in the dropdown instead of just the elements that belong to its current index.
WebUI 26.6.1 Release (June 18, 2026).
Improvements
  • The Gantt Chart now allows multiple tasks to be selected at once, which allows for moving or resizing them all at once. For details, see the documentation.
  • The Selection Box widget now supports HTML content in its dropdown values.
  • We added support for displaying node labels in the Map widget. See the documentation for details.
Resolved Issues
  • When changing the value of an element parameter using a Selection Box widget and after that changing the value of the same element parameter through the AIMMS model, the Selection Box did not update automatically.
  • In rare situations involving empty identifiers in a Table widget, downloading the table contents as an .xlsx file, changing some of its contents and then re-uploading it to the Table widget, could lead to none of the changes being applied to the table.
  • On a page using layout 9, having a Tabbed Pages widget displaying pages with layout 11, part of those pages were cut off.
  • When searching identifiers in the identifier dialog, directly searching (by typing) for an identifier which is in a library sometimes resulted in no matches being found, even if the identifier did exist.
WebUI 26.5
WebUI 26.5.3 Release (May 28, 2026).
Resolved Issues
  • In the Gantt Chart V2 widget, when having a bar selected and right-clicking on another bar, this new bar did not get selected, leaving the store focus set on the previously selected bar. This could lead to unexpected behavior when the user then tried to use item actions on the newly right-clicked bar, as these would be applied to the previously selected bar.
  • We extended the Diagram Widget to support HTML-based tooltips for enhanced node hover interactions.
WebUI 26.5.2 Release (May 22, 2026).
Improvements
  • It is now possible to upload multiple files simultaneously. This allows end-users to select and upload multiple files in one action, improving efficiency and user experience when dealing with bulk file uploads.
Resolved Issues
  • Annotations were not applied to all arcs in the Map widget, preventing custom styling from being consistently rendered on the intended arcs.
  • The Tabbed widget header section did not blend seamlessly with its widget area.
  • The order in which the entries in the webui.json files were written has been accidentally broken since the WebUI 25.3.1 release. This made it hard to track changes in these files, for example when using version control systems. We have now re-established the consistent order for the entries in the webui.json files, which should make it easier to track changes in these files again.
WebUI 26.5.1 Release (May 5, 2026).
Improvements
  • The maximized widget view has been extended, such that when you have a maximized widget on-screen, you can easily navigate to the next or previous widget in the same page, without having to exit the maximized view first. Using previous/next buttons you can now switch to the previous/next widget in the same page, while still in maximized view.
  • We have overhauled our implementation of the Gantt Chart V2 widget. The new implementation is more efficient, both in terms of the amount of data it can handle and in the rendering speed. It offers a today/now line to indicate the current date and time. Furthermore, it supports a double-click action, which lets you select a procedure to immediately run when the user double-clicks on a job.
Resolved Issues
  • In some cases, when right-clicking on Arcs in a Diagram widget, you needed to do so twice in order to have the item actions menu popping up.
  • Read-only libraries were not identified correctly as such in the WebUI, leading, for example, to unexpected behavior by allowing the copying of widgets to pages in such libraries.
  • In WebUI versions from 26.4.1 onwards, all comments and newlines were accidentally removed from the base theming file, making it hard to understand which property is used for theming which part of the application.
WebUI 26.4
WebUI 26.4.5 Release (April 23, 2026).
Improvements
  • As part of our ongoing initiative to improve the WebUI user experience, the fonts used to display data in the Table widget have been updated. Users upgrading from earlier versions will notice a change in the visual appearance of table data.
Resolved Issues
  • Pasting in a Table widget worked only when the V key was released before the Ctrl key.
  • In some situations, when converting a Bar Chart widget to a Combination Chart widget, the webui.json file could get corrupted.
WebUI 26.4.4 Release (April 10, 2026).
Resolved Issues
  • We introduced an option “webui.show-unsupported-values-warning” that allows you to suppress the warning in the WebUI stating that your user data contains unsupported values, for example when using ZERO values. By default, these warnings will be shown. This option needs to be specified (and set to 0) in the webui-options.conf file to suppress the warnings.
WebUI 26.4.3 Release (April 8, 2026).
Resolved Issues
  • In some rare situations, in models that contain some hard references to labels in the set webui::AllPageIds, warnings like ‘The value ‘’ is outside the range set “webui::AllPageIds” of element parameter “MyWebUIPage”’ could be triggered. Please note that it is not recommended to use fixed labels in your model to elements that might not be present in a set.
WebUI 26.4.2 Release (April 3, 2026).
Resolved Issues
  • The Download .xlsx functionality did not work for Table widgets on a library page. This issue prevented users from downloading table data to Excel in that context.
  • Fixed an issue in the Map widget where arcs were displayed incorrectly based on the ArcLabel settings when the configured ArcValue parameter was empty or contained only zeros.
WebUI 26.4.1 Release (March 20, 2026).
Improvements
  • As part of our ongoing initiative to improve the WebUI user experience, we have continued to enhance the WebUI’s visual appeal by giving our buttons rounded corners consistently through the WebUI.
  • We also added rounded corners to dialogs, pop-ups and fly-out menus.
  • The Gantt Chart V2 widget now supports optional vertical grid lines, which can be enabled to improve readability and alignment of tasks across the timeline. When enabled, these grid lines will appear at regular intervals along the time axis, providing a clearer visual structure to the chart and making it easier for users to track task duration and dependencies over time. For more information, please see the documentation.
WebUI 26.3
WebUI 26.3.1 Release (March 5, 2026).
Improvements
  • Incorporating feedback we’ve received on the Gantt Chart v2 widget, we have introduced the following two enhancements:
    • HTML support in tooltips: Tooltips now interpret HTML tags as markup rather than literal text. This allows you to format tooltip content with rich HTML, including tables, bold/italic text, and lists, making the information easier to read and enabling you to convey more relevant details.
    • Unique resource rows: Each resource row is now displayed uniquely based on the indices pivoted into the Resources area. Previously, multiple resources sharing the same display name were grouped together. With this update, even if resources have identical display text, they are shown as separate rows, ensuring each individual resource is represented distinctly and avoiding ambiguity.
  • Visual enhancements for widgets:
    As part of our ongoing initiative to improve the WebUI user experience, all widgets now feature rounded corners, and the widget header section has been updated to blend seamlessly with the widget area. These changes are part of our effort to make the WebUI more modern and contemporary.
WebUI 26.2
WebUI 26.2.2 Release (March 3, 2026).
Resolved Issues
  • Buttons with a tooltip specified for it were rendered light grey instead of blue in certain circumstances, making them look like disabled buttons.
  • Using the ENTER button to confirm adding a widget on the ‘Add Widget’ dialog did not add the widget. Only an explicit click on ‘Add Widget’ would work.
  • The WebUI could break in case your AIMMS project folder name contained some special characters.
WebUI 26.2.1 Release (February 26, 2026).
Improvements
  • We have added a new option to control the job height in the Gantt Chart V2 widget. For details, see the documentation.
  • As part of our broader initiative to enhance the WebUI user experience, we have introduced rounded corners for button widgets. This is the first step in a series of visual improvements. Rounded corners will be extended to additional widgets in upcoming updates, along with other UX enhancements.
Resolved Issues
  • There was a rendering glitch that caused Combination Chart widgets to jump or shift during their initial setup.
  • The tooltip was sometimes appearing in an incorrect position in the Gantt Chart v2 widget.
WebUI 26.1
WebUI 26.1.1 Release (February 17, 2026).
Improvements
  • The performance of the Map widget has improved somewhat. Additionally, we have introduced four new options with which the Map widget reports back its current North-West and South-East coordinates. This allow you to restrict the nodes/arcs that you calculate based on only those currently visible. For more information, please see the documentation.
  • The performance of the Gantt Chart V2 widget has been improved, especially for larger datasets. It now uses so-called ‘lazy loading’ (an optimization technique where data for tasks or rows is only fetched and rendered when they are about to enter the current viewport while scrolling).
Resolved Issues
  • Clicking on a workflow step linked to a page from a library with an uppercase prefix resulted in an error.
WebUI 25.9
WebUI 25.9.3 Release (January 29, 2026).
Resolved Issues
  • Widget creation failed on pages with numeric-only names.
  • Dynamic updates to the job text were not working in the Gantt Chart V2 widget.
WebUI 25.9.2 Release (January 6, 2026).
Resolved Issues
  • Secondary Page Actions were displayed too far to the right in combination with Side Panels. They would overlap the Side Panel, potentially preventing the input of data in any overlapped widget.
  • Identifier slicing was not persistent when used in Widget Named Views.
WebUI 25.9.1 Release (December 16, 2025).
Improvements
  • The new Gantt Chart V2 widget now also offers support for item actions.
Resolved Issues
  • Some jobs in the Gantt Chart V2 were always rendered as non-overlapping, regardless of the “Non-Overlapping Jobs” configuration setting.
  • Moving or resizing a job would throw errors when the start or duration identifier was sliced in the Gantt Chart V2 widget.
  • In some cases, the default coloring of the Gantt Chart widgets was not applied correctly, resulting in charts with just a single color for all jobs.
  • The IFrame widget was not working properly anymore; its settings could not be opened.
  • The Combination Chart, which was corrected in a previous release to make sure all data and labels are always visible, showed choppy animation and could end up in a state of infinite, small correction loops, weighing down on performance and visual appeal. These corrections will now happen only after the animations have finished, meaning they are safe, but also slightly more obvious.
WebUI 25.8
WebUI 25.8.1 Release (November 28, 2025).
Improvements
  • We added an alternative way to run your WebUI app: it can be run locally, but in end-user mode. The app will behave just as it does on the cloud, only it is deployed locally on an end-user machine. Obviously, by doing so you will lose all the maintenance advantages that cloud publication of WebUI offers. For more information, please see the documentation.
  • We created a new version of our Gantt Chart widget, currently released as an experimental feature. This new Gantt Chart V2 widget offers enhanced customization options such as multiple X-axis support and a switch to force a non-overlapping display of overlapping tasks. For more information, please see the documentation.
Resolved Issues
  • The AIMMS and the WebUI versions were shown as undefined in the ‘About AIMMS’ popup.
WebUI 25.7
WebUI 25.7.7 Release (October 24, 2025).
Resolved Issues
  • Displaying a dialog page that was located in a library with one or more capitals in its prefix only showed the bare dialog, without any widgets on it.
  • Using very similar names for multiple pages and using those as parent pages for your menu structure, could lead to pages being displayed beneath the wrong parent page in the actual menu.
  • Changing the order or area of widgets on side panels did not result in the new ordering to be used when actually opening the side panel from a page.
WebUI 25.7.6 Release (October 21, 2025).
Resolved Issues
  • The Combination Chart widget, when placed on Grid Layout pages and when confronted with changes to the size of the chart area (due to a whole range of events like the containing Page or Tab loading, Workflow being added to the page, maximizing the widget to ‘full screen’, zooming in to the chart data or even just resizing the browser window), could end up displaying misaligned, clipped and overlapping chart data, axes or axis labels. Correction will now take place, sometimes visibly so, making sure all data is displayed in as big an area as possible.
WebUI 25.7.5 Release (September 23, 2025).
Resolved Issues
  • In rare cases, when quickly zooming in and/or out on the Map widget, the widget would get ‘stuck’ between two zoom levels and jump back and forth indefinitely.
  • Since the WebUI 25.6.1 release, zooming using the mouse wheel on the Map widget did not take the current position of the mouse into account. Instead of zooming in on that point, the map was zoomed in on the exact center of the displayed map.
  • In some cases, when having a Map widget on two different pages, both with the same Zoom Level identifier specified and switching between the two pages, the zoom level was not retained. Instead, the map was reset to ‘World level’ again.
WebUI 25.7.4 Release (September 11, 2025).
Resolved Issues
  • In some cases, the Combination Chart widget showed too much empty space on the left side of the actual chart.
WebUI 25.7.3 Release (September 2, 2025).
Resolved Issues
  • When the WebUI was used with our SC Navigator product, the SENSAI chat bot did not correctly indicate that it was processing the user’s question anymore.
WebUI 25.7.2 Release (August 22, 2025).
Resolved Issues
  • The Tabbed Pages widget displayed unnecessary empty space when running in PRO, if the tab headers were hidden and the ‘UI Editable’ option was set to false.
  • The mouse scroll wheel could not be used for scrolling in Table widgets anymore since the WebUI 25.7.1 release.
WebUI 25.7.1 Release (August 13, 2025).
Improvements
  • We improved the implementation of the Gantt Chart. We focused on increasing the efficiency of data handling, which results in a quicker display of the chart and an increased amount of data that can be handled.
Resolved Issues
  • Renaming libraries or library prefixes through the AIMMS Library Manager are now correctly registered in the webui.json files.
  • A workflow parent step could not be expanded if the workflow parent’s data was updated after the application initialization.
  • We corrected the Portuguese translations for several texts in the WebUI.
WebUI 25.6
WebUI 25.6.2 Release (July 22, 2025).
Resolved Issues
  • On pages with both primary and secondary page actions that also displayed a Tabbed widget, the secondary page actions button would overlap the primary page action button. That way, it was not possible anymore to run the primary page action.
WebUI 25.6.1 Release (July 17, 2025).
Improvements
  • We have added a Step Size option to the Map widget, which you can use to control the zoom steps on the map. This provides the end-user with finer control when zooming to the map areas that they are interested in.
Resolved Issues
  • Sometimes, when very quickly switching between pages using the Workflow, the currentPageId identifier in AIMMS was not updated accordingly.
WebUI 25.5
WebUI 25.5.3 Release (July 11, 2025).
Resolved Issues
  • When specifying the Menu Bar settings for your app, and subsequently hiding the menu bar, you could not make it visible anymore.
  • Labels on the vertical and/or horizontal axis of Combination Charts should no longer run the risk of being clipped by the edge of the usable widget area.
WebUI 25.5.2 Release (July 9, 2025).
Improvements
  • The implementation of the webui::proint::CaseFileSave procedure was changed, to make it run more time and memory efficient when you use the NoSave property of identifiers.
Resolved Issues
  • After changing the color palette in the WebUI 25.5.1 release, any inactive primary Page Action would have an illegible label when hovered. Page Actions now show the correct colors for all states and content. We made some minor fixes for other combinations too.
  • Columns could not be resized if row or column headers were hidden in the Table widget.
  • Table columns were unnecessarily resized after a manual adjustment followed by a data update.
WebUI 25.5.1 Release (July 1, 2025).
Improvements
  • The main color palette has been revisited to contain more consistent, less harsh but also less warm shades of blue and grey. This means that many UI-elements show up slightly different. A few elements, like secondary buttons (seen in dialogs), the items in some popup menus and the secondary page actions, have received a more prominent palette change. Note for anyone customizing their apps through custom stylesheets: if you have color values in your styling that are supposed to mimic other, original WebUI colors, and which have been defined as a hex value (#xxyyzz and related) instead of referring to some theming variable, then you will of course see those elements stand out from the others. Please redefine them to use a relevant theming variable (which we can ‘guarantee’ for you) or at least match them up to the new colors. Also see the primitive color constants (in capitals) defined at the :root{} level or the (documented) base theme file.
  • It is now also possible to directly delete widgets from the ‘Page’ tab of the App manager, instead of only from the ‘App’ tab. We also updated the warning message to show the name of the actual widget that you are about to delete.
WebUI 25.4
WebUI 25.4.2 Release (June 20, 2025).
Resolved Issues
  • PageID’s from libraries not located directly under the MainProject folder path (such as in subfolders or relative paths outside of the MainProject) were not recognized by the webui::AllPageIds set.
WebUI 25.4.1 Release (June 13, 2025).
Improvements
  • The List widget has been extended with support for Store Focus and Annotations.
  • The “About AIMMS” flyout, accessible by hovering over the AIMMS icon in the page footer, now displays both the AIMMS version and the WebUI Library version used in the application.
Resolved Issues
  • In WebUI applications with a workflow configured, the home page did not load automatically upon app startup. A manual refresh was required.
WebUI 25.3
WebUI 25.3.6 Release (June 3, 2025).
Resolved Issues
  • As a follow-up up to the related issue in 25.3.5: references to URLs inside CSS files in ASR were not correctly resolved when published on the AIMMS Cloud in case the Application Name contained spaces.
  • With the Pages in Library feature enabled, updating a library’s name and/or prefix previously allowed pages from that library to be moved across other libraries, which could lead to a corrupted webui.json file, leaving the WebUI unresponsive. As we work toward a more robust solution for handling library renames and prefix updates, we have introduced a temporary safeguard: libraries that have had their name or prefix changed will no longer be listed in the WebUI Page Manager when the project starts.
WebUI 25.3.5 Release (May 28, 2025).
Resolved Issues
  • The paths of resources (for example images) in ‘application specific resources’ (ASR), used in Pages in Libraries, would stop working correctly when combined with being deployed on the Cloud, leading to missing or broken interface elements for the functionality in that ASR.
  • Table widgets, that also had widget visibility set to ‘hidden’, were continuously re-rendering in the background. Which is undesirable and can lead to performance issues. Please note that the use of ‘hidden widgets’ is not a recommended practice (and can often be rebuilt in some way using the Tabbed Pages widget), but we understand the feature still has its applications.
WebUI 25.3.4 Release (May 27, 2025).
Resolved Issues
  • The WebUI Table widget could appear empty after scrolling and data updates.
WebUI 25.3.3 Release (May 22, 2025).
Improvements
Resolved Issues
  • Extra space would appear in the ‘Tabbed Pages’ widget when side panels were configured in the main page.
  • In the Tabbed widget, the UponLoad procedure of a tab page was executed twice.
WebUI 25.3.2 Release (May 20, 2025).
Resolved Issues
  • When using a slightly older AIMMS than the latest release, AIMMS would show a fatal application error when used in combination with WebUI 25.3.1.
WebUI 25.3.1 Release (May 20, 2025).
Improvements
  • From now on, it is possible to create WebUI pages that are contained in your AIMMS libraries. This allows for a clearer structure of your big AIMMS/WebUI models and of course greatly enhances the sharing of AIMMS libraries. For all the details, please see the documentation.
  • It is now possible to customize the menu bar of a WebUI app. For details, see the documentation.
  • The Arc Settings in the Map widget have been enhanced with a new “Label” option. This allows you to choose a two-dimensional identifier that defines the labels for the arcs. If this option is not set, the labels will default to displaying data from the “Value” option, as was the previous behavior. When the option is set, the selected data will appear in the arc labels.
  • For applications that have issues and need the App developer’s attention, we now show a warning icon on the page header across the application. Clicking this icon opens a dialog with details about the flaws/issues. Currently, this mechanism is implemented for the Table sorting issue that we addressed in this release.
Resolved Issues
  • When a table was sorted based on one of the columns (column A) and that column would be hidden by an action of the end-user, the table automatically sorted on the column that happened to end up in the position of column A, which obviously was unexpected. Now the sorting is internally based on the actual identifier tuples instead of the column position.
  • When removing an identifier from an old style Table (V1) widget, its slicing information was not removed from the webui.json file. This could lead to unexpected error messages in the WebUI later, if one of the indexes of such an identifier would be deleted in the AIMMS model.
WebUI 25.2
WebUI 25.2.9 Release (May 8, 2025).
Resolved Issues
  • The page enter procedure of a page used for the active tab in a Tabbed widget was executed twice.
  • When the pageId of the currently focused tab was updated to an invalid or empty value, the Tabbed Pages widget did not refresh correctly and the appropriate active tab was not selected.
  • When the pageId of the currently focused tab in a Tabbed widget was updated, the tab content was not immediately applied or rendered.
  • For a limited range of characters, like the (semi)colon, @-signs and some types of brackets, when used in certain combinations with other regular characters, the baseline of these characters appeared ‘raised’, which was undesirable in most cases.
WebUI 25.2.8 Release (April 24, 2025).
Resolved Issues
  • Large AIMMS models that use Item Actions in their WebUI could suffer from a slower performance because of an unnecessary Order By attribute on a predeclared set in the standard WebUI library.
WebUI 25.2.7 Release (April 11, 2025).
Resolved Issues
  • We encountered an issue with the webui::RefreshAllWidgets procedure: the widgets were not updated if the model was very busy doing something else. The behavior of the procedure has been improved to make sure that for every call to this procedure, all WebUI widgets are checked (for data changes) and updated if needed.
  • Applying filters to column, row or identifier headers showed incorrect filter information in the filter dialog when adjacent headers with certain indices were hidden.
  • For Table content that was inserted as html, and where this html was also set up as a table with little other styling, we noticed that the Table’s own default row height was being applied to the html cell content too, making it impossible to get it to fit. We corrected the code that was applying row heights twice or more, but also got rid of ‘generic’ styling to tables in places like these, making sure your html shows up as close as possible to how you probably expect it to show. Please note: you still need to manually set a row height that matches your content, though, or row headers and content will still not align well.
  • There was a timezone-related issue that could result in an error when an app developer accessed the WebUI from a European location.
  • Our recent addition of making the ‘busy spinner’ themable had a side-effect that broke the layout of the progress message and Cancel button within the veil, specifically when a Dialog was open at the same time. The Cancel button is now back to its normal size.
WebUI 25.2.6 Release (March 28, 2025).
Improvements
  • Three new custom CSS properties have been added, such that you can now also have control of the ‘spinner’ image that shows when AIMMS or WebUI is ‘busy’. Please read the additional usage hints in the base-theme file, where we’re keeping track of these possibilities as usual. Look for ‘spinner’ in the Generic Props section.
WebUI 25.2.5 Release (March 28, 2025).
Resolved Issues
  • For customers who have been using ASR/custom CSS to apply borders to the Table widget’s columns, rows or cells: it came to our attention that adding those borders, especially vertical ones, can lead to unexpected layout with borders getting at least partially obscured between the tiles of (larger) tables. Because there was no solution that did not harm the performance of the Table, we have now described the preferred way of working in our Theming documentation. You can still achieve most ‘borders’ you prefer, but you should use a new approach (box shadows) and you might see us actively suppressing (real) borders between tiles. Please read about it, and update your custom CSS if the above applies to you. In the process, a bug in applying colors to table dividers through theming, was also fixed.
  • Although the identifier selector dialog and the ‘Add Widget’ wizard dialog never let you finish without completing the required input, the ‘Finish’ button itself had stopped showing its ‘disabled’ state.
  • The Tabbed widget was unable to load the selected active tab when a webui::ElementText display text was applied to the PageIDs used in the widget data.
  • The recent “End User Widget Controls” feature was unable to control the Contents option editor category for the Tabbed widget type.
WebUI 25.2.4 Release (March 18, 2025).
Resolved Issues
  • Status Bar items now have their corresponding State property applied as a CSS class, such that you can style them as appropriate.
WebUI 25.2.3 Release (March 11, 2025).
Resolved Issues
  • The recently added webui::OptionEditorCategories set was missing the “List Settings” option category entry. This has now been added.
WebUI 25.2.2 Release (March 4, 2025).
Resolved Issues
  • The WebUI 25.2.1 release did not contain the correct minimal AIMMS version. This could lead to crashes when using it in AIMMS versions older than AIMMS 24.6.
  • Using WebUI version 25.2.1, encrypted WebUI applications (among which all WebUI applications that were published on PRO using an aimmspack) stopped working.
WebUI 25.2.1 Release (February 28, 2025).
Improvements
  • As part of our endeavors to improve the UI and UX of WebUI, we’ve replaced our two main font families, Roboto and Montserrat, with Inter Variable. Along with a number of other tweaks that might affect certain setups/layouts in WebUI apps. More details about our motivation, the implications and the steps you might want to take (but which are fully optional), can be found in this topic on the AIMMS Community & Support Forum.
  • The “Limited Option Editor” feature has been upgraded and is now available as an experimental feature called “End User Widget Controls”. When enabled, the existing Limited Options feature will be replaced and a new option, “End User Widget Controls” will appear in the Application Settings. You can now define a Binary parameter indexed over webui::indexOptionEditorCategories (Set webui::OptionEditorCategories), setting it to true for the relevant option editor categories you wish to make available to end users. This update provides App developers with enhanced control, allowing them to restrict or enable specific option editor categories for end users.
WebUI 25.1
WebUI 25.1.2 Release (February 25, 2025).
Resolved Issues
  • The webui::DataChangeMonitorUpdate procedure could issue a warning, caused by recent changes to the FOR statement released in the AIMMS 24.6.8 release.
  • Within Side Panels, the appearance of the Selection Box Widget was cleaned up to be a better match with its surroundings.
WebUI 25.1.1 Release (February 5, 2025).
Improvements
  • We improved the support for copying blocks of data from external sources (like Excel and Google Sheets) into the WebUI table.
  • A “Read Only” option has been added to the “Defaults” section of the Contents tab of the Table V2 options editor. The per-identifier option will inherit its value from this by default, unless overridden.
Resolved Issues
  • We have resolved a warning reported from ‘webui::RefreshAllCases’, caused by recent changes to the FOR statement and released in the AIMMS 24.6.8 release.
WebUI 24.13
WebUI 24.13.7 Release (January 22, 2025 - build 24.13.7.4).
Resolved Issues
  • When setting the browser language to a language with a different thousand/decimal separator scheme than English, it could happen that instead of the correct comma separator, a ‘0’ character would be inserted in numbers in Table cells. So, for example, setting the language to Spanish and typing ‘1000’ would show ‘10000.00’ instead of ‘1,000’.
WebUI 24.13.6 Release (January 15, 2025).
Resolved Issues
  • With the introduction of the support for display-domain identifiers with a different slice specification than the associated contents identifier in the Table widget (in WebUI 24.13.1), it could happen that other widgets that share the same contents option editor as the Table (e.g. the Combination Chart widget) would show incorrect data in case a sliced display-domain identifier had been specified for some contents identifier.
  • We identified an issue where, with the WebUI State Support experimental feature enabled, interacting with multiple tabs in the WebUI caused the session to become unresponsive after being left unattended for a while.
WebUI 24.13.5 Release (December 19, 2024).
Resolved Issues
  • The use of webui::ResetRequestQueue (when called from the model), could in some situations cause a (harmless) message “Cannot change value of read-only identifier ‘RequestQueue’”. This specific message will not be shown anymore.
  • A blank error message was displayed during the Page-Leave-Procedure when the StatusDescription field was left empty upon return.
WebUI 24.13.4 Release (December 12, 2024).
Resolved Issues
  • Having an identifier in a Table that was set up to use the store focus feature based on the indices of this identifier, and changing the identifier to another one with different indices, could yield an incorrect error message “undefined: Unknown identifier”.
WebUI 24.13.3 Release (December 11, 2024).
Resolved Issues
  • The page-upon-leave procedure was not executed when the page contained a Tabbed Pages widget.
  • Applying Table filtering to a Table widget where the row or column headers had an identical display text did not work.
WebUI 24.13.2 Release (December 9, 2024).
Resolved Issues
  • There was a navigation problem in the workflow that occurred when the step state was changed to active and a webui::OpenPage call was executed on the same workflow step from within the same AIMMS procedure.
WebUI 24.13.1 Release (December 4, 2024).
Improvements
  • Some aggregators do not make sense in all scenarios for all identifiers in a widget. For example, summing longitude/latitude values. We now provide a mechanism which gives you the possibility to hide specific aggregators for individual identifiers per widget. For details, see the documentation.
  • We extended the Table widget with the possibility to individually hide any index from the row or column header, including the identifier-set index. This gives you more control about how your table looks, which headers are important in your use case and which are not. For details, see the documentation.
  • The behavior of in-cell icons for some types of Scalar Widget values and the alignment of those values, which we tweaked in release 24.12.7, was revisited. Icons will be visible immediately more often and the values will be right-aligned more often like it was the case before that release.
Resolved Issues
  • With the initial release of Table v2, the indices and any slicing information provided for the Display Domain identifier were ignored, and instead, the slicing information from the content identifier was used.
WebUI 24.12
WebUI 24.12.11 Release (November 28, 2024).
  • The Tabbed Pages widget will now use a different styling when it appears as the only widget in a grid layout, like Layout 9 or 11 (defining one single area). That effectively made it look like a whole page (with a single row of tabs), which works better if the background of the content and the widget styling is ‘normal’ like for a page outside a tabbed page.
  • The Tabbed Pages widget incorrectly kept on using pure white as a background color, even when the custom css property for theming it (–color_bg_widget-canvas) was changed. Related to that same background color: for some widget types it was hard to see where they started or ended (like Scalar widgets with their identifier names, values and dropdowns). A border will now visually keep these together (using –color_border-divider_light).
WebUI 24.12.10 Release (November 22, 2024).
  • Webui::MappedBrowserTimeZone would always remain empty when the user’s browser language was set to a language other than English.
  • The recently introduced per-identifier ‘Read Only’ option in the Table widget did not work when the table was comparing multiple cases (as specified in the Data Manager).
WebUI 24.12.9 Release (November 19, 2024).
  • WebUI widgets could show up incorrectly, in case you would lower the access rights of identifiers that were already being displayed in WebUI (by changing the value of the webui::IdentifierAuthorization identifier; see the documentation).
  • When switching between browser tabs and returning to the original tab, the focus would always be placed on the last Table widget on the page, instead of on the one that had the focus when leaving the tab.
  • If opening an option editor when a Table cell was selected (i.e. outlined in blue), the cell remained selected and when selecting a cell in another Table, you ended up with both cells having the focus.
WebUI 24.12.8 Release (November 13, 2024).
  • Changing the page layout to “Classic Layout” did not immediately update the page and its widgets to reflect the classic layout style. Also, for app developers using many pages with “Grid Layout”, the area names and boundaries no longer disappear when using the page navigator to navigate between different grid layout pages.
  • In special cases, especially in tables when clicking in cells that contain long (string) values, table cells could be wrongly aligned (or even not visible at all).
  • When trying to upload a file of over 128 MB in size (the maximum allowed) with the webui::RequestFileUpload function, AIMMS hung and you did not get an error message.
WebUI 24.12.7 Release (November 8, 2024).
  • The dropdown and ‘set to default’ icon for relevant table cells and scalar input fields used to be very small and equally hard to operate with the mouse. Together with the date/time picker icon, these are now shown (when hovering those cells) in a more pleasing way, with better clues as to their interactivity.
WebUI 24.12.6 Release (November 7, 2024).
  • The Tabbed Widget content would also refresh when non-mandatory properties, such as “displayText”, “tooltip”, “icon” or “iconColor” were modified for hidden tabs only.
WebUI 24.12.5 Release (November 5, 2024).
  • The current tab in the Tabbed Widget was not updated when both the tabs specification data and the current tab value were changed in the same AIMMS procedure.
  • A webui::ShowMessage call from the AIMMS model will now always trigger a toast notification: both in developer mode and in the cloud, for any message level (including ‘info’).
WebUI 24.12.4 Release (October 28, 2024).
  • We recently introduced a new per-identifier, ‘Read Only’ option in the Table widget. This option did not work for identifiers that were inside some module or library namespace.
WebUI 24.12.3 Release (October 24, 2024).
  • In recent versions, HTML content was not always shown as intended in tooltips.
  • Sorting a row or column in a Table widget could go wrong if the row or column to be sorted contained some cells that were filtered out because of an associated display domain identifier.
Resolved Issues
WebUI 24.12.2 Release (October 23, 2024).
Resolved Issues
  • In rare situations, changing a value in a table with both row and column headers hidden could lead to the table being ‘locked’. Editing or scrolling was not possible anymore without refreshing the WebUI page first.
  • The webui::proint::casefilesave procedure sometimes did not save defined parameters into a case.
  • In the WebUI combination chart the element text of a set element was used to differentiate the groups (of bars). In the case two set elements had identical element text, they would be part of the same stack, even if the associated index was in the ‘grouped’ part. This behavior of the combination chart has been improved by using the element name (i.e. the label) instead (which is guaranteed to be unique within the set).
  • Sometimes when navigating to a Workflow step that had an UponLoad procedure which both updated the workflow information and triggered a dialog, users faced a “Page Navigation Disabled” error message.
WebUI 24.12.1 Release (October 15, 2024).
Improvements
  • We introduced the ‘Read Only’ option to the Table widget. With this new option, you can display identifiers in read-only mode, which can be useful if you just want to display your data in a dashboard-like page, for example.
  • It is now allowed to specify an element parameter as the webui::AnnotationsIdentifier. This can be used to highlight suspicious input data which might be causing a mathematical model to become infeasible. (The AIMMS feature to find the suspicious input data will be released at the end of 2024.)
WebUI 24.11
WebUI 24.11.2 Release (October 3, 2024).
Resolved Issues
  • When using a DateTimePicker that should only select a month and a year (and no day), the WebUI would give an error.
WebUI 24.11.1 Release (October 2, 2024).
Improvements
  • We added an updated version of the Table widget as an Experimental Feature (called ‘Table V2’). In this Widget, we modernized some option tabs, allowing you to specify options like decimal places and the showing of units for each identifier displayed, instead of for the complete table. For more details, see the documentation.
  • We promoted the following previously experimental features to generally available status: Widget Named Views, the Tabbed Widget and the Diagram Widget.
  • The Text widget has been upgraded with enhanced rich text editor controls, offering improved formatting capabilities.
  • You can now use webui::IdentifierElementText to apply translations to the identifier name displayed on the Slider widget.
Resolved Issues
  • Selecting multiple scattered boolean cells in a Table widget and using Ctrl+Space now toggles the values as described in the documentation.
  • In the Combination Chart, tooltips were already displayed by hovering the blank space in the widget. If you were using large tooltips, this could block the view of the actual chart. Now the tooltips are only displayed when hovering over the points or lines of the chart.
  • Navigating between tabs within a Tabbed Widget was incorrectly updating the webui::CurrentPageId with the page of the current tab, instead of the current page on which the Tabbed Widget resides.
WebUI 24.10
WebUI 24.10.3 Release (September 12, 2024).
Resolved Issues
  • When clicking the ‘preview end-user mode’ button on the WebUI (introduced in WebUI 24.9.1), sometimes a ‘Page not found’ message was displayed instead of showing the preview.
WebUI 24.10.2 Release (August 28, 2024).
Resolved Issues
  • In the Diagram and Map widgets, you can now use sliced identifiers to specify the Center X, Center Y, and Zoom options.
  • The procedure webui::RequestShowNotification can now be called in combination with a call to webui::RequestsPerformWebUIDialog. The OS notification and the WebUI dialog will appear simultaneously to make sure that the user will be notified, even in case the browser is minimized or another browser tab (other than the WebUI) has focus.
WebUI 24.10.1 Release (August 23, 2024).
Improvements
  • To improve performance (especially for cloud applications), the webui::LoadCase procedure will skip the file system scan for all available case files and assume that the list of available cases is not changed.
  • The AIMMS WebUI library has been extended with a webui::ShowMessage procedure. This procedure takes two arguments (the first being the ‘level’ and the second being the message to be displayed) and will show a message to the user in WebUI (i.e. in the browser). For the levels ‘warning’ and ‘error’ a call to the webui::ShowMessage procedure will behave the same as the execution of a raise warning or raise error command from the model. In addition, the ‘info’ level can now be used to send an informational message to the WebUI user (which was not possible in combination with a raise command in the language).
  • In the WebUI table widget, the store focus will now work bidirectional. In case all indices have a store focus element parameter and in case the value of one or more of these store-focus element parameters is changed, the focus cell in the table will be updated accordingly.
Resolved Issues
  • On the Diagram widget, the restriction on reusing the same identifier with different slicing options in the Node Template fields has been removed.
WebUI 24.9
WebUI 24.9.2 Release (August 8, 2024).
Resolved Issues
  • HTML text in Table header cells would show the raw HTML code instead of the resulting HTML if the header content was dynamically updated.
  • The WebUI now offers translation support for the following words/phrases that are used on the Multi-Select widget: Select All, Deselect All, Select, Deselect, Search and Use search box for more results.
  • When switching your network while in a WebUI app on PRO, the app will now remain on the same page instead of redirecting you to the home page of the portal.
WebUI 24.9.1 Release (July 22, 2024).
Improvements
  • We have introduced a new widget type, called “Iframe Widget”. This widget makes it possible to embed external content, such as reports and other web pages, directly into your AIMMS WebUI application. For details about this widget, please see the documentation.
  • We have introduced a new “End-User Mode Preview” button in the page header section. Clicking this button opens the current WebUI page in a new tab, displaying it from the perspective of the end users. This feature provides a quick and easy way to preview how your end users will experience the WebUI.
  • The AIMMS WebUI library has been enhanced with a new webui::RequestShowNotification(message, title) procedure. This feature allows the WebUI to trigger operating system notifications directly from the browser window in which it is running. An example use case is, you can call this procedure after a solve action in an AIMMS procedure to notify the user that the optimization has been completed. See the documentation for more details.
WebUI 24.8
WebUI 24.8.1 Release (July 17, 2024).
Improvements
  • The Diagram Widget now uses the domain condition of the arcs identifier in the following way: in case a connection between two nodes is not in the index domain, the target node will not show any target feedback (i.e. a blue rectangle). And, in case a certain node cannot have any outgoing connection, it will not be possible to create a new arc starting from that specific node in the first place.
Resolved Issues
  • The Table Widget will now restrict mouse wheel scrolling to within the bounds of the data, preventing scrolling beyond the start or end of the table. This should help with the confusion when using Tables in small grid areas, where you are expecting the data to fit perfectly.
WebUI 24.7
WebUI 24.7.4 Release (July 3, 2024).
(Due to internal technical reasons, we skipped the WebUI 24.7.3 Release).
Resolved Issues
  • Changing the updateability of identifiers in a WebUI widget by adding them to (or removing them from) the set CurrentInputs did not work correctly in widgets that contained more than one identifier for which the updateability had changed.
WebUI 24.7.2 Release (June 25, 2024).
Resolved Issues
  • When uploading a large file using webui::RequestFileUpload, a veil is now displayed to indicate that AIMMS is busy. An appropriate message is also displayed.
  • Previously, in the MultiSelect widget, custom annotations, if configured, were listed under the data-annotations DOM attribute of the elements. To maintain consistency across the WebUI, starting with this WebUI 24.7.2 release, custom annotations will now be loaded under the class DOM attribute of the elements in the MultiSelect.
WebUI 24.7.1 Release (June 20, 2024).
Improvements
  • We have created a new widget type, called ‘Tabbed Widget’. This widget makes it possible to show multiple pages inside a single widget, as separate tabs. This can serve as a much cleaner solution than using hidden widgets on a page, as it basically allows you to show anything you need within the same space on a WebUI page, depending on the context. For full details, please see the documentation. The Tabbed widget is available as an Experimental Feature, and it is enabled by default.
  • The Table widget now also supports item actions when clicking in the row or column header of the table. See the documentation for more details.
WebUI 24.6
WebUI 24.6.2 Release (June 18, 2024).
Resolved Issues
  • The Label widget now officially supports HTML content. As a security precaution, any content enclosed within script tags are ignored.
  • When selecting an Element Parameter as an input for Store-Focus options on a Combination Chart widget, it was not possible to select an Element Parameter that is ranged over a Super-Set for the given index.
  • There was a superfluous warning about an uninitialized local string parameter webui::LocalFileNames after creating a new project.
  • Previously, clicking on the labels in Table header cells caused the menu indicator to stay fixed to the cells. Now the chevron appears when you hover over the cells, and the context menu can be accessed by either double-clicking the labels in the header cells or by clicking on the menu indicator.
WebUI 24.6.1 Release (May 24, 2024).
Improvements
  • The store focus mechanism has been extended, such that it does not only work when giving cells the focus, but also when clicking on row or column header cells. In that case, only the element parameters of the indices present in the clicked row or column header cell will be updated.
  • The Table widget now allows copying content from a single cell and pasting it onto a block of cells or multiple scattered cells.
  • Now the widget menu button provides the CSS class name ‘has-widget-actions’ when widget actions are available for a widget.
Resolved Issues
  • The Table Filtering dialog displayed the ‘raw’ identifier names, instead of the translated identifier names using ElementTextIdentifier annotations.
WebUI 24.5
WebUI 24.5.2 Release (May 16, 2024).
Resolved Issues
  • When using Primary Page Actions on a page, and when configuring a label for the button, that label would prevent you from interacting with anything in an even wider area around it, also when not hovering the button itself and the label was still invisible. Now, only the button itself will be ‘always on top’.
WebUI 24.5.1 Release (May 15, 2024).
Improvements
  • The design of and the interaction with the Diagram Widget has been improved to provide better and more consistent feedback while displaying, managing and selecting the nodes, labels and connecting lines.
  • The WebUI library now incorporates information about the customer’s browser language. App developers can leverage this information to deliver language-specific content on the UI. For details, please see the documentation.
  • You can utilize index domain conditions to limit arcs being added from or to specific node types in the Diagram Widget. Previously, when such an arc was added, it remained on the diagram until further interaction. Such arcs are promptly removed from the UI.
Resolved Issues
  • In the previous version, an error was encountered when users clicked on aggregator cells in the table with Store-Focus settings configured. Now, clicking on aggregator cells will effectively clear the store-focus entry from the respective index.
  • We have revised the message displayed on the Combination chart in instances where the chart fails to load all data points.
  • When using the “Upload “.xlsx” action from the Table widget menu in combination with a file format different from .xlsx and.xls, AIMMS would crash. Now only these file formats are enforced.
WebUI 24.4
WebUI 24.4.1 Release (April 25, 2024).
Improvements
  • If an option in the options editor is derived from a Template, this is now indicated properly with a ‘t’ icon next to it.
  • It is now also possible to use Table filtering on Table widgets that are displayed on a Dialog page.
  • We extended the recently introduced WebUI feature that allows you to show ‘raw’ html in a table cell in WebUI (the documentation) to the filtering. In case a certain cell is shown as html, the text filters (e.g. ‘contains’, ‘starts with’) will exclude any text that is within an html tag. For example, if a certain cell that is shown as html contains the value <span class=”author”>Hemingway</span>, the cell will not match when specifying a ‘contains’ filter with search string “author”. In other words, it will only search in the actual displayed text that is a part of the html fragment.
