Widget Header Bar¶
All Widgets have a header bar, consisting of several options and the widget title.
Title, Full Screen, and Settings¶
Some of the options are specific to certain widgets but almost all widgets have Title, Full Screen and Settings options
The Title for the widget can be specified in the Title
option under the Miscellaneous section of the Widget Options.
The icon expands the respective to a full-screen mode. Clicking on the icon again returns the widget to the original size.
The icon represents the Widget Options where you can specify contents, pivoting, and other options for the widget.
Below are some of the other icons you will see in the Widget Header if they are configured.
Download Image - PNG
Download Image - PNG is available starting from the AIMMS software version 4.79 onwards as part of Experimental Features. Please visit the Experimental Features page on how to enable the feature.
This option allows users to save a snapshot of the widget to their disk.
Download Image is available for Table, Bar Chart, Line Chart, Bar-Line Chart, Gantt Chart, Bubble Chart, Pie Chart, TreeMap, and also for the Full Page.
In order to save an image for the full page which is currently active you neeed to click the in the Application Menu Bar.
When downloading the image, the widget title is taken as the filename. In the case that no title is specified for the widget, then the filename is the chart type (eg. barchart.png).
This option is also available when the widget is toggled to the full-screen mode.
When downloading the image for a Table only the viewable area is saved and not the entire table.
The Gantt Chart does not support the scrollable area when downloading the image.
For both these cases you can try expanding the widget to full-screen mode first and then download the image.
Download CSV
You can save the table data to a .csv
file by using the Download Table Data functionality.
This option is available only for the Table widget.
Widget Actions
When Widget Actions are specified for the widget the icon is displayed so the user can access the actions.
Widget Actions can be configured for the Table, Bar Chart, Line Chart, Gantt Chart, Bubble Chart, Pie Chart, Tree Map, Multiselect, Slider, Legend, Map and Scalar (except in Compact Mode) widgets.
Filtering
When a user applies Data Filtering on the Table, the icon is displayed in the header of that respective table widget.
