Managing Generated Mathematical Program Instances
Managing math program instances
The procedures and functions of the GMP::Instance namespace are
listed in this table and take care of the creation and
management of generated mathematical program instances. Mathematical
program instances also provide access to the solution repository and
solver sessions associated with the instance.
Creation of mathematical program instances
New mathematical program instances can be created by calling
the
SOLVEstatement,the
GMP::Instance::Generatefunction,the
GMP::Instance::GenerateRobustCounterpartfunction,the
GMP::Instance::GenerateStochasticProgramfunction,the
GMP::Instance::Copyfunction,the
GMP::Instance::CreateBlockMatricesfunction,the
GMP::Instance::CreateDualfunction,the
GMP::Instance::CreateFeasibilityfunction,the
GMP::Instance::CreatePresolvedfunction, orthe
GMP::Instance::CreateMasterMIPfunction.
All mathematical program instances created through each of these calls,
are uniquely represented by elements in the predefined set
AllGeneratedMathematicalPrograms. For the functions in the
GMP::Instance namespace creating GMPs you can explicitly specify the
name of the associated set element to be created. When calling the
SOLVE statement, AIMMS will generate an element with the same name
as the MathematicalProgram at hand. When the name of the element to
be created is already contained in the set
AllGeneratedMathematicalPrograms, the mathematical program instance
associated with the existing element will be completely replaced by the
newly created mathematical program instance.
Special math programming types
Stochastic programming and the use of the function
GenerateStochasticProgram is discussed in Solving Stochastic Models.
Robust optimization and the use of the function
GenerateRobustCounterpart is explained in Solving Robust Optimization Models.
The functionality of the CreateDual function is explained in more
detail in Dealing with Degeneracy and Non-Uniqueness. The function CreateMasterMIP
is used by the AIMMS Outer Approximation solver, which is discussed in
full detail in AIMMS Outer Approximation Algorithm for MINLP. Presolving of mathematical programs is
discussed in The AIMMS Presolver.
Deleting and renaming instances
Through the procedures GMP::Instance::Delete and
GMP::Instance::Rename you can delete and rename mathematical program
instances and their associated elements in the set
AllGeneratedMathematicalPrograms. If you rename a mathematical
program instance to a name that already exists in the set
AllGeneratedMathematicalPrograms, the associated mathematical
program instance will be deleted prior to renaming.
CLEANDEPENDENTS statement
Note that also the CLEANDEPENDENTS statement may remove mathematical
program instances from memory when it affects any constraint or variable
referenced by that instance.
Retrieving and setting basic properties
Through the functions
you can retrieve the current value of some basic properties of a mathematical program instance. The number of rows, columns and nonzeros can be changed by manipulating the matrix of the mathematical program instance (see also Matrix Manipulation Procedures). You can use the functions
to modify the optimization direction and mathematical programming type.
The type of a mathematical program must be a member of the set
MathematicalProgrammingTypes (see also MathematicalProgram Declaration and Attributes) The
direction associated with a mathematical program is either
'maximize','minimize', or'none'.
The direction 'none' is the instruction to the solver to find a
feasible solution.
Installing callbacks
For each mathematical program instance, you can set up to six callback functions that will be called by any solver session associated with the mathematical program instance at hand. Through the following procedures you can install or uninstall a callback function for a mathematical program instance.
Each of these procedures expects an element of the set
AllProcedures, or an empty element " to uninstall the callback.
Callback procedures
Callback procedures for each type of callback should be declared as follows:
AnExampleCallback(solverSession)
where the solverSession argument should be a scalar input element
parameter into the set AllSolverSessions. Callback procedures should
have a return value of
0, if you want the solver session to stop, or
1, if you want the solver session to continue.
As discussed before, each solver session can be uniquely associated with
a single mathematical program instance. You can find this instance by
calling the function GMP::SolverSession::GetInstance (see also
Using Solver Sessions), and, within the callback procedure, use this
instance to get access to its associated properties.
Example
The following example implements a callback procedure for the incumbent callback. The callback procedure finds the associated mathematical program instance, and stores all incumbents reported by the solver into the next solution of the solution repository.
Procedure IncumbentCallBack {
Arguments : solvSess;
Body : {
theGMP := GMP::SolverSession::GetInstance( solvSess );
GMP::Solution::RetrieveFromSolverSession( solvSess, solutionNumber(theGMP) );
solutionNumber(theGMP) += 1;
return 1; ! continue solving
Note that the callback procedure uses the
GMP::Solution::RetrieveFromSolverSession function (discussed in
Managing the Solution Repository) to retrieve the solution from the solver.
Solving mathematical program instances
In contrast to the SOLVE statement, the philosophy behind the GMP
library is to break down the optimization functionality in AIMMS to a
level which offers optimum support for implementing advanced algorithms
around a MathematicalProgram in your model. One of the consequences
of this philosophy is that the solution is never directly transferred
between the symbolic variables and constraints and the solver, but is
intermediately stored in a solution repository. Therefore, solving a
MathematicalProgram using the GMP library breaks down into the
following basic steps:
generate a mathematical program instance for the
MathematicalProgram,create a solver session for the mathematical program instance,
transfer the initial point from the model to the solution repository,
transfer the initial point from the solution repository to the solver session,
let the solver session solve the problem,
transfer the final solution from the solver session to the solution repository, and
transfer the final solution from the solution repository to the model.
Solving the instance directly
For your convenience, however, the GMP library contains a procedure
which, given a generated mathematical program instance, takes care of
all intermediate steps (i.e. steps 2-7) necessary to solve the
mathematical program instance. In case you need access to the solution
in the solution repository after calling the GMP::Instance::Solve
call, you should notice that the GMP::Instance::Solve procedure (as
well as the SOLVE statement) performs all of its solution transfer
through the fixed solution number 1 in the solution repository.
Emulating the SOLVE statement
The following AIMMS code provides an emulation of the SOLVE
statement in terms of GMP::Instance functions.
! Generate an instance of the mathematical program MPid and add
! the element 'MPid' to the set AllGeneratedMathematicalPrograms.
! This element is returned into the element parameter genGMP.
genGMP := GMP::Instance::Generate(MPid, FormatString("%e", MPid));
! Actually solve the problem using the solve procedure for an
! instance (which communicates through solution number 1).
GMP::Instance::Solve(genGMP);
Solving with a round-and-repair heuristic
For MIP and MIQP models, the procedure
solves a mathematical program instance like GMP::Instance::Solve,
but uses a round-and-repair heuristic to find good integer solutions
faster. During the solve, it repeatedly rounds the binary variables of a
fractional solution, uses the rounded values to construct an integer
solution by solving two auxiliary MIPs, and passes that solution to the
solver as a heuristic solution. The procedure interrupts the solve and
continues it later, and can therefore only be used with a solver that
supports continued solves, i.e., CPLEX or Gurobi.
Multistart support
The function FindApproximatelyFeasibleSolution is used by the AIMMS
multistart algorithm (see The AIMMS Multistart Algorithm) to compute an
approximately feasible solution for an NLP problem. The algorithm used
by this function to find the approximately feasible solution is
described in [Chi04].
Creating solver sessions
For each generated mathematical program instance, you can explicitly create and delete one or more solver sessions using the following functions:
Once created, you can use the solver session to solve the generated mathematical program
in a blocking manner by calling the
GMP::SolverSession::Executefunction, orin a non-blocking manner by calling the
GMP::SolverSession::AsynchronousExecutefunction.
Prior to calling the GMP::SolverSession::Execute or
GMP::SolverSession::AsynchronousExecute functions, you should call
the function GMP::Solution::SendToSolverSession to initialize the
solver session with a solution stored in the solution repository. Using
an explicit solver session allows you, for instance, to solve an NLP
problem with several initial solutions stored in the solution
repository.
Multiple sessions allowed
AIMMS allows you to create multiple solver sessions per mathematical
program instance, and solve them in parallel. You can solve multiple
mathematical program instances in parallel, by calling the function
GMP::SolverSession::AsynchronousExecute multiple times. The function
starts a separate thread of execution to solve the math program instance
asynchronously, and returns immediately. To solve multiple mathematical
program instances in parallel, your computer should have multiple
processors or a multi-core processor.
Deleting solver sessions
Once the function GMP::SolverSession::Execute or
GMP::SolverSession::AsynchronousExecute has been called, the
internal solver representation of the mathematical program instance will
be created. The solver representation will only be deleted-and its
associated resources freed-when the corresponding solver session has
been deleted by calling the procedure GMP::SolverSession::Delete.
Implementing the procedure GMP::Instance:: Solve
The GMP:Instance::Solve procedure discussed previously can be
emulated using solver sessions, as illustrated in the equivalent code
below.
! Create a solver session for genMP, which will create an element
! in the set AllSolverSessions, and assign the newly created element
! to the element parameter session.
session := GMP::Instance::CreateSolverSession(genMP);
! Copy the initial solution from the variables in AIMMS to
! solution number 1 of the generated mathematical program.
GMP::Solution::RetrieveFromModel(genMP,1);
! Send the solution stored in solution 1 to the solver session
GMP::Solution::SendToSolverSession(session, 1);
! Call the solver session to actually solve the problem.
GMP::SolverSession::Execute(session);
! Copy the solution from the solver session into solution 1.
GMP::Solution::RetrieveFromSolverSession(session, 1);
! Store this solution in the AIMMS variables and constraints.
GMP::Solution::SendToModel(genMP, 1);
Setting default solver session limits
You can use the following procedures to set various default limits that
apply to all solver sessions created through
GMP::Instance::CreateSolverSession.
Setting GMP-specific options
For every GMP you can override the default project options using the
function GMP::Instance::SetOptionValue. You can also set options for
a specific solver session associated with a GMP through the function
GMP::SolverSession::SetOptionValue. In turn, option values set for a
specific solver session override the option values for the associated
GMP.
Setting the default solver
Similarly, you can get and set the default solver that will be used by
Outer approximation support
the GMP library offers support for solving mixed integer nonlinear (MINLP) problems using a white box outer approximation approach. The AIMMS Outer Approximation solver is discussed in full detail in AIMMS Outer Approximation Algorithm for MINLP.
Re-optimizing with limited impact on the solution
Imagine you have created a production plan based on optimizing some mathematical program and that something unexpected happened that (partly) ruined the plan. You now have to re-optimize the mathematical program, with some changes, but would like the solution of the new optimization to be close to the previous one. For that you can use the procedure
which adds a constraint that limits the number of binary decision variables of which the solution value is allowed to change. This constraint can be removed using the procedure
Background
When solving a mathematical program, some practical difficulties may arise when the optimal solution of the underlying model is either degenerate and/or not unique (i.e. there are multiple optimal solutions). These difficulties may concern both the primal and dual solution (i.e. the shadow prices).
Problems with degeneracy
In the case of degeneracy (see also Section 4.2 of the AIMMS Modeling Guide for an explanation), the solution status of one or more variables is “basic at bound”. In the presence of degeneracy, shadow prices are no longer unique, and their interpretation is therefore ambiguous. As a result, if the shadow prices have an economic interpretation in the application, the particular shadow prices found by the solver cannot be presented to the end-user in a meaningful and reliable fashion.
Problems with multiple solutions
In the case of multiple solutions, the situation is even worse. There are multiple optimal bases, and the associated shadow prices differ between these bases (just as with degeneracy). In addition, the solution presented to the end-user is no longer unique, which may raise questions by the end-user as to why a particular solution is presented.
Degeneracy and multiple solutions
Both degeneracy and multiple solutions can occur at the same time, having their combined effect on the non-uniqueness of both the primal and the dual solution (the optimal shadow prices). The following two paragraphs present possible solutions to deal with multiple primal and dual solutions.
Towards a unique primal solution
One way to deal with multiple solutions is to find a new and second objective function specifically designed to deal with eliminating the multiplicity of solutions. This might be accomplished, for instance, by adding new sets of variables and constraints to cap some aspect of the primal model, and the maximum cap could then be minimized. Or perhaps a straightforward modification of the original objective function could become the second auxiliary objective. It is important to note that this second objective function is optimized only after the first objective function is fixed at its previous optimal value and has been added as a constraint.
Implementing primal uniqueness
Using the functionality provided by the GMP library, constructing a second objective function for a mathematical program is a straightforward task:
generate and solve the original mathematical program,
use the matrix manipulations procedures discussed in Matrix Manipulation Procedures to create a new objective and fix the original one in the associated mathematical program instance,
resolve the modified mathematical program instance.
Towards a unique dual solution
In the presence of primal degeneracy and/or multiple primal solutions, it is impossible to influence the selection of shadow prices, as this decision is made by the solver. To give the control back to you as a model developer, the only sensible step is to go directly to the dual formulation, and work with the model expressed in terms of shadow prices. It is then possible to construct a second auxiliary objective function designed to produce economically meaningful shadow prices. Again, it is important to note that this second objective function is optimized only after the original objective function is fixed at the optimal objective function value of the primal model, and has been added as a constraint.
Creating a dual mathematical program instance
To support the procedure for reaching dual uniqueness, the GMP library contains the function
which creates the dual mathematical program instance associated with a given primal mathematical program instance.
Standard dual formulation
For a mathematical program of the form
the dual mathematical program can be formulated as follows
where the \(\lambda_j\) represent the shadow prices of the constraints of the primal formulation.
Sign changes
If the primal formulation contains nonpositive or free variables, or contains \(\leq\) or equality constraints, a number of simple substitution will bring the formulation back into the standard form above, after which the above dual formulation can be used directly. The resulting changes to the dual formulation are as follows:
a nonpositive variable \(x_i\) corresponds to a dual \(\geq\) constraint,
a free variable \(x_i\) corresponds to a dual equality constraint,
a \(\leq\) constraint corresponds to a nonpositive dual variable \(\lambda_j\), and
an equality constraint corresponds to a free dual variable \(\lambda_j\).
Bounded variables and ranged constraints
However, such simple transformation are not possible anymore if the primal model contains:
bounded variables, i.e. \(l_i \leq x_i \leq u_i\), or
ranged constraints, i.e. \(d_i \leq \sum_i A_{ij}x_i \leq b_j\).
In these cases, additional constraints (implicitly) have to be added as follows to satisfy the above standard formulation:
\(x_i \geq l_i\) whenever \(l_i \neq 0,-\infty\),
\(x_i \leq u_i\) whenever \(u_i \neq 0, \infty\), and
\(\sum_i A_{ij}x_i \geq d_j\).
In the generated dual mathematical program, such implicit constraint additions in the primal formulation will lead to the explicit introduction of additional variables in the dual formulation. Such variable additions to the dual formulation are taken care of by AIMMS automatically, but will have consequences when you want to manipulate the matrix of the dual mathematical program instance, as discussed in Modifying an Extended Math Program Instance.
Implementing dual uniqueness
Using the function GMP::Instance::CreateDual, it is relatively
straightforward to implement the procedure outlined above to reach dual
uniqueness:
generate a dual mathematical program instance from the primal mathematical program instance,
use the matrix manipulations procedures discussed in Matrix Manipulation Procedures to create a new dual objective and fix the original dual objective in the newly created dual mathematical program instance,
solve the modified dual mathematical program instance.
Explainability
Determining data causing infeasibility
A particular situation which requires explainability is when the mathematical optimization model is formulated correctly, but it becomes infeasible due to incorrect input data provided by the user. So, in this case the infeasibility is not inherent to the model formulation and it is not found as a modeling error during the model development phase, but rather during the model deployment phase due to some incorrect data instance which turns the model infeasible.
Business applications including optimization should also consider infeasibilities and include support for dealing with the infeasibility in this situation. More specifically, some valuable information about the cause of the infeasibility should be returned to the end user in a form which she/he can understand and use for correcting the input data in order to make the model feasible again.
This goal can be achieved by calling the procedure GMP::Instance::GetInfeasibleData. Under the assumption that an LP/MILP model is correctly formulated, this function performs in essence the following tasks:
Calculate IIS or solve Feasibility Problem
Remove constraints without changeable parameters
Pinpoint the changeable parameters used in the constraints
After performing these steps, the function returns a message (as output argument) and fills the parameter suffix called .SuspicionLevel with one of the possible values: High, Normal, or Low.
The output message may be displayed in a suitable way into the graphical user interface in order to inform the user in a concise manner about the most likely cause of the infeasibility.
In turn, the values of the .SuspicionLevel parameter suffixes may be used to assign identifier annotations to the parameters of interest. Such annotations may be subsequently used in order to highlight
the suspicious values of those parameters in the graphical user interface and visually notify the user about potentially incorrect data values. For example, when such values are rendered in a table,
the cells of the suspicious values may be coloured in light pink, pink, or red, based on the suspicion levels Low, Normal, or High, respectively.
After adjusting the most critical values highlighted in the graphical user interface to more realistic numbers, the user may re-solve the model and observe the effect. If the model turns feasible, then the issue
has been resolved/explained. If the model still stays infeasible, then a new call to the procedure GMP::Instance::GetInfeasibleData may reveal additional information about potentially incorrect data
and the process may be repeated in a similar way until the model becomes feasible again. It could happen that a few iterations are required in order to fully explain the cause of the infeasibility and to
resolve the issue with the incorrect user data completely.
