Matrix Manipulation Procedures
Matrix manipulation
The matrix manipulation procedures in the GMP library allow you to
implement efficient algorithms for generated mathematical program
instances which require only slight modifications of the matrix
associated with the mathematical program instance during successive
runs. These procedures operate directly on the coefficient matrix
underlying the mathematical program, and thus avoid the
constraint-generation process normally initiated by the SOLVE
statement after input data has been modified.
This section
Prior to discussing the individual matrix manipulation procedures, the following section will provide some motivation when and when not to use matrix manipulation.
When to Use Matrix Manipulation
When to use matrix manipulation
Even though AIMMS offers a library of matrix manipulation procedures, you should not use them blindly. As explained below, it is important to distinguish between manual and automatic input data changes inside an AIMMS application. Your decision whether or not to use the matrix manipulation procedures described in this section, should depend on this distinction.
Manual data input …
Consider an end-user of an AIMMS application who, after having looked at the results of a mathematical program, wants to make changes in the input data and then look again at the new solution of the mathematical program. The effect of the data changes on the input to the solver cannot be predicted in advance. Even a single data change could lead to multiple changes in the input to the solver, and could also cause a change in the number of constraints and variables inside the particular mathematical program.
…requires structure recognition
As a result, AIMMS has to determine whether or not the structure of the underlying mathematical program has changed. Only then can AIMMS decide whether the value of existing coefficients can be overwritten, or whether a new and structurally different data set has to be provided to the solver. This structure recognition step is time consuming, and cannot be avoided in the absence of any further information concerning the changes in input data.
Automatic data input …
Whenever input data are changed inside an AIMMS procedure, their effect
on the input to the solver can usually be determined in advance. This
effect may be nontrivial, in which case it is not worth the effort to
establish the consequences. Rather, letting AIMMS perform the required
structure recognition step through the regular SOLVE statement
before passing new information to the solver seems to be a better
remedy. There are several instances, however, in which the effect of
data changes on the solver input data is easy to determine.
…may reflect particular structure
Consider, for instance, automatic data changes that have a one-to-one
correspondence with values in the underlying mathematical program. In
these instances, the incidence of variables in constraints is not
modified, and only the replacement values of some coefficients need to
be supplied to the particular solver. Other examples include automatic
data changes that could create new values for particular
variable-constraint combinations, or that could even cause new
constraints or variables to be added to the input of the solver. In all
these instances, the exact effects on the input of the solver can easily
be determined in advance, and there is no need to let AIMMS perform of
the computationally intensive structure recognition step of the
SOLVE statement before passing new information to the solver.
Restrictions on usage
The above effects of data input modifications on the input to the solver are straightforward to implement with linear and quadratic mathematical programs, because the underlying data structures are matrices with rows, columns and nonzero elements. The input data structures for nonlinear mathematical programs are essentially nonlinear expressions. Modifications of the type discussed in the previous paragraph are not easily passed onto these nonlinear data structures. For this reason, the efficient updating of solver input has been confined to
linear and quadratic constraints, and
coefficients of nonlinear constraints with respect to variables that only occur linearly in that constraint.
Regeneration of nonlinear constraints
Whenever the input data of a nonlinear expression in a nonlinear constraint has changed, it is not possible anymore to change the nonlinear expression used by the solver directly to reflect the data change. You can still request AIMMS to regenerate the entire row, which will then use the updated inputs. You should note, however, that any modifications to the linear part of the regenerated constraint are lost after the constraint has been regenerated.
Scalar arguments only
Most GMP modification procedures have scalar-valued arguments. The row argument should always be
a scalar reference to an existing constraint name in your model, or
a row number which is an integer in the range \(\{ 0 .. m-1 \}\) whereby \(m\) is the number of rows.
The column argument should always be
a scalar reference to an existing variable name in your model, or
a column number which is an integer in the range \(\{ 0 .. n-1 \}\) whereby \(n\) is the number of columns.
Modifying a group of columns or rows
For most matrix procedures in the GMP::Coefficient, GMP::Row and GMP::Column namespaces, that can be
used to modify a generated mathematical program, there also exists a multi variant which can be
applied to a group of columns of rows, belonging to one variable or constraint respectively. These
procedures are listed in More Efficient Modification Procedures.
Mathematical program instance required
Before you can apply any of the GMP modification procedures, you must
first create a mathematical program instance using any of the functions
for this purpose discussed in Managing Generated Mathematical Program Instances. Either of these
methods will set up the initial row-column matrix required by the matrix
manipulation procedures. Also, any row or column referenced in the
matrix manipulation procedures must either have been generated during
the initial generation step, or must have been generated later on by a
call to the procedures GMP::Row::Add, or GMP::Column::Add,
respectively.
Coefficient Modification Procedures
Coefficient modification procedures
The procedures and functions of the GMP::Coefficient namespace are
listed in the table below and take care of the
modification of coefficients in the matrix and objective of a generated
mathematical program instance.
Modifying coefficients
You can instruct AIMMS to modify any particular coefficient in a matrix
by specifying the corresponding row and column (in AIMMS notation),
together with the new value of that coefficient, as arguments of the
procedure GMP::Coefficient::Set. This procedure can also be used
when a value for the coefficient does not exist prior to calling the
procedure.
Quadratic coefficients
For quadratic mathematical programs, you can modify the quadratic
objective coefficients by applying the function
GMP::Coefficient::SetQuadratic to the objective row. For every two
columns \(x_1\) and \(x_2\) you can specify the modified
coefficient \(c_{12}\) if \(c_{12}x_1x_2\) is to be part of the
quadratic objective.
Quadratic Coefficient Modification Procedures
Quadratic coefficient modification procedures
The procedures and functions of the GMP::QuadraticCoefficient
namespace are listed in the table below and take care of
the modification of coefficients of quadratic rows in the matrix other
than the objective of a generated mathematical program instance.
You can instruct AIMMS to modify any particular quadratic coefficient in
a matrix by specifying the corresponding row and columns (in AIMMS
notation), together with the new value of that coefficient, as arguments
of the procedure GMP::QuadraticCoefficient::Set. This procedure can
also be used when a value for the quadratic coefficient does not exist
prior to calling the procedure.
Row Modification Procedures
Row modification procedures
The procedures and functions of the GMP::Row namespace are listed in the
table below and take care of the modification of properties
of existing rows and the creation of new rows.
Row types
The row type refers to one of the four possibilities:
'<=','=','>=', and'ranged'
You are free to change this type for each row. Deactivating and subsequently reactivating a row are instructions to the solver to ignore the row as part of the underlying mathematical program and then reconsider the row again as an active row.
Row generation
When you add a new row to a matrix using GMP::Row::Add, the newly
added row will initially only have any zero coefficients, regardless of
whether the corresponding AIMMS constraint had a definition or not.
Through the procedure GMP::Row::Generate you can tell AIMMS to
discard the current contents of a row in the matrix, and insert the
coefficients as they follow from the definition of the corresponding
constraint in your model.
Indicator conditions
When you are using the CPLEX, Gurobi or ODH-CPLEX solver, you can
declaratively specify indicator constraints through the
IndicatorConstraint property of a constraint declaration (see
Indicator Constraints, Lazy Constraints and Cut Pools). You can also set and delete indicator
constraints programmatically for a given GMP using the functions
GMP::Row::SetIndicatorCondition and
GMP::Row::DeleteIndicatorCondition
Lazy and cut pool constraints
declaratively specify constraints to be part of a pool of lazy
constraints or cuts through the IncludeInLazyConstraintPool and
IncludeInCutPool properties of a constraint declaration respectively
(see Indicator Constraints, Lazy Constraints and Cut Pools). You can also specify lazy and cut
pool constraints programmatically for a given GMP using the function
GMP::Row::SetPoolType.
Convex and relaxation-only constraints
Through the .Convex and .RelaxationOnly suffices of constraints
you can set special constraint properties for the BARON global
optimization solver (see also Constraint Suffices for Global Optimization). For a
given GMP you can also set these constraint properties
programmatically using the GMP::Row::SetConvex and
GMP::Row::SetRelaxationOnly functions.
Column Modification Procedures
The procedures and functions of the GMP::Column namespace are listed
in the table below and take care of the modification of
properties of existing columns and the creation of new columns.
Column types
The column type refers to one of the three possibilities:
'integer','continuous', and'semi-continuous'.
You are free to specify a different type for each column. For newly added columns, AIMMS will (initially) use the lower bound, upper bound and column type as specified in the declaration of the (symbolic) variable associated with the added column. Freezing a column and subsequently unfreezing it are instructions to the solver to fix the corresponding variable to its current value, and then free it again by letting it vary between its bounds.
Changing the objective column
If you want to implement the procedures for reaching primal or dual uniqueness as described in Dealing with Degeneracy and Non-Uniqueness, you can use the procedure
to change the objective function used by either the primal or dual mathematical program instance that you want to solve for a second time. Notice that the defining constraint for this variable should be
part of the original mathematical program formulation for which AIMMS has generated a mathematical program instance, or
added later on to the primal or dual generated mathematical program instance using the
GMP::Row::Addprocedure, where the row definition is generated by AIMMS through theGMP::Row::Generateprocedure or constructed explicitly through several calls to theGMP::Coefficient::Setprocedure.
If you want to change the data of many columns or rows belonging to some variable or constraint then
it is more efficient to use the multi variant of a modification procedure. The available multi
procedures of the GMP namespace are listed in the table below.
Binding argument
All procedures in the table above contain an index binding argument. The index binding argument specifies which columns or rows will be modified. If the procedure contains a value argument then the size of this vector is defined by the index binding argument. Further information on index binding can be found in Index Binding.
Alternative procedures
An alternative approach to change or retrieve the data of multiple columns or rows is using the raw procedures, of the GMP namespace,
mentioned in the table below.
These procedures use a set of column and/or row numbers as input. These sets of column and row numbers can be obtained by using the functions
respectively.
Modifying an Extended Math Program Instance
Extended math program instances
To use the matrix manipulation routines of the GMP library, you must be able to associate every row and column of the matrix of the math program instance you want to manipulate with a symbolic constraint or variable within your model. However, some routines in the GMP library generate rows and columns that cannot be directly associated with specific symbolic constraints and variables in your model. Examples of such routines are:
the
GMP::Instance::CreateDualprocedure, which may generate additional variables in the dual formulation for bounded variables and ranged constraints in the primal formulation (see also Dealing with Degeneracy and Non-Uniqueness),the
GMP::Linearization::AddandGMP::Linearization::AddSingleprocedures, which add linearizations of nonlinear constraints to a specific math program instance (see also Creating and Managing Linearizations),the
GMP::Instance::AddIntegerEliminationRowsprocedure, andthe
GMP::Instance::AddLimitBinaryDeviationRowprocedure.
The rows and columns generated by these procedures can, however, be indirectly associated with symbolic constraints, variables or mathematical programs, as will be explained below.
Extended suffices
To support the use of the matrix manipulation routines in conjunction with rows and columns generated by AIMMS that can only be indirectly associated with symbolic identifers in the model, AIMMS provides the following suffices which allow you to do so:
These suffices are supported for Variables, Constraints and
MathematicalPrograms. They behave like variables and constraints,
which implies that it is possible to refer to the .ReducedCost and
.ShadowPrice suffices of these extended suffices to get hold of
their sensitivity information.
Suffix dimensions
Each of the suffices listed above has one additional dimension compared
to the dimension of the original identifier, over the predefined set
AllGMPExtensions. For example, assuming that ae is an index into
the set AllGMPExtensions,
if
z(i,j)is a variable or constrain, the .ExtendedVariable suffix will have indicesz.ExtendedVariable(ae,i,j),if
mpis a mathematical program, the .ExtendedConstraint suffix will have indicesmp.ExtendedConstraint(ae).
Each of the procedures listed above, will add elements to the set
AllGMPExtensions as necessary. The names of the precise elements
added to the set is explained below in more detail.
Suffices generated by CreateDual
The procedure GMP::Instance::CreateDual will add the following
elements to the set AllGMPExtensions:
DualObjective,DualDefinition,DualUpperBound,DualLowerBound.
In addition, it will generate the following extended variables and constraints
For the mathematical program
mpat handthe variable
mp.ExtendedVariable('DualDefinition'),the constraint
mp.ExtendedConstraint('DualObjective').
For every ranged constraint
c(i)the constraint
c.ExtendedConstraint('DualLowerBound',i),the constraint
c.ExtendedConstraint('DualUpperBound' i).
For every bounded variable
x(i)in \([l_i,u_i]\)- the constraint
x.ExtendedConstraint('DualLowerBound',i)(if \(l_i\neq 0,-\infty\)), - the constraint
x.ExtendedConstraint('DualUpperBound' i)(if \(u_i\neq 0, \infty\)).
Modifying the dual math program
Using the matrix manipulation procedures, you can modify the matrix or
objective associated with a dual mathematical program instance created
by calling the procedure GMP::Instance::CreateDual. Below you will
find how you can access the rows and columns of a dual mathematical
program instance created by AIMMS.
Row and column names
For each procedure in the GMP::Coefficient, GMP::Row and
GMP::Column namespaces you must refer to a scalar constraint and/or
variable reference from your symbolic model. For the dual formulation,
you must
use the symbolic primal constraint name, to refer to the dual shadow price variable associated with that constraint in the dual mathematical program instance, and
use the symbolic primal variable name, to refer to the dual constraint associated with that variable in the dual mathematical program instance.
In other words, when modifying matrix coefficients, rows or columns the role of the symbolic constraints and variables is interchanged.
Implicitly added variables and constraints
You can refer to the implicitly added variables and constraints in the
procedures of the GMP::Coefficient, GMP::Row and GMP::Column
namespaces through the .ExtendedVariable and .ExtendedConstraint
suffices described above. After solving the dual math program, AIMMS
will store the dual solution in the suffices
.ExtendedVariable.ReducedCost and
.ExtendedConstraint.ShadowPrice, respectively.
Extended suffices for linearization
By calling the procedures GMP::Linearization::Add or
GMP::Linearization::AddSingle, AIMMS will add the linearization for
a single nonlinear constraint instance, or for all nonlinear constraints
from a set of nonlinear constraints to a given math program instance.
When doing so, AIMMS will add an element Linearization\(k\)
(where \(k\) is a counter) to the set AllGMPExtensions, and will
create for each nonlinear constraint c(i)
a constraint
c.ExtendedConstraint('Linearization\(k\)',i), anda variable
c.ExtendedVariable('Linearization\(k\)',i)if deviations from the constraint are permitted (see also Creating and Managing Linearizations).
Elimination constraints and variables
By calling the procedure GMP::Instance::AddIntegerEliminationRows,
AIMMS will add one or more constraints and variables to a math program
instance, which will eliminate the current integer solution from the
math program instance. When called, AIMMS will add elements of the form
Elimination\(k\),EliminationLowerBound\(k\), andEliminationUpperBound\(k\)
to the set AllGMPExtensions. In addition, AIMMS will add
a constraint
mp.ExtendedConstraint('Elimination\(k\)')to exclude current solution for all binary variables from the math programmpat hand, andfor every integer variable
c(i)with a level value between its bounds the variables and constraintsc.ExtendedVariable('Elimination\(k\)',i),c.ExtendedVariable('EliminationLowerBound\(k\)',i),c.ExtendedVariable('EliminationUpperBound\(k\)',i),c.ExtendedConstraint('Elimination\(k\)',i),c.ExtendedConstraint('EliminationLowerBound\(k\)',i), andc.ExtendedConstraint('EliminationUpperBound\(k\)',i).
Constraints for limiting deviation
By calling the procedure GMP::Instance::AddLimitBinaryDeviationRow,
AIMMS will add one constraint to a math program instance, which limits
the number of binary variables of which the solution value is allowed to change.
When called, AIMMS will add an element of the form
Deviation\(k\)
a constraint
mp.ExtendedConstraint('Deviation\(k\)')to limit the number of binary variables from the math programmpat hand of which the solution value is allowed to change.
