Customizing the Progress Window
Customizing the progress window
When you are using the GMP library to implement a customized algorithm
for a particular problem or problem class, you can use the procedures in
the GMP::ProgressWindow namespace to customize the contents of the
AIMMS Progress Window. This allows you to provide customized feedback to
the end-user regarding the progress of the overall solution algorithm,
or to provide simultaneous progress information about multiple solver
session executing in parallel.
Customizing progress
The procedures and functions of the GMP::ProgressWindow namespace
are listed in this table. They allow you to modify
every aspect of the solver part of the AIMMS progress window.
Creating a new progress category
When your model executes multiple solver sessions in parallel, you can
request AIMMS to create a new progress category to display separate
solver progress for each solver session in a separate area of the
progress window. Using the function
GMP::Instance::CreateProgressCategory, you can create a new progress
category for a specific mathematical program instance that will
subsequently be used to display solver progress for all solver
sessions associated with that mathematical program instance.
Alternatively, you can create a per-session category to display separate
solver progress for every single solver session using the function
GMP::SolverSession::CreateProgressCategory. The procedure
GMP::ProgressWindow::Transfer allows you to share a progress
category among several solver sessions. Through the function
GMP::ProgressWindow::DeleteCategory you can delete progress
categories created by either function.
Freezing category content
Through the functions GMP::ProgressWindow::FreezeLine and
GMP::ProgressWindow::UnfreezeLine you can instruct AIMMS to stop and
start updating particular areas of the solver progress area associated
with the progress category.
Displaying custom content
When you are writing a custom algorithm you can use the progress window to display custom progress information supplied by you using the functions
When your custom algorithm consists of a sequence of solves, you can use these functions, for instance, to display custom progress information for the overall algorithm, possibly in combination with regular progress for the underlying solves in a separate category.
Example of use
An example of the usage of the GMP::ProgressWindow can be found in
the AIMMS module containing the GMP Outer Approximation algorithm
discussed in A First and Basic Implementation. In this module, the contents of the
AIMMS progress window is adapted for the AIMMS Outer Approximation
solver.
