Automatic Benders’ Decomposition
Important note
The solver CPLEX has its own implementation of the Benders’
decomposition algorithm. An important difference is that the algorithm
in CPLEX supports multiple subproblems. CPLEX allows you to specify the
decomposition by assigning the variables to the master problem or a
subproblem by using the procedure GMP::Column::SetDecomposition. For
more information see the CPLEX option Benders_strategy.
Introduction
Benders’ decomposition, introduced by Jacques F. Benders in 1962 ([Ben62]), is an algorithm that decomposes a problem into two simpler parts. The first part is called the master problem and solves a relaxed version of the problem to obtain values for a subset of the variables. The second part is often called the subproblem (or slave problem or auxiliary problem) and finds values for the remaining variables fixing the variables of the master problem. If the problem contains integer variables then typically they become part of the master problem while the continuous variables become part of the subproblem.
Cuts
The solution of the subproblem is used to cut off the solution of the master problem by adding one or more constraints (“cuts”) to the master problem. This process of iteratively solving master problems and subproblems is repeated until no more cuts can be generated. The combination of the variables found in the last master problem and subproblem iteration forms the solution to the original problem.
Reduced solution times possible
For particular optimization problems, Benders’ decomposition may lead to a good, or even the optimal, solution in relatively few iterations. In such cases, employing Benders’ decomposition results in drastically reduced solution times compared to solving the original problem. For other problems, however, the progress per iteration is so small that there is no positive, or even an adversary, effect by applying Benders’ decomposition. Upfront, it is hard predict whether or not there will be positive effects for your particular model.
Hard to implement manually
Implementing Benders’ decomposition from scratch for a particular problem is a non-trivial and error-prone task. Because duality theory plays an important role, the process often involves explicitly working out the dual formulation of the subproblem-and keeping it up-to-date when you make changes to the original problem. Given the uncertainty whether Benders’ decomposition will lead to an improvement in solution times at all, a manual implementation may not be a prospect to look forward to.
Automatic Benders’ decomposition in AIMMS
For AIMMS, on the other hand, generating the master and slave problems in an automated fashion is a fairly straightforward task, given a generated mathematical program and the collection of variables that should go into the master problem. With such an automated scheme, verifying whether your particular model will benefit from Benders’ decomposition becomes completely trivial. With just a few lines of code, and simply re-solving your model you will get immediate insight into the benefits of Benders’ decomposition for your model.
Classical versus modern
The Benders’ decomposition module in AIMMS implements both the classical Benders’ decomposition algorithm and a modern version. By the classical approach we mean the algorithm described above that solves an alternating sequence of master problems and subproblems, and that, in principle, will work for any problem type. The modern approach will only work for problems containing integer variables. In the modern approach, the algorithm will solve only a single master MIP problem, where subproblems are solved whenever the MIP solver finds a solution for the master problem, using callbacks provided by modern MIP solvers.
Several algorithms
Besides the classical and the modern algorithm, the Benders’ decomposition module in AIMMS also implements a two phase algorithm that solves a relaxed problem in the first phase and the original problem in the second phase. In addition, the module offers you the flexibility to solve the subproblem as a primal or dual problem, to normalize the subproblem to get better feasibility cuts, and so on.
Limitations of current implementation
Benders’ decomposition in AIMMS can be used for solving Mixed-Integer Programming (MIP) problems and Linear Programming (LP) problems. Currently it cannot be used to solve nonlinear problems. Also, the current implementation does not support multiple subproblems which could be efficient in case the subproblem has a block diagonal structure. This implies that the current implementation cannot be used to solve (two stage) stochastic programming problems with a subproblem for each scenario.
Open algorithm
Benders’ decomposition in AIMMS is implemented as a system module with
the name GMP Benders Decomposition. You can install this module
using the Install System Module command in the AIMMS Settings
menu. The Benders’ decomposition algorithms are implemented in the AIMMS
language. Some supporting functions that are computationally difficult,
or hard to express in the AIMMS language, have been added to the GMP
library in support of the Benders’ decomposition algorithm. Besides this
small number of fixed subtasks, the implementation is an open algorithm;
you as an algorithmic developer may want to customize the individual
steps in order to obtain better performance and/or a better solution for
your particular problem.
This chapter
This chapter starts with a quick start for using Benders’ decomposition in AIMMS for those already familiar with Benders’ decomposition. Following a brief introduction to the problem statement, we discuss the Benders’ decomposition algorithm as it can be found in several textbooks. Next we describe the implementation of the classic Benders’ decomposition algorithm using procedures in the AIMMS language that are especially designed to support the open approach. This section is important for users that want to modify the algorithm. Next, we discuss in detail the parameters inside the Benders’ module that can be used to control the Benders’ decomposition algorithm. We continue by describing the implementation of a modern Benders’ decomposition algorithm. The chapter ends by introducing a two phase algorithm that solves a problem by using information gathered while solving a relaxed version of the problem, and we also describe its implementation.
