The AIMMS Multistart Algorithm
The multistart algorithm
A multistart algorithm calls an NLP solver from multiple starting points, keeps track of (all) feasible solutions found by the NLP solver, and reports back the best of these as its final solution.
Why use multistart?
A multistart algorithm can improve the reliability of any NLP solver, by calling it with many starting points. A single call to a NLP solver can fail (return a status of infeasible), but multiple calls from the widely spaced starting points provided by a multistart algorithm have a much better chance of success.
Basic techniques
In a pure multistart algorithm many local searches will converge to the same local minimum. Computational effort can be reduced if the minimizations leading to the same local minimum point can be identified and combined at early stages. An improvement is to use cluster analysis techniques to identify regions of points that will lead to the same local minimum.
Algorithm used by AIMMS
AIMMS uses a multistart algorithm that does not use advanced cluster analysis techniques, but instead tries to identify areas of points that will lead to the same local solution. These areas are updated (and become larger) whenever a starting point is found that leads to a local solution that has already been found before. An more detailed description of a multistart algorithm similar to the one used by AIMMS can be found in [KT87].
Definitions
The following terminology is used for the multistart algorithm
Sample points: a set of points that were randomly sampled.
Cluster point: a point that defines the center of a cluster, i.e., a cluster is a circle/ball with a cluster point as its center.
Starting point: a point used as an initial solution (“hotstart”) for solving the NLP.
Local solution: a solution found by the NLP solver (by using a starting point). A local solution belongs to exactly one cluster point. A local solution can be infeasible.
Two algorithms
The multistart module implements two algorithms, namely a basic algorithm and a dynamic algorithm in which the number of iterations is changed dynamically. The inputs for both algorithms are:
a GMP associated with an NLP,
NumberOfSamplePoints, andNumberOfSelectedSamplePoints.
The basic algorithm
The basic algorithm employs the following steps:
Set
IterationCountequal to 1.Generate
NumberOfSamplePointssample points from the uniform distribution. Calculate the penalized objective for all sample points and select the bestNumberOfSelectedSamplePointssample points.For all sample points (
NumberOfSelectedSamplePointsin total) do:For all clusters, calculate the distance between the sample point and the center of the cluster. If the distance is smaller than the radius of the cluster (i.e., the sample point belongs to the cluster) then delete the sample point.
For all (remaining) sample points do:
Solve the NLP by using the sample point as its starting point to obtain a candidate local solution.
For all clusters do:
Calculate the distance between the candidate local solution and the local solution belonging to the cluster.
If the distance equals 0 (which implies that the candidate local solution is the same as the local solution belonging to the cluster) then update the center and radius of the cluster by using the sample point.
Else, construct a new cluster by using the mean of the sample point and the candidate local solution as its center with radius equal to half the distance between these two points. Assign the candidate local solution as the local solution belonging to the cluster.
For all remaining sample points, calculate the distance between the sample point and the center of the updated or the new cluster. If the distance is smaller than the radius of the cluster then delete the sample point.
Increment
IterationCount. If the number of iterations exceeds theIterationLimit, then go to step (5). Else go to step (1).Order the local solutions and store the
NumberOfBestSolutionssolutions in the solution repository.
By default, the algorithm uses the initial variable values as the first “sample” point in the first iteration.
The dynamic algorithm: first phase
The dynamic algorithm contains two phases. The first phase is similar to the basic algorithm but with some differences. The dynamic algorithm starts by determining the best sampling box for the creation of the random points (in step 0). For the first sample point, which can be an initial point provided by the user or the first randomly generated point, a method is applied to compute an approximately feasible solution (see [Chi04]) to increase the chance that this first sample point will lead to a feasible solution. Finally, if the dynamic algorithm did not find any feasible solution during the first iterations, and all local solutions found contain large infeasibilities, then a heuristic will be used to update the variable bounds (in step 4).
The dynamic algorithm: second phase
The second phase of the dynamic algorithm is only conducted if no feasible solution was found in the first phase, or if the objective values of the feasible solutions found in the first phase vary. The second phase differs for both situations. If no feasible solution was found in the first phase then the algorithm will continue with steps 1 to 4 until a feasible solution is found or the time limit is hit. In each iteration, the algorithm will now use the method for computing an approximately feasible solution for the first randomly generated point. In the other case, in which the objective values of the feasible solutions found in the first phase vary, the second phase will continue with steps 1 to 4 until enough feasible solutions are found to satisfy a Bayesian estimate for the number of local feasible solutions (or if the time limit is hit).
Using the AIMMS multistart algorithm
The AIMMS multistart algorithm is implemented as a system module, with
the name Multi Start, that you can add to your project. You can
install this module using the Install System Module command in the
AIMMS Settings menu. The algorithm outlined above is implemented in
the AIMMS language. Some supporting functions that are computationally
difficult, or hard to express in the AIMMS language, have been added to
the GMP library in support of the AIMMS multistart algorithm.
Calling the multistart algorithm
The main procedure to start the multistart algorithm is the procedure
DoMultiStart. The only mandotory input is a generated mathematical
program obtained by calling the GMP::Instance::Generate function of
the GMP library discussed in Managing Generated Mathematical Program Instances. Therefore the
multistart algorithm can be called by using for example:
MulStart::DoMultiStart( myGMP );
Here MulStart is the prefix of the multistart module. The behavior
of the multistart algorithm is influenced by several control parameters,
which are discussed in Control Parameters That Influence the Multistart Algorithm.
Optional arguments
The procedure DoMultiStart contains two optional arguments (with a
default value of 0) which can be used to specify the number of sample
points and the number of selected sample points (as outlined above). If
both arguments are not specified (like in the example of the previous
paragraph) or are equal to 0, then the multistart algorithm will use the
dynamic algorithm, and otherwise the basic algorithm. For example, if
MulStart::DoMultiStart( myGMP, 20, 10 );
is used then the basic algorithm will be used with 20 sample points and
10 selected sample points. If the dynamic algorithm is used then the
multistart algorithm will automatically select values for the number of
sample points and the number of selected sample points. It is possible
to use the dynamic algorithm and specify the number of sample points and
the number of selected sample points yourself by calling the procedure
DoMultiStartDynamic.
Supporting GMP functions
The GMP library contains the following functions to support the multistart algorithm:
GMP::Solution::RandomlyGenerate(used in step (1))GMP::Solution::GetPenalizedObjective(used in step (1))GMP::Solution::GetDistance(used in steps (2) and (4))GMP::Solution::ConstructMean(used in step (4))GMP::Solution::UpdatePenaltyWeights(used during initialization)
Optionally it is possible to (approximately) project each sample point
to the feasible region by using the procedure
GMP::Instance::FindApproximatelyFeasibleSolution.
Modifying the algorithm
Because the multistart algorithm is written in the AIMMS language, you have complete freedom to modify the algorithm in order to tune it for your nonlinear programs.
