Using Solver Sessions
Using solver sessions
The procedures and functions of the GMP::SolverSession namespace are
listed in this table. Solver sessions are created
implicitly by AIMMS or explicitly by calling the procedure
GMP::Instance::CreateSolverSession.
Solving a mathematical program instance
By calling the GMP::SolverSession::Execute procedure, the given
solver session will take care of solving the associated mathematical
program instance in a blocking manner, i.e. the function will not return
until the solver has completed the solution process. This function is
called implicitly by the GMP::Instance::Solve function or by the
SOLVE statement.
Asynchronous solve
Alternatively, you can solve a mathematical program instance in an
non-blocking manner by using the function
GMP::SolverSession::AsynchronousExecute. Rather than waiting for the
solution process to complete, this function will dispatch the solution
process to a separate thread of execution, and return immediately. This
allows multiple mathematical program instances to be solved in parallel,
assuming your computer has multiple processors or a multi-core
processor. Note that requests for a synchronous solve through the
SOLVE statement will fail if a AIMMS is still executing an
asynchronous solution process.
Session synchronization
To allow your application to synchronize its execution when multiple solver sessions are executed asynchronously, AIMMS offers the following synchronization procedures
Through the GMP::SolverSession::Interrupt function you can request
AIMMS to interrupt a solver session that is executing (asynchronously).
You can call the function GMP::SolverSession::ExecutionStatus to
check the status of a given solver session.
Waiting for multiple completions
Using the function GMP::SolverSession::WaitForCompletion you can
halt the main AIMMS thread of execution to wait until the entire set of
solver sessions passed as an argument to the function have completed.
You can use this function, for instance, to end the solution phase of
your model, prior to moving on to the post-processing phase of your
model.
…and for single completion
In addition, AIMMS offers a function
GMP::SolverSession::WaitForSingleCompletion which returns as soon as
a single solver session from the given set of solver sessions has
completed its execution. The return value of the function is the
completed solver session that caused the function to return. You can use
WaitForSingleCompletion, for instance, to asynchronously solve the
next mathematical program instance from a queue of mathematical program
instances waiting to be solved.
No solution transfer
Note that neither GMP::SolverSession::Execute and
GMP::SolverSession::AsynchronousExecute will copy the initial
solution into the solver, or copy the final solution back into solution
repository or model identifiers. When you use these functions you always
have to explicitly call functions from the GMP::Solution namespace
to accomplish these tasks.
Support for callbacks
When callbacks for the mathematical program instance associated with a solver session have been set (see also Managing Generated Mathematical Program Instances), AIMMS will make sure that the specified callback procedures in your model will be called whenever appropriate. If you have specified a single callback procedure for multiple callback reasons, you can call the procedure
to retrieve the reason why your callback procedure was called. The
result is an element in the predeclared set AllSolverInterrupts
which contains the elements
Candidate,Incumbent,AddCut,Iterations,Heuristic,StatusChange, andFinished.
When the solver session has not yet been called, the status is "
(empty element). During a callback, you can call the function
if you need the mathematical program instance associated with the given solver session, and you can retrieve the current objective values using the functions
Synchronous nested solves allowed
During any callback you are allowed to generate and solve other
mathematical program instances in a synchronous manner. You can use
such nested solves, for instance, for finding a heuristic solution
during a Heuristic callback. Once you have found a heuristic
solution, you can pass it onto the running solver session using the
function GMP::Solution::SendToSolverSession. Note that this
functionality is currently only supported by CPLEX and Gurobi.
No asynchronous solves
During a callback AIMMS does not allow you to call the function
GMP::SolverSession::AsynchronousExecute to solve another
mathematical program instance in an asynchronous manner. However, AIMMS
offers a special class of synchronization objects called events, which
allow you to notify the main thread of execution that some event has
occurred and act accordingly. When set during a callback, the main
thread of execution may respond, for instance, by generating a
mathematical program instance based on solver data set by the callback,
and solve that mathematical program instance in an asynchronous manner.
Events are discussed in full detail in Synchronization Events.
Adding cuts
During an AddCut callback you may use the procedure
GMP::SolverSession::GenerateCut to generate a local or global cut. A
local cut will only be added to the current node in the solution process
and all its descendant nodes, while a global cut will remain to exist
for all nodes onwards. The result of the procedure will be the temporary
addition of row to the matrix, as if GMP::Row::Generate had been
called. Note that this functionality is currently only supported by
CPLEX, Gurobi and ODH-CPLEX.
Rejecting incumbents
During a Candidate callback you can reject the incumbent found by
the solver by calling the procedure
GMP::SolverSession::RejectIncumbent. Note that this functionality is
currently only supported by CPLEX.
Setting options
You can set options for a specific solver session associated through the
function GMP::SolverSession::SetOptionValue. These option values
override the option values for the associated GMP, set through
GMP::Instance::SetOptionValue, which in their turn override the
project options.
Retrieving an irreducible infeasible set
If the generated math program appears to be infeasible then the procedure
GMP::SolverSession::GetIIS can be used to retrieve an irreducible
infeasible set (IIS). This procedure returns the row and column numbers
of the rows and columns that are part of the IIS.
