A First and Basic Implementation
Calling the AOA algorithm
To call the AOA algorithm, the GMP library is used to generate a number
of math program instances, and associated solver sessions, where
SymbolicMP is the symbolic mathematical program containing the MINLP
model.
! Generate the MINLP model.
GMINLP := GMP::Instance::Generate(SymbolicMP, FormatString("%e", SymbolicMP)) ;
! Create NLP subproblem.
GNLP := GMP::Instance::Copy( GMINLP, 'OA_NLP' ) ;
GMP::Instance::SetMathematicalProgrammingType( GNLP, 'RMINLP' ) ;
ssNLP := GMP::Instance::CreateSolverSession( GNLP ) ;
! Create Master MIP problem.
GMIP := GMP::Instance::CreateMasterMip( GMINLP, 'OA_MasterMIP' ) ;
ssMIP := GMP::Instance::CreateSolverSession( GMIP ) ;
BasicAlgorithm;
The basic algorithm outlined above is available in the GMP Outer
Approximation module as the procedure DoOuterApproximation.
The basic algorithm
The basic algorithm is straightforward, and makes a call to five other procedures that execute the various algorithm steps. The naming convention is self-explanatory, and the following lines make up this first example of a main procedure. For the sake of brevity and clarity, the parts of the code used to create a status file and to customize the contents of the progress window have been left out. They can be found in the basic implementation of the AOA algorithm in the AOA module.
InitializeAlgorithm;
SolveRelaxedMINLP;
while ( not MINLPAlgorithmHasFinished ) do
AddLinearizationsAndSolveMasterMIP;
FixIntegerVariablesAndSolveNLP;
TerminateOrPrepareForNextIteration;
endwhile;
Note that the scalar parameter MINLPAlgorithmHasFinished must be
initially set to zero, and should only get a nonzero value when the
algorithm is ready to terminate.
InitializeAlgorithm
The following procedure is used to set all algorithmic parameters and options, and to prepare the status file and progress window output.
IterationCount := 0 ;
LinearizationCount := 1 ;
EliminationCount := 1 ;
IncumbentSolutionHasBeenFound := 0 ;
MINLPAlgorithmHasFinished := 0 ;
if ( NLPUseInitialValues ) then
GMP::Solution::RetrieveFromModel( GNLP, SolNumbInitialValues ) ;
endif;
if ( GMP::Instance::GetDirection( GMINLP ) = 'maximize' ) then
MINLPOptimizationDirection := 1;
else
MINLPOptimizationDirection := -1;
endif;
GMP::Solution::SetProgramStatus( GMINLP, SolNumb, 'ProgramNotSolved' ) ;
GMP::Solution::SetSolverStatus( GMINLP, SolNumb, 'Unknown' ) ;
! The marginals of the NLP solver are needed.
option always_store_marginals := 'On';
The algorithmic parameters are initially set such that the AOA algorithm will always select the original initial values (i.e. the values of the variables prior to starting the AOA algorithm) as the starting values for each NLP subproblem to be solved. This setting has found to work quite well in extensive tests performed using this algorithm.
MINLPTerminate
The following termination procedure is used in several of the procedures that are described later.
if ( IncumbentSolutionHasBeenFound ) then
GMP::Solution::SetProgramStatus( GMINLP, SolNumb, 'LocallyOptimal' ) ;
GMP::Solution::SetSolverStatus( GMINLP, SolNumb, 'NormalCompletion' ) ;
else
GMP::Solution::SetProgramStatus( GMINLP, SolNumb, 'LocallyInfeasible' ) ;
endif;
GMP::Solution::SendToModel( GMINLP, SolNumb ) ;
MINLPAlgorithmHasFinished := 1 ;
The parameter IncumbentSolutionHasBeenFound contains a value of one
or zero depending on whether the AOA algorithm has received an incumbent
solution to the original MINLP model. Such a solution may be found when
solving the NLP subproblem, and this must then be communicated to the
AOA algorithm. Note that you also need to set the program status and
indicate when the MINLP algorithm has finished.
SolveRelaxedMINLP
The first model that is solved during the algorithm is the relaxed MINLP model. All integer variables are relaxed to continuous variables. The following procedure implements this first solution step of the outer approximation algorithm.
SolveNLPSubProblem( 1 );
ProgramStatus := GMP::Solution::GetProgramStatus( GNLP, SolNumb ) ;
if ( ProgramStatus in NLPOptimalityStatus ) then
! Save NLP solution as MINLP solution if an integer solution has been found.
if ( GMP::Solution::IsInteger( GNLP, SolNumb ) ) then
! Set incumbent solution for MINLP.
GMP::Solution::RetrieveFromModel( GMINLP, SolNumb ) ;
IncumbentSolutionHasBeenFound := 1 ;
if ( TerminateAfterFirstNLPIsInteger ) then
! Terminate if an integer solution has been found.
MINLPTerminate;
endif;
endif;
else
! Terminate if no linearization point has been found.
SolverStatus := GMP::Solution::GetSolverStatus( GNLP, SolNumb ) ;
if not ( SolverStatus in NLPContinuationStatus ) then
MINLPTerminate;
endif;
endif ;
IterationCount += 1 ;
GMP::Solution::SetIterationCount( GMINLP, SolNumb, IterationCount ) ;
When the procedure SolveNLPSubProblem has terminated, the AOA
algorithm has typically found a point for the linearization step. The
exception being when the NLP solver does not produce a solution at all
(either feasible or infeasible). In such a situation the outer
approximating algorithm should be terminated. Note that in the special
event that the solution is feasible and has integer values for the
integer variables, a locally optimal solution has been found and the AOA
algorithm is instructed accordingly. Otherwise, the next step of the
outer approximation algorithm can be executed.
If a termination flag has not been set, the following procedure adds linearizations to the master MIP problem prior to solving it. If this model becomes infeasible, the outer approximation algorithm will be terminated.
return when ( MINLPAlgorithmHasFinished );
GMP::Linearization::Add( GMIP, GNLP, SolNumb, AllNonLinearConstraints,
DeviationsPermitted, PenaltyMultiplier,
LinearizationCount, JacobianTolerance ) ;
LinearizationCount += 1 ;
GMP::SolverSession::Execute( ssMIP ) ;
GMP::Solution::RetrieveFromSolverSession( ssMIP, SolNumb ) ;
GMP::Solution::SendToModel( GMIP, SolNumb ) ;
ProgramStatus := GMP::Solution::GetProgramStatus( GMIP, SolNumb ) ;
if not ( ProgramStatus in MIPOptimalityStatus ) then
MINLPTerminate;
endif ;
The AIMMS parameters DeviationsPermitted and PenaltyMultiplier
are part of the AOA module. By default, deviations are allowed and are
penalized with the value 1000 in the objective function of the master
MIP.
The following procedure implements the next major step of the outer approximation algorithm. First, the NLP subproblem is solved after fixing all the integer variables in the MINLP model using the values found from solving the previous master MIP problem. Then, if the combination of integer values and feasible NLP solution values improves the current MINLP incumbent solution, a new incumbent solution is set. When the NLP subproblem does not produce a solution (either feasible or infeasible), the outer approximation algorithm will be terminated.
SolveNLPSubProblem( 0 );
! Save NLP solution as MINLP solution if no incumbent solution
! has been found yet, or if the NLP solution is better than
! the current incumbent.
if ( not IncumbentSolutionHasBeenFound ) then
else
NLPobjectiveValue := GMP::Solution::GetObjective( GNLP , SolNumb ) ;
MINLPIncumbentValue := GMP::Solution::GetObjective( GMINLP, SolNumb ) ;
if ( MINLPSolutionImprovement( NLPobjectiveValue, MINLPIncumbentValue ) ) then
endif;
endif ;
else
MINLPTerminate;
endif;
endif ;
The AOA algorithm maintains the MINLP problem, the master MIP problem, the NLP subproblem, and the incumbent solution of the MINLP. As a result, direct access to the corresponding objective function values is available.
SolveNLPSubProblem
The procedure SolveNLPSubProblem solves the NLP subproblem using
various routines from the GMP library. The procedure has a single
argument initialSolve which indicates whether this is the solve of
the initial relaxed MINLP problem. In that case some steps in the
procedure are not necessary.
GMP::Solution::SendToModel( GNLP, SolNumbInitialValues ) ;
elseif ( not initialSolve ) then
endif;
GMP::Solution::RetrieveFromModel( GNLP, SolNumb ) ;
GMP::Solution::SendToSolverSession( ssNLP, SolNumb ) ;
GMP::Instance::FixColumns( GNLP, GMIP, SolNumb, AllIntegerVariables ) ;
endif;
GMP::SolverSession::Execute( ssNLP ) ;
GMP::Solution::RetrieveFromSolverSession( ssNLP, SolNumb ) ;
GMP::Solution::SendToModel( GNLP, SolNumb ) ;
The following procedure implements the final major step of the outer approximation algorithm. If a termination flag has not been set previously, and the maximum number of iterations has not yet been reached, then the previously found integer solution of the master MIP problem will be eliminated by adding the appropriate cuts. This will ensure that the next master MIP will have a new integer solution (or none at all).
if ( IterationCount = IterationMax ) then
MINLPTerminate;
else
! Prepare for next iteration
GMP::Instance::AddIntegerEliminationRows( GMIP, SolNumb, EliminationCount ) ;
EliminationCount += 1 ;
endif ;
Note that you are responsible for determining the appropriate iteration count for the overall outer approximation algorithm. As you are free to develop a solution algorithm in any way you desire, it is not always possible for the AOA algorithm to determine the correct setting of the MINLP iteration count.
