Working with the Set AllIdentifiers
Working with AllIdentifiers
Throughout your model you can use the predefined set AllIdentifiers
to construct and work with dynamic collections of identifiers in your
model. Several operators in AIMMS support the use of a subset of
AllIdentifiers instead of an explicit list of identifier names,
while other operators support the use of an index into
AllIdentifiers instead of a single explicit identifier name.
Constructing identifier sets
AIMMS offers a number of constructs that can help you to construct a
meaningful subset of AllIdentifiers. They are:
set algebra with other predefined identifier subsets, and
dynamic selection based on model query functions.
Predefined identifier sets
When compiling your model, AIMMS automatically creates an identifier set
for every section in your model. Each such set contains all the
identifier names that are declared in the corresponding section. In
addition, for every identifier type, AIMMS fills a predeclared set
AllIdentifierTypes (e.g. AllParameters, AllSets) with all
the identifiers of that type. The complete list of identifier type
related sets defined by AIMMS can be found in <no title>. You can use both type of sets to perform set algebra to
construct particular identifier subsets of interest to your model.
Example
If your model contains a section Unit Model, you can assign the
collection of all parameters in that section to a subset
UnitModelParameters of AllIdentifiers through the assignment
UnitModelParameters := Unit_Model * AllParameters;
Model query functions
Another method to construct meaningful subsets of AllIdentifiers
consists of using the functions provided to query aspects of those
identifiers. Selected examples are:
the function
IdentifierDimensionreturning the dimension of the identifier,the function
IdentifierTypereturning the type of the identifier as an element ofAllIdentifierTypes,the function
IdentifierTextreturning the contents of theTEXTattribute, andthe function
IdentifierUnitreturning the contents of theUNITattribute.
These functions take as argument an element in the set
AllIdentifiers.
Functions accepting identifier index
In addition to the functions lists above, the functions Card and
ActiveCard also accept an index into the set AllIdentifiers.
They will then return the cardinality of the identifier represented by
the index, or the cardinality of the active elements of that identifier,
respectively. You can also use these functions to dynamically construct
a subset of AllIdentifiers.
Example
The set expression
{ IndexIdentifiers in UnitModelParameters |
IdentifierDimension( IndexIdentifier ) = 3 }
refers to the collection of all 3-dimensional parameter in the section
Unit Model.
Working with identifier sets
The following operators in AIMMS support identifier subsets to represent a collection of individual identifiers:
the
READandWRITEoperators,the
EMPTY,CLEANUP,CLEANDEPENDENTS, andREBUILDoperators.
If you are interested in the contents of an identifier subset, you can
use the DISPLAY operator, which will just print the identifier names
contained in the set, rather than the contents of the identifiers
referred to in the identifier set as is the case for the WRITE
statement.
Functions accepting identifier sets
In addition to the operators above, the following AIMMS functions also
operate on subsets of AllIdentifiers:
See also Model Query Functions of the AIMMS Function Reference.
