Reading and Writing Spreadsheet Data
Treating Excel as a database
While it is technically possible to exchange data with Excel through the
READ and WRITE statements using the ODBC database connectivity
interfaces (see Communicating With Databases), the Excel ODBC drivers have many
limitations. Essential internal SQL statements like UPDATE and
DELETE are not supported by these interfaces, effectively making the
READ statement the only AIMMS statement which might be used in this
setup. For this reason, we strongly recommend you not to use this setup,
but to consider to use the spreadsheet functions, described in this
chapter, instead. Please note that there are no ODBC drivers available
for OpenOffice Calc, so the remarks above apply to the Excel case only.
The AIMMSXLLibrary
The AIMMSXLLibrary Documentation is the preferred way to communicate with excel files from AIMMS applications. This library can also communicate with Excel files in server environments where Excel is not installed. This is particularly useful when one deploys applications on PRO Platform which is typically installed on a machine with no Office or Excel instance.
The Data Exchange library
The Data Exchange Library allows you to flexibly map any JSON, XML format, and CSV or Excel sheet onto appropriate identifiers in your AIMMS model.
