Model Initialization and Termination
Separation of model and data
In general, it is a good strategy to separate the initialization of data from the specification of your model structure. This is particularly true for large models. The separation improves the clarity of the model text, but more importantly, it allows you to use the same model structure with various data sets.
Supplying initial data
There are several methods to input the initial data of the identifiers in your model. AIMMS allows you:
to supply initial data for a particular identifier as part of its declaration,
to read in data from various external data sources, such as text data files, AIMMS cases and databases, and
to initialize data by means of algebraic statements.
Interactive initialization
In an interactive application the end-user often has to enter additional data or modify existing data before the core of the model can be executed. Thus, proper data initialization in most cases consists of more steps than just reading data from external sources. It is the responsibility of the modeler to make sure that an end-user is guided through all necessary initialization steps and that the sequence is completed before the model is executed.
The attribute InitialData
Both sets and parameters can have an InitialData attribute. You can
use it to supply the initial data of a set or parameter, but only when
the set or parameter does not have a definition as well. In general, the
InitialData attribute is not recommended when different data sets
are used. However, it can be useful for initializing those identifiers
in your model that are likely to remain constant for all data sets. The
contents of the InitialData attribute must be a constant
expression (i.e. a constant, a constant enumerated set or a constant
list expression) or a DataTable. The table format is explained in
Tabular Expressions.
The MainInitialization and PostMainInitialization procedures
AIMMS will add the procedures MainInitialization and
PostMainInitialization to a new project automatically. Initially
these are empty, leaving the (optional) specification of their bodies to
you. You can use these procedures to read in data from external sources
and to specify AIMMS statements to compute your model’s initial data in
terms of other data. The latter step may even include solving a
mathematical program. Both the MainInitialization and
PostMainInitialization procedure are aimed at initializing your
model. The distinction between the two becomes apparent in the presence
of libraries in your model (cf. LibraryModule Declaration and Attributes).
Library initialization
Each library can provide LibraryInitialization and
PostLibraryInitialization procedures. The LibraryInitialization
procedure is aimed at initializing the state of each library,
regardless of the state of other libraries, such as sets and
parameters that represent the internal state of the library, or, when
the library uses an external DLL, initializing such a DLL. The
PostLibraryInitialization procedures are executed after all
LibraryInitialization procedures have been executed, and thus, can
rely on the internal state of all other libraries already being
initialized to perform tasks on its behalf.
Model initialization sequence
To initialize the data in your model, AIMMS performs the following actions directly after compiling the model:
AIMMS fills the contents of any global set or parameter with the contents of its
InitialDataattribute,AIMMS executes the predefined procedures
MainInitialization,AIMMS executes the predefined procedure
LibraryInitializationfor each library,AIMMS executes the predefined procedure
PostMainInitialization, andfinally AIMMS executes the predefined procedure
PostLibraryInitializationfor each library.
Thus, as a guideline, any model initialization that depends on (other)
libraries should go into a PostLibraryInitialization or the
PostMainInitialization procedure, to make sure that it can be
executed successfully.
Library termination
Similarly to the situation of library initialization, each library can
provide PreLibraryTermination and LibraryTermination procedures.
The PreLibraryInitialization procedures are executed before all
LibraryTermination procedures have been executed, and are aimed at
at library termination steps that may still need other libraries to be
functioning. The LibraryTermination procedures are aimed at
terminating the state of each library individually, for instance, to
deinitialize any external DLLs the library may depend upon.
Model termination sequence
To terminate your model, AIMMS performs the following actions directly prior to closing the project:
PreLibraryTerminationfor each library,AIMMS executes the predefined procedure
PreMainTermination,AIMMS executes the predefined procedure
LibraryTerminationfor each library.finally AIMMS executes the predefined procedure
MainTermination.
Reading Data from External Sources
The READ statement
You can use the READ statement to initialize data from the following
external data sources:
user-supplied text files containing constant lists and tables,
AIMMS-generated binary case files, and
external ODBC-compliant databases.
Reading from text data files
With the READ statement you can initialize selected model input data
from text files containing explicit data assignments. Only
DataTables and constant expressions (i.e. a constant, a constant
enumerated set or a constant list expression) are allowed. Since the
format of these AIMMS data assignments is simple, the corresponding
files are easily generated by external programs or by using the AIMMS
DISPLAY statement.
When useful
Reading from text files is especially useful when
the data must come directly from your end-users, but is not contained in a formal database,
the data is produced by external programs that are not linked or cannot be linked directly to AIMMS
Reading from binary case files
The READ statement can also initialize data from an AIMMS case file.
You can instruct AIMMS to read either selected identifiers or all
identifiers. The case file data is already in an appropriate format, and
therefore provides a fast medium for data storage and retrieval inside
your application.
When useful
Reading from case files is especially useful when
you want to start up your AIMMS application in the same state as you left it when you last used it,
you want to read from different data sources captured inside different cases making up your own internal database.
Reading from databases
A third (and powerful) application of the READ statement is the
retrieval of data from any ODBC-compliant database. This form of data
initialization gives you direct access to up-to-date corporate
databases.
When useful
Reading from databases is especially useful when
data is shared by several users or applications inside an organization,
data integrity over time in a database plays a crucial role during the lifetime of your application.
Computing initial data
After reading initial data from internal and external sources, AIMMS allows you to compute other identifiers not yet initialized. This feature is very useful when the external data sources of your model supply only partial initial data. For instance, after reading in event data which represent tank actions (when and at what rate do charges and discharges take place), all stock levels at distinct model time instances can be computed.
