Data Control
Why data control?
The contents of domain sets in your model may change through running procedures or performing other actions from within the graphical user interface. When elements are removed from sets, there may be data for domain elements that are no longer in the domain sets. In addition, data may exist for intermediate parameters, which is no longer used in the remainder of your model session. For these situations, AIMMS offers facilities to eliminate or activate data elements that fall outside their current domain of definition. This section provides you with housekeeping data control statements, which can be combined with ordinary assignments to keep your model data consistent and maintained.
Facilities
AIMMS offers the following data control tools:
the
EMPTYstatement to remove the contents from all or a selected number of identifiers,the
CLEANUPandCLEANDEPENDENTSstatements to clean up all, or a selected number of identifiers,the
REBUILDstatement to manually instruct AIMMS to reclaim unused memory from the internal data structures used to the store the data of a selected number of identifiers,the procedure
FindUsedElementsto find all elements of a particular set that are in use in a given collection of indexed model identifiers, andthe procedure
RestoreInactiveElementsto find and restore all inactive elements of a particular set for which inactive data exists in a given collection of indexed model identifiers.
The EMPTY statement
The EMPTY statement can be used to discard the complete contents of
all or selected identifiers in your model. Its syntax follows.
empty-statement:
Empty AIMMS identifiers
The EMPTY operator operates on a list of references to AIMMS
identifiers and takes the following actions.
For parameters, variables (arcs) and constraints (nodes) AIMMS discards their values plus the contents of all their suffices.
For sets, AIMMS will discard their contents plus the contents of all corresponding subsets. If a set is a domain set, AIMMS will remove the data from all parameters and variables that are defined over this set or any of its subsets.
For slices of an identifier, AIMMS will discard all values associated with the slice.
For sections in your model text, AIMMS will discard the contents of all sets, parameters and variables declared in this section.
For a subset of the predefined set
AllIdentifiers, AIMMS will discard the contents of all identifiers contained in this subset.
Use in databases
You can also use the EMPTY statement in conjunction with databases.
With the EMPTY statement you can either empty single columns in a
database table, or discard the contents of an entire table. This use is
discussed in detail in Data Removal. You should note, however,
that applying the EMPTY statement to a subset of AllIdentifiers
does not apply to any database table contained in the subset to avoid
inadvertent deletion of data.
Examples
The following statements illustrate the use of the EMPTY operator.
Remove all data of the variable
Transport.empty Transport ;
Remove all data in the set
Cities, but also all data depending onCities, like e.g.Transport.empty Cities ;
Remove all the data of the indicated slice of the variable
Transportempty Transport(DiscardedCity, j);
Remove all data of all identifiers in the model tree node CityData.
empty CityData ;
Warning
Avoid an inoperable application:
Empty AllIdentifiers ;
Using a blanket 'Empty AllIdentifiers' will also clear identifiers from utility libraries such
as AimmsPROLibrary,
AimmsWebUI, and
AimmsDEX,
which makes those libraries inoperable.
The recommended approach:
Create a subset of
AllIdentifiers.Populate this subset with specific sections or modules (e.g., Business_model) to precisely control what is emptied, see also Working with the Set AllIdentifiers.
Then, perform the
Emptycommand on this subset.
Example taken from Vessel Scheduling:
Set s_idsToBeEmptied {
SubsetOf: AllIdentifiers;
Procedure pr_emptyInstance {
Body: {
s_idsToBeEmptied := Business_model ;
Empty s_idsToBeEmptied ;
In this example, the identifiers that together form the Business model are
captured in a section called Business model; thereby making the
selection of relevant identifiers to be emptied very concise.
Inactive data
When you remove some but not all elements from a domain set, AIMMS will not automatically discard the data associated with those elements for every identifier defined over the particular domain set. AIMMS will also not automatically discard data that does not satisfy the current domain restriction of a given identifier. Instead, it will consider such data as inactive. During the execution of your model, no reference will be made to inactive data, but such data may still be visible in the user interface. In addition, AIMMS will not directly reclaim the memory that is freed up when the cardinality of a multidimensional identifier in your model decreases.
When useful
The facility to create inactive data in AIMMS allows you to temporarily remove elements from domain sets when this is required by your model. You can then restore the data after the relevant parts of the model have been executed.
Discard inactive data
If you want to discard inactive data that has been introduced in a
particular data set, you can apply the CLEANUP statement to
parameters and variables, or the CLEANDEPENDENTS statement to root
sets in your model. Through the REBUILD statement you can instruct
AIMMS to reclaim the unused memory associated with one or more
identifiers in your model. The syntax follows.
cleanup-statement:
Rules
The following rules apply when you call the CLEANUP statement.
When you apply the
CLEANDEPENDENTSstatement to a set, all inactive elements are discarded from the set itself and from all of its subsets. In addition, AIMMS will discard all inactive data throughout the model caused by the changes to the set.When you apply the
CLEANUPstatement to a parameter or variable, all inactive data associated with the identifier is removed. This includes inactive data that is caused by changes in domain and range sets, as well as data that has become inactive by changes in the domain condition of the identifier.When you apply the
CLEANDEPENDENTS,CLEANUP, orREBUILDstatement to a section, AIMMS will remove the inactive data of all sets, or parameters and variables declared in it, respectively.
After using the CLEANUP or CLEANDEPENDENTS statement for a
particular identifier, all its associated inactive data is permanently
lost.
Resorting root set elements
In addition to discarding inactive data from your model that is caused
by the existence of inactive elements in a root set, the
CLEANDEPENDENTS operator will also completely resort a root set and
all data defined of it whenever possible and necessary. The following
rules apply.
Resorting will only take place if the current storage order of a root set differs from its current ordering principle.
AIMMS will not resort sets for which explicit elements are used in the model formulation.
As a call to CLEANDEPENDENTS requires a complete rebuild of all
identifiers defined over the root sets involved, the CLEANDEPENDENTS
statement may take a relatively long time to complete. For a more
detailed description of the precise manner in which root set elements
and multidimensional data is stored in AIMMS refer to
Set Element Ordering. This section also explains the benefits of
resorting a root set.
Generated Mathematical Programs
The CLEANDEPENDENTS statement will also check whether any variable
or constraint is affected; and if so will remove any generated
mathematical program that is generated from such a variable or
constraint.
Restricted usage in AIMMS GUI
You should not call the CLEANDEPENDENTS statement in procedures that
have been linked to edit actions in graphical objects in an AIMMS
end-user GUI via the Procedures tab of the object Properties
dialog box. During these actions, AIMMS does not expect the element
numbering to change.
Efficiency considerations
If you want to apply the CLEANDEPENDENTS statement to multiple sets,
applying the operation to all sets in a single call of the
CLEANDEPENDENTS statement will, in general, be more efficient than
using a separate call for every single set. If an identifier depends on
two or more of the sets to which you want to apply the
CLEANDEPENDENTS operation, the data of such an identifier will only
be traversed and/or rebuild once, rather than multiple times.
Examples
The following
CLEANDEPENDENTSstatement will remove all data from your application that depends on the removed element'Amsterdam', including, for instance, all previously assigned values toTransportdeparting from or arriving at'Amsterdam'.Cities -= 'Amsterdam' ; cleandependents Cities ;
The following
CLEANUPstatement will remove the data of the identifierTransportfor all tuples that either lie outside the current contents ofCities, or do not satisfy the domain restriction.cleanup Transport;
Consider a parameter
A(i,j)whereiis an index into a setSandjan index into a setT, thencleandependents S,T;
will be more efficient than
cleandependents S; cleandependents T;
because the latter may require
A(i,j)to be rebuilt twice.
Finding used elements
When you want to remove the elements in a set that are no longer used in
your application, you first have to make sure which elements are
currently in use. To find these elements easily, AIMMS provides the
procedure FindUsedElements. It has the following three arguments:
a set SearchSet for which you want to find the used elements,
a subset SearchIdentifiers of the predefined set
AllIdentifiersconsisting of all identifiers that you want to be investigated, anda subset UsedElements of the set SearchSet containing the result of the search.
Upon execution, AIMMS will return that subset of SearchSet for which
the elements are used in the combined data of the identifiers contained
in SearchIdentifiers. When the identifiers SearchSet and
UsedElements are contained in SearchIdentifiers they are
ignored.
Example
The following call to FindUsedElements will find the elements of the
set Cities that are used in the identifiers Supply, Demand,
and Distance, and store the result in the set UsedCities.
SearchIdentifiers := DATA { Supply, Demand, Distance };
FindUsedElements( Cities, SearchIdentifiers, UsedCities );
If these cities are the only ones of interest, you can place them into
the set Cities, and thereby overwrite its previous contents. After
that you can cleanup your entire dataset by eliminating data dependent
on cities other than the ones currently contained in the set Cities.
This process is accomplished through the following two statements.
Cities := UsedCities;
cleandependents Cities;
Finding and restoring inactive elements
Inactive data in AIMMS results when elements are removed from (domain)
sets. Such data will be inaccessible, unless the corresponding set
elements are brought back into the set. When this is necessary, you can
use the procedure RestoreInactiveElements provided by AIMMS. This
procedure has the following three arguments:
a set SearchSet for which you want to verify whether inactive data exists,
AllIdentifiersconsisting of those identifiers that you want to be investigated, anda subset InactiveElements of the set SearchSet containing the result of the search.
Upon execution AIMMS will find all elements for which inactive data exists in the identifiers in SearchIdentifiers. The elements found will not only be placed in the result set InactiveElements, but also be added to the search set. This latter extension of SearchSet implies that the corresponding inactive data is restored.
Example
The following call to RestoreInactiveElements will verify whether
inactive data exists for the set Cities in AllIdentifiers.
RestoreInactiveElements( Cities, AllIdentifiers, InactiveCities );
After such a call the set InactiveCities could contain the element
'Amsterdam'. In this case, the set Cities has been extended with
'Amsterdam' as well. If you subsequently decide that cleaning up the
set Cities is harmless, the following two statements will do the
trick.
Cities -= InactiveCities;
Reclaiming memory
If the cardinality of a multidimensional identifier in your model decreases, AIMMS will not automatically reclaim the memory that is freed up because of the decreased amount of data to store. Instead, it will keep the memory available to store additional data that is associated with subsequent changes to the identifier. If the cardinality of an identifier decreases dramatically during a run the of a model, this may lead to a huge amount of memory getting stuck up with a single identifier in your model.
Memory fragmentation
In addition, if a model is running for a prolonged period of time, and an identifier has undergone huge amounts of structural changes during that time, the memory associated with that identifier may become heavily fragmented. In the long run, memory fragmentation may lead to decreased performance of your model. Rebuilding the internal data structures associated with such an identifier will resolve the fragmentation problem.
Automatic reclamation
Prior to solving a mathematical program, AIMMS will perform a quick check comparing the total amount of memory used by an identifier to the amount of unused memory associated with that identifier. By adding to and removing elements from identifiers, memory may become fragmented and the fraction of unused memory may grow. If the fraction of unused memory compared to the total amount of memory in use becomes too large, AIMMS will automatically rebuild such an identifier in order to reclaim the unused memory. AIMMS will also reclaim the memory of an identifier whenever it becomes empty during the run of a model.
Through the REBUILD statement you can manually instruct AIMMS to
rebuild the internal data structures associated with one or more
identifiers. During the REBUILD statement AIMMS uses a more thorough
check to verify whether a rebuild of an identifier is worthwhile prior
to solving a mathematical program.
