Reading and Writing XML Data
This chapter
The Extensible Markup Language (XML) is a universal format for exchanging structured documents and data on the web. For those unfamiliar with XML, XML in 10 Points provides a short introduction. It is taken literally from https://www.w3.org/XML/1999/XML-in-10-points, and is copyrighted © 1999-2000 by the W3C organization. Introduction to XML Support in AIMMS onwards explain in detail how AIMMS lets you employ the XML data format from within your AIMMS applications.
Further information about XML
If you are unfamiliar with XML, the explanation given here will probably not be sufficient. The best starting point to obtain further information about XML, as well as references to specific XML specifications, formats and tools is the W3C XML site https://www.w3.org/XML/.
