The DatabaseTable Declaration
Database tables
You can make a database table known to AIMMS by means of a
DatabaseTable declaration in your application. Inside this
declaration you can specify the ODBC data source name of the database
and the name of the database table from which you want to read, or to
which you want to write. The list of attributes of a DatabaseTable
is given in this table.
Attribute |
Value-type |
See also page |
index-domain |
string-expression |
string-expression |
string-expression |
mapping-list |
string |
comment string |
convention |
The DataSource attribute
The mandatory DataSource attribute specifies the ODBC data source
name of the database you want to link with. Its value must be a string
or a string parameter. If you are unsure about the data source name by
which a particular database is known, AIMMS will help you. While
completing the declaration form of a database table, AIMMS will
automatically let you choose from the available data sources on your
system using the DataSource wizard. AIMMS supports the following
data source types:
ODBC file data sources (
.dsnextension, only available on Windows), andODBC user and system data sources (no extension), and
ODBC connection string.
In addition, you can specify the name of an AIMMS string parameter, holding the name of any of the above data source types. If the data source you are looking for is not available in this list, you can set up a link to that database from within the wizard.
The TableName attribute
With the TableName attribute you must specify the name of the table
or view within the data source to which the DatabaseTable is mapped.
Once you have provided the DataSource attribute, the TableName
wizard will let you select any table or view available in the specified
data source.
Example
The following declaration illustrates the simplest possible
DatabaseTable declaration.
DatabaseTable RouteData {
DataSource : "Topological Data";
TableName : "Route Definition";
It will connect to an ODBC user or system data source called
Topological Data, and in that data source search for a table named
Route Definition.
The Owner attribute
The Owner attribute is for advanced use only. By default, when
connecting to a database server, you will have access to all tables and
stored procedures which are visible to you. In case a table name appears
more than once, but is owned by different users, by default a connection
is made to the table instance owned by yourself. By specifying the
Owner attribute you can gain access to the table instance owned by
the indicated user.
The Property attribute
With the Property attribute of a DatabaseTable you can specify
whether the declared table is ReadOnly. Specifying a database table
as ReadOnly will prevent you from inadvertently modifying its
content. If you do not provide this property, the database table will
default to read-write permissions unless the server does not allow write
access.
The Mapping attribute
By default, AIMMS tries to map the column names used in a database table
onto the AIMMS identifiers of the same name. Such an implicit mapping
is, of course, not always possible. When you link to an existing
database that was not specifically designed for your AIMMS application,
it is very likely that the column names do not correspond to the names
of your AIMMS identifiers. Therefore, the Mapping attribute lets you
override this default. The database columns explicitly mapped through
the Mapping attribute are added to the set of implicit mappings
constructed by AIMMS. The column names from the database table used in a
mapping list must be quoted. If the implicit mapping is not desirable
you can provide the property No Implicit Mapping.
Example
The following declarations demonstrate the use of mappings in a
DatabaseTable declaration. This example assumes the set and
parameter declarations of A Basic Example plus the existence of
the relation Routes given by
Set Routes {
SubsetOf : (Cities, Cities);
The following mapped database declaration will take care of the necessary column to identifier mapping.
Mapping : {
"from" --> i, ! name substitution
"to" --> j,
"dist" --> Distance(i,j),
"fcost" --> TransportCost(i,j,'fixed'), ! slicing
"vcost" --> TransportCost(i,j,'variable'),
("from","to") --> Routes ! mapping to relation
Name substitution
The first three lines of the Mapping attribute provide a simple name
translation from a column in the database table to an AIMMS identifier.
You can only use this type of mapping if the structural form of the
database table (i.e. the primary key) coincides with the domain of the
AIMMS identifier.
Mapping columns to slices
If the number of attributes in the primary key of a database table is
lower than the dimension of the intended AIMMS identifier, you can also
map a column name to a slice of an AIMMS identifier of the proper
dimension, as shown in the fcost and vcost mapping. You can do
this by replacing one or more of the indices in the identifier’s index
space with a reference to a fixed element.
Mapping primary key to relation
As shown in the last line of the Mapping attribute, you can let the
complete primary key in a database table correspond with a simple set,
or with a relation (see Relations) in AIMMS. This
correspondence is specified by mapping the tuple of primary attributes
of the table onto the AIMMS set itself, or onto an index into this set.
The primary attributes in the tuple are mapped in a one-to-one fashion
onto the indices in the relation.
Syntax
The syntax of the Mapping attribute is given by the following
diagram.
mapping-list:
The Convention attribute
With the Convention attribute you can indicate to AIMMS that the
external data is stored with the units provided in the specified
convention. If the unit specified in the convention differs from the
unit that AIMMS uses to store its data internally, the data is scaled at
the time of transfer. For the declaration of Conventions you are
referred to Globally Overriding Units Through Conventions.
Date conversions
In addition, you can use Conventions to convert calendar data from
the calendar slot format used within your model to the format expected
by the database and vice versa. The use of Conventions for this
purpose is discussed in full detail in Working in Multiple Time Zones. For
non-calendar related date-time values you can use the predefined
identifier OBDCDateTimeFormat to accomplish this (see
Dealing with Date-Time Values).
