Dealing with Date-Time Values
Mapping date-time values
Special care is required when you want to read data from or write data to a database which represents a date, a time, or a time stamp in the database table. The ODBC technology uses a fixed string format for each of these data types. Most likely, this format will not coincide with the format that you use to store dates and times in your modeling application.
Mapped onto calendars
When a column in a database table containing date-time values maps onto
a Calendar in your AIMMS model, AIMMS will automatically convert the
date-time values to the associated time slot format of the calendar, and
store the corresponding values for the appropriate time slots.
Time zone translation
By default, AIMMS assumes that the date-time values mapped onto a
particular CALENDAR are stored in the database according to the same
time zone (ignoring daylight saving time) as specified in the
TimeslotFormat attribute of that calendar (see also
Support for Time Zones and Daylight Saving Time). In the absence of such a time zone
specification, AIMMS will assume the local time zone (without daylight
saving time). You can override the time zone through the
TimeslotFormat attribute of a Convention. The use of
Conventions with respect to Calendar is discussed in full detail
in Working in Multiple Time Zones.
The ODBCDateTimeFormat parameter
If a date-time column in a database table does not map onto a
Calendar in your model, you can still convert the ODBC date-time
format into the date- or time representation of your preference, using
the predefined string parameter ODBCDateTimeFormat defined over the
set of AllIdentifiers. With it, you can specify, on a per identifier
basis, the particular format that AIMMS should use to store dates and/or
times using the formats discussed in Format of Time Slots and Periods. AIMMS will
never perform a time zone conversion for non-calendar data, and will
ignore ODBCDateTimeFormat when it contains a date-time format
specification for a CALENDAR.
Unmapped columns
If you do not specify a date-time format for a particular identifier,
and the column does not map onto a Calendar, AIMMS will assume the
fixed ODBC format. These formats are:
YYYY-MM-DD hh:mm:ss.tttttt for date-time columns,
YYYY-MM-DD for date columns, and
hh:mm:ss for time columns.
When you are unsure about the specific type of a date/time/date-time
column in the database table during a WRITE action, you can always
store the AIMMS data in date-time format, as AIMMS can convert these to
both the date and time format. During a READ action, AIMMS will
always translate into the type for the column type.
Example
A stock ordering model contains the following identifiers:
the set
Productswith indexp, containing all products kept in stock,an ordinary set
OrderDateswith indexd, containing all ordering dates, anda string parameter
ArrivalTime(p,d)containing the arrival time of the goods in the warehouse.
The order dates should be of the format ‘140319‘, whilst the
arrival times should be formatted as ‘12:30 PM‘ or
‘9:01 AM‘. Using the time specifiers of Format of Time Slots and Periods,
you can accomplish this through the following assignments to the
predefined parameter ODBCDateTimeFormat:
ODBCDateTimeFormat( 'OrderDates' ) := "%y%m%d";
ODBCDateTimeFormat( 'ArrivalTime' ) := "%h:%M %p";
