Indexed Database Tables
Exogenous columns in primary key
While the Mapping attribute allows you to map data columns in a
database table onto a slice of a higher-dimensional AIMMS identifier, a
different type of slicing is required when the primary key of a database
table contains exogenous columns that are of no interest to your
application. Consider, for instance, the following situations.
You are linking to a database table that contains data for a huge set of cities, but your model only deals with a single city that is not explicitly part of the model formulation. For your application the city column is exogenous.
A table in a database contains several versions of a particular data set, where the version number is represented by an additional version column in the table. For your application the version column is exogenous.
Indexed DatabaseTables
In your AIMMS application you can deal with these situations by
partitioning a single table inside the database into a set of virtual
lesser-dimensional tables indexed by the exogenous column(s). You can do
this by declaring the database table to have an IndexDomain
corresponding to the sets that map onto the exogenous columns. In
subsequent READ and WRITE statements you can then refer to a
particular instance of a virtual table through a reference to the
database table with an explicit set element or an element parameter.
Example
The following example assumes that the table "Route Definition"
contains several versions of the data, each identified by the value of
an additional column version. In the AIMMS model, this column is
associated with a set TableVersions given by the following
declaration.
Set TableVersions {
Index : v;
Parameter : LatestVersion;
The following declaration will provide a number of virtual tables
indexed by v.
DatabaseTable RouteData {
IndexDomain : v;
DataSource : "Topological Data";
TableName : "Route Definition";
Mapping : {
"version" --> v,
"from" --> i,
"to" --> j,
"dist" --> Distance(i,j),
"cost" --> TransportCost(i,j)
Note that the index v in the index domain is mapped onto the column
version in the table.
Data transfer with indexed tables
In order to obtain the set of TableVersions you can follow one of
two strategies:
you can obtain the set of the available versions from the table
"Route Definition"itself by declaring anotherDatabaseTablein AIMMSDatabaseTable VersionTable { DataSource : "Topological Data"; TableName : "Route Definition"; Mapping : { "version" --> TableVersions } }
or, you can obtain the versions from a separate table in a relational database declared similarly as above.
A typical sequence of actions for data transfer with indexed tables could then be the following.
Read the set of all possible versions from
VersionTable:read TableVersions from table VersionTable ;
Obtain the value of
LatestVersionfrom within the language or the graphical user interface.Read the data accordingly:
read Distance, TransportCost from RouteData(LatestVersion) ;
