Database Transactions
Transactions
By default, AIMMS places a transaction around any single WRITE
statement to a database table. In this way, AIMMS makes sure that the
complete WRITE statement can be rolled back in the event of a
database error during the execution of that WRITE statement. You can
increase the amount of transactional control over READ, WRITE
statements and SQL queries through the procedures
StartTransaction([isolation-level])
The procedure StartTransaction
With the procedure StartTransaction you can manually initiate a
database transaction. As a consequence, you can commit or roll back the
changes in the database caused by all WRITE statements and SQL
queries executed within the context of the transaction simultaneously.
You can specify the exact semantics of the transaction through its only
(optional) argument isolation-level, which must be an element from the
predefined set AllIsolationLevels. You cannot call
StartTransaction recursively, i.e. you must call
CommitTransaction or CallbackTransaction prior to the next call
to StartTransaction. The procedure returns a value of 1 if the
transaction was started successfully, or 0 otherwise.
The set AllIsolationLevels
Besides the ability to commit roll back all the changes made to the database during the transaction, AIMMS supports the following isolation levels for transactions:
ReadUncommitted: a transaction operating at this level can see uncommitted changes made by other transactions,ReadCommitted(default): a transaction operating at this level cannot see changes made by other transactions until those transactions are committed,RepeatableRead: a transaction operating at this level is guaranteed not to see any changes made by other transactions in values it has already read during the transaction, andSerializable: a transaction operating at this level guarantees that all concurrent transactions interact only in ways that produce the same effect as if each transaction were entirely executed one after the other.
Note that not all database servers may support all of these isolation
levels, and may cause the call to StartTransaction to fail.
The procedure CommitTransaction
Through the procedure CommitTransaction you can commit all the
changes that you have made to the database since the previous call to
StartTransaction. The function returns a value of 1 of the changes
are committed successfully, or 0 otherwise.
The procedure RollbackTransaction
With the procedure RollbackTransaction you can roll back (i.e. undo)
all the changes that you have made to the database since the previous
call to StartTransaction. The function returns a value of 1 of the
changes are rolled back successfully, or 0 otherwise.
