Working in Multiple Time Zones
Multiple time zones
If your application uses external time-dependent data supplied by users worldwide, you are faced with the problem of converting all dates and times to the calendar in which your application is set up to run. The facilities described in this section help you with that task.
Obtaining time zone info
With the functions TimeZoneOffset, DaylightSavingStartDate and
DayLightSavingEndDate you can obtain various time zone specific
characteristics.
TimeZoneOffset(FromTimeZone, ToTimeZone)DaylightSavingStartDate(year, TimeZone)DaylightSavingEndDate(year, TimeZone)
The function TimeZoneOffset returns the offset in minutes between
the time zones FromTimeZone and ToTimeZone. You can use the function
DaylightSavingStartDate and DaylightSavingEndDate to retrieve
the reference dates, within a particular time zone, corresponding to the
begin and end date of daylight saving time.
Example
offset := TimeZoneOffset('UTC', 'Eastern Standard Time');
! result: -300 [min]
startdate := DaylightSavingStartDate( '2001', 'Eastern Standard Time');
! result: "2001-04-01 02"
Converting reference dates
With the function ConvertReferenceDate you can convert reference
dates to different time zones. Its syntax is:
ConvertReferenceDate(ReferenceDate, FromTimeZone, ToTimeZone[, IgnoreDST])
With the function you can convert a reference date ReferenceDate, within the time zone FromTimeZone, to a reference date within the time zone ToTimeZone. If the optional argument IgnoreDST is set to 1, AIMMS will ignore daylight saving time for both input and output reference dates (see also Support for Time Zones and Daylight Saving Time). By default, AIMMS will not ignore daylight saving time.
Example
UTCdate := ConvertReferenceDate("2001-05-01 12", 'Local', 'UTC');
! result: "2001-05-01 11"
Conventions and time zones
When your application needs to read data from or write data to a
database or file with dates not specified in local time, some kind of
conversion of all dates appearing in the data source is required during
the data transfer. To support you with such date conversions, AIMMS
allows you to override the default timeslot format of one or more
calendars in your model through a unit Convention (see also
Globally Overriding Units Through Conventions).
The TimeslotFormat attribute
In the TimeslotFormat attribute of a Convention you can specify
the time slot format (see also Format of Time Slots and Periods) to be used for
each Calendar while communicating with an external source. The
syntax of the TimeslotFormat attribute is:
Syntax
timeslot-format-list:
Use in graphical user interface
When an active Convention overrides the time slot format for a
particular calendar, all calendar elements will be displayed according
to the time slot format specified in the Convention. The time slot
format specified in the calendar itself is then ignored.
Reading and writing to file
If you use a Convention to override the time slot format while
writing data to a data file, report file or listing file, AIMMS will
convert all calendar elements to the format specified in the
TimeslotFormat for that calendar in the Convention prior to
writing the data. Similarly, when reading data from a data file, AIMMS
will interpret the calendar slots present in the file according to the
specified time slot format, and convert them to the corresponding
calendar elements in the model.
Database communication…
When communicating calendar data to a database, there is one additional
issue that you have to take into account, namely the data type of the
column in which the calendar data is stored in the database table. If
calendar data is stored in a string column, AIMMS will transfer data
according to the exact date-time format specified in the
TimeslotFormat attribute of the Convention, including any
indicators for specifying the time zone and/or daylight saving time.
… for datetime columns
However, if the data type of the column is a special date-time data
type, AIMMS will always communicate calendar slots as reference dates,
which is the standard date-time string representation used by ODBC. In
translating calendar slots to reference dates, AIMMS will adhere to the
format specified in the TimeslotFormat attribute of either the
Calendar itself, or as overridden in the currently active
Convention.
Generated reference dates
The reference dates are generated according to the time zone specified
in the %TZ specifier of the currently active TIMESLOT SPECIFIER.
These dates always ignore daylight saving time (i.e. shift back by one
hour if necessary), as daylight saving time cannot be represented in the
fixed reference date format. Specifiers in the TIMESLOT FORMAT other
than the %TZ specifier are not used when mapping to date-time values
in a database. If you do not specify a %TZ specifier in the
TIMESLOT FORMAT, AIMMS will assume that all date-time columns in a
database are represented in the 'Local' time zone (the default).
Example
Consider the calendar HourCalendarLocalDST defined below.
Calendar HourCalendarLocalDST {
Index : hd;
Unit : hour;
BeginDate : "2001-03-25 00";
EndDate : "2001-03-25 06";
TimeslotFormat : "%c%y-%m-%d %H:00%TZ('LocalDST')|\"\"|\" DST\"|";
If you want to transfer data defined over this calendar with a database table in which all dates are represented in UTC time, you should define a convention defined as follows.
Convention UTCConvention {
TimeslotFormat : {
HourCalendarLocalDST : "%c%y-%m-%d %H:00%TZ('UTC')"
When this convention is active, AIMMS will represent all calendar slots
of the calendar HourCalendarLocalDST as reference dates according to
the UTC time zone, by shifting as many hours as dictated by the local
time zone and/or daylight saving time if applicable. Hence, when you use
the convention UTCConvention during data transfer with the database,
all calendar data slots will be in the expected format.
