Database Table Restrictions
Data transfer to single tables
The AIMMS READ and WRITE statements are intended to directly
transfer data to and from a single text or case file, or a single
table in a database. This is the simplest form of communication with a
database. If you need more advanced control over the connection with a
particular database, you can access stored procedures within the
database using AIMMS. Such procedures can be implemented by the database
designer to accomplish advanced tasks that go beyond the ordinary. The
use of stored procedures is discussed in
Executing Stored Procedures and SQL Queries.
Automatic connection
When you are connecting to a table in a database through a READ or
WRITE statement, you do not have to make a connection to the server
explicitly. The database table declaration and the ODBC configuration
files on your system provide sufficient information to allow AIMMS to
make the connection automatically whenever needed. If you need to log on
to the database, you will be prompted with a log on screen. On some
systems it is possible to store log on information in the ODBC data
source file.
Different data representation
There is a fundamental difference in the storage of data in AIMMS and the storage of data in a database table. Whereas AIMMS stores its data separately per identifier, a database table stores the data of several indexed identifiers in records all indexed by the same single index tuple. This difference implies that AIMMS has to impose some additional restrictions on data transfer with database tables that are not needed when reading from or writing to either AIMMS case files or text files.
Assumptions about database tables
In order to be able to define the semantics of the READ and
WRITE statements to database tables in an unambiguous way, AIMMS
makes a number of (reasonable) assumptions about the database tables in
an external database. It is, however, not always possible for AIMMS to
verify these assumptions, and unexpected effects may occur when they do
not hold. The following assumptions about database tables are made.
Every database table is in second normal form, i.e. every non-primary column in the table is functionally dependent on the primary key.
Every primary column in a database table is mapped onto an index in an AIMMS domain set.
Every non-primary column in a database table is mapped onto a (slice of an) AIMMS identifier, such that the specific index domain of this identifier precisely matches the primary key of the database table according to the existing index mapping.
Assumptions about identifier selections
AIMMS will not allow all identifier selections to be read from or written to database tables. An identifier selection is allowed when the following conditions hold for its components.
All parameter and variable references must have the same domain after slicing. The resulting domain must correspond to the primary key of the database table.
During a
WRITEstatement inREPLACEmode you can only write a simple set or relation mapped onto the primary key of a database table as long as there are no non-primary columns, or when the selection comprises all the columns of the table.AIMMS allows each domain set associated with a primary column in a table of any dimension to be read from that table.
Simply stated
The above rules can be summarized by stating that the database table can be transformed into an AIMMS composite table for the indexed identifiers in it.
Selections are sparse
Identifier selections in READ and WRITE statements form a
one-to-one correspondence with a sparse set of records in the database
table. During a READ statement the sparsity pattern is determined by
all the records in the database table. During a WRITE statement the
sparsity pattern is determined by all indexed identifiers in the
selection. Records will be written for only those tuples for which at
least one of the indexed identifiers or tuple references has a
nondefault value. Thus, the transferred data resulting from a WRITE
statement is equivalent to the single composite table in AIMMS for all
indexed identifiers in the selection.
Creation of records
Writing data to a database in either merge or replace mode may lead to the creation of new records in a database table. New records will be created when AIMMS writes a tuple for a key for which no record is available. If the table has non-primary attributes for which no data is written, AIMMS will leave these attributes empty when it creates new rows.
Removal of records: REPLACE COLUMNS/ROWS mode
AIMMS supports two replace modes for writing: REPLACE COLUMNS mode
(default) and REPLACE ROWS mode.
In
REPLACEorREPLACE COLUMNSmode, AIMMS will only remove data from columns mapped onto identifiers in your model. Rows will only be removed from the database table if all columns in the table are mapped onto identifiers in your model.In
REPLACE ROWSmode, AIMMS will remove all rows whose primary key does not correspond to an index tuple being written during theWRITEstatement. Columns that are not mapped onto identifiers in your model, either are assigned their default value specified in the database, or aNULLvalue otherwise. As a consequence, you should make sure that all non-nullable columns in the table are mapped onto identifiers in your model (or have a default value in the database) duringREPLACE ROWSmode.
AIMMS will only remove records if the selection you are writing comprises all the columns in the database table, including the set mapped onto the primary key. In this way, AIMMS ensures that no data is lost in the table inadvertently.
Filtering on records
Using the DatabaseTable interface it is only possible to filter
records using simple domain conditions formulated in a FILTERING
clause. For huge database tables it may be desirable to use more
advanced filtering techniques designed to restrict the number of records
to be transferred. This can be done inside the database application
itself in the following two ways.
Create a view in the database that does the filtering for you, and then use the standard
READstatement. This is the most straightforward approach, and is sufficient if the filter does not depend on AIMMS data.Create a stored procedure in the database that can be activated through a
DatabaseProcedurein AIMMS. This allows you to filter records dependent on the value of some AIMMS identifiers that are used as arguments of the stored procedure (see Executing Stored Procedures and SQL Queries).
