A Basic Example
Getting started
The aim of this section is to give you an overview of the READ and
WRITE statements through a short illustrative example. It shows how
to read data from and write data to text files and database tables. It
is based on the familiar transport problem with the following input
data:
the set
Cities,the relation
RoutesfromCitiestoCities,the parameters
Supply(i)andDemand(i)for each cityi, andthe parameters
Distance(i,j)andTransportCost(i,j)for each route between two citiesiandj.
For the sake of simplicity, it is assumed that there is only a single
output, the actual Transport(i,j) along each route.
Format of input data
The input data can be conveniently given in the form of tables. One for
the identifiers defined over a single city like Supply and
Demand, and the other for the identifiers defined over a tuple of
cities like Distance and TransportCost. These tables can be
provided in the form of text files as in Example data set for the transport model
(format explained in Composite Tables). Alternatively, the data
can be obtained from particular tables in a database. This example
assumes the following database tables exist:
CityDatafor the one-dimensional parameters, andRouteDatafor the two-dimensional parameters.
COMPOSITE TABLE
Cities Supply Demand
Amsterdam 50
Rotterdam 100
Antwerp 75 25
Berlin 125
Paris 75
COMPOSITE TABLE
i j Distance TransportCost
Amsterdam Rotterdam 85 1.00
Amsterdam Antwerp 170 2.50
Amsterdam Berlin 660 10.00
Amsterdam Paris 510 8.25
Rotterdam Antwerp 100 1.20
Rotterdam Berlin 700 10.00
Rotterdam Paris 440 7.50
Antwerp Berlin 725 11.00
Antwerp Paris 340 5.00
Berlin Paris 1050 17.50
Simple Data Transfer
Simple data initialization
The simplest use of the READ statement is to initialize data from a
fixed name text data file, or a database table.
To read all the data from each source, the
following groups of statements will suffice
read from file "transport.inp" ;
read from table CityData;
read from table RouteData;
Such statements are typically found in the body of the predefined
procedure MainInitialization.
Reading identifier selections
When a data source also contains data for identifiers that are of no
interest to your particular application (but may be to others), AIMMS
allows you to restrict the data transfer to a specific selection of
identifiers in that data source. For instance, the following READ
statement will only read the identifiers Distance and
TransportCost, not changing the current contents of the AIMMS
identifiers Supply and Demand.
read Distance, TransportCost from file "transport.inp" ;
Similar identifier selections are possible when reading from
a database table.
Writing the solution
After your model has computed the optimal transport, you may want to
write the solution Transport(i,j) to an text output file for future
reference. You can do this by calling the WRITE statement, which has
equivalent syntax to the READ statement. The transfer of
Transport(i,j) to the file transport.out is accomplished by the
following WRITE statement.
write Transport to file "transport.out" ;
If you omit an identifier selection, AIMMS will write all model data to the file. When writing to a database table, AIMMS can of course only transfer data for those identifiers that are known in the table that you are writing to.
File name need not be explicit
File data transfer is not restricted to files with a fixed name. To choose the name of the data file either during execution or from within the end-user interface, you have several options:
replace the filename string in the
READandWRITEstatements with a string-valued parameter holding the filename, oruse a
Fileidentifier (for text files only).
Set Initialization and Domain Checking
Domain restrictions
When you are reading the initial data of the transport model from an external data source several situations can occur:
you just want to initialize the set
Citiesfrom the data source,the set
Citieshas already been initialized, and you want to retrieve the parametric data for existing cities only, orthe set
Citieshas already been initialized, but you want to extend it on the basis of the data read from the external data source.
The READ statements
The following statements impose domain restrictions on the READ
statement.
read Cities
read Supply, Demand
filtering i ;
read Supply, Demand
Initializing sets
The first READ statement is a straightforward initialization of the
set Cities. By default, AIMMS reads in replace mode, which implies
that any previous contents of the set Cities is overwritten.
Domain checking
The second READ statement assumes that the set Cities has
already been initialized. From all entries of the identifiers Supply
and Demand it will only read those which correspond to existing
elements in the set Cities, and skip over the data from the
remaining entries.
Extending domain sets
The third READ statement differs from the second in that the clause
FILTERING i has been omitted. As a result, AIMMS will not reject
data that does not correspond to an existing label in the set
Cities, but will read all available Supply and Demand data,
and extend the set Cities accordingly.
