Format of Time Slots and Periods
Flexible time slot and period formats
While the BeginDate and EndDate attributes have to be specified
using the fixed reference date format (see Calendars),
AIMMS provides much more flexible formatting capabilities to describe
time slots in a
Calendarconsisting of a single basic time unit (e.g. 1-day time slots),time slots in a
Calendarconsisting of multiple basic time units (e.g. 3-day time slots), andperiods in a timetable consisting of multiple time slots.
The formatting capabilities described in this section are quite extensive, and allow for maximum flexibility.
Wizard support
In the Model Explorer, AIMMS provides a wizard to support you in constructing the appropriate formats. Through this wizard, you can not only select from a number of predefined formats (including some that use the regional settings of your computer), you also have the possibility of constructing a custom format, observing the result as you proceed.
Basic and extended format
AIMMS offers both a basic and an extended format for the description of time slots and periods. The basic format only refers to the beginning of a time slot or period. The extended format allows you to refer to both the first and last basic time unit contained in a time slot or period. Both the basic and extended formats are constructed according to the same rules.
Care is needed
The TimeslotFormat used in a Calendar must contain a reference
to either its beginning, its end, or both. As the specified format is
used to identify calendar elements when reading data from external data
sources such as files and databases, you have to ensure that the
specified format contains sufficient date and time references to
uniquely identify each time slot in a calendar.
Example
For instance, the description January 1 is sufficient to uniquely
identify a time slot in a calendar with a range of one year. However, in
a two-year calendar, corresponding days in the first and second year are
identified using exactly the same element description. In such a case,
you must make sure that the specified format contains a reference to a
year.
Building blocks
A format description is a sequence of four types of components. These are
predefined date components,
predefined time components,
predefined period references (extended format), and
ordinary characters.
Ordinary characters
Predefined components begin with the % sign. Components that begin
otherwise are interpreted as ordinary characters. To use a percent sign
as an ordinary character, escape it with another percent sign, as in
Date-specific Components
Date-specific components
The date-specific components act as conversion specifiers to denote portions of a date description. They may seem rather cryptic at first, but you will find them useful and constructive when creating customized references to time. They are summarized in this table.
Conversion specifier |
Meaning |
Possible entries |
day |
\(01,\dots,31\) |
month |
\(01,\dots,12\) |
month |
element |
year |
\(00,\dots,99\) |
quarter |
\(01,\dots,04\) |
weekyear |
\(00,\dots,99\) |
century |
\(00,\dots,99\) |
weekcentury |
\(00,\dots,99\) |
day of week |
\(1,\dots,7\) |
day of week |
element |
week of year |
\(01,\dots, 53\) |
day of year |
\(001,\dots,366\) |
Custom date-specific references
All date conversion specifiers allow only predefined numerical values,
except for the specifiers %Am and %Aw. These allow you to
specify references to sets. You can use %Am and %Aw to denote
months and days by the elements in a specified set. These are typically
the names of the months or days in your native language. AIMMS will
interpret the elements by their ordinal number. The predefined
identifiers AllMonths, AllAbbrMonths, AllWeekdays and
AllAbbrWeekdays hold the full and abbreviated English names of both
months and days.
Week year and century
The %Y and %C specifiers refer to the weekyear and weekcentury
values of a specific date, as explained on page
Day and week numbering. You can use these if you want to refer to
weekly calendar periods by their week number and year.
Omitting leading zeros
AIMMS can interpret numerical date-specific references with or without
leading zeros when reading your input data. When writing data, AIMMS
will insert all leading zeros to ensure a uniform length for date
elements. If you do not want leading zeros for a specific component, you
can insert the ‘s‘ modifier directly after the % sign. For
instance, the string %sd will direct AIMMS to produce single-digit
numbers for the first nine days.
Omitting trailing blanks
When using the %Am and %Aw specifiers, AIMMS will generate
uniform length elements by adding sufficient trailing blanks to the
shorter elements. As with leading zeros, you can use the s modifier
to override the generation of these trailing blanks.
Example
The format %Am|AllMonths| %sd, %c%y will result in the generation
of time slots such as 'January 1, 1996'. The date portion of the
fixed reference date format used to specify the Begin and
EndDate attributes of a calendar can be reproduced using the format
%c%y-%m-%d.
Time-specific Components
Time-specific components
The conversion specifiers for time components are listed in this table. There are no custom time-specific references in this table, because the predefined numerical values are standard throughout the world.
Meaning |
Possible entries |
hour |
\(01,\dots,12\) |
hour |
\(00,\dots,23\) |
minute |
\(00,\dots,59\) |
second |
\(00,\dots,59\) |
tick |
\(00,\dots,99\) |
before or after noon |
AM, PM |
AIMMS can interpret numerical time-specific references with or without
will insert leading zeros to ensure a uniform length for time elements.
If you do not want leading zeros for a specific component, you can
instance, the string %sh will direct AIMMS to produce single-digit
numbers for the first nine hours.
Example
The time slot format %sAw|WeekDays| %sh:%M %p will result in the
generation of time slots such as 'Friday 11:00 PM',
'Friday 12:00 PM' and 'Saturday 1:00 AM'. The full reference
date format is given by %c%y-%m-%d %H:%M:%S.
Period-specific Components
Use of period references
With period-specific conversion specifiers in either a time slot format or a period format you can indicate that you want AIMMS to display both the begin and end date/time of a time slot or period. You only need to use period-specific references in the following cases.
The
Unitattribute of your calendar consists of a multiple of one of the basic time units known to AIMMS (e.g. each time slot in your calendar consists of 3 days), and you want to refer to the begin and end day of every time slot.You want to provide a description for a period in a timetable consisting of multiple time slots in the associated calendar using the function
PeriodToString(see also Converting Time Slots and Periods to Strings), referring to both the first and last time slot in the period.
Period-specific components
By including a period-specific component in a time slot or period format, you indicate to AIMMS that any date, or time, specific component following it refers to either the beginning or the end of a time slot or period. The list of available period-specific conversion specifiers is given in this table.
Meaning |
begin of unit period |
begin of time slot |
end of period (inclusive) |
end of period (inclusive), but omitted when equal to begin of period |
end of period (exclusive) |
end of time slot |
Inclusive or exclusive
Through the %I and %E specifiers you can indicate whether
you want any date/ time components used in the description of the end of
a period (or time slot) to be included in that period or excluded from
it. Inclusive behavior is common for date references, e.g. the
description “Monday - Wednesday” usually means the period consisting of
Monday, Tuesday and Wednesday. For time references exclusive behavior
is used most commonly, i.e. “1:00 - 3:00 PM” usually means the period
from 1:00 PM until 3:00 PM.
Limited resolution
After a conversion specifier that refers to the end of a period or time
slot (i.e. %E, %I or %i) you should take care when
using other date, or time, specific specifiers. AIMMS will only be able
to discern time units that are larger than the basic time unit specified
in the Unit attribute of the calendar at hand (or, when you use the
function PeriodToString, of the calendar associated with the
timetable at hand). For instance, when the time slots of a calendar
consists of periods of 2 months, AIMMS will be able to distinguish the
specific months at the beginning and end of each time slot, but will not
know the specific week number, week day or month day at the end of each
time slot. Thus, in this case you should avoid the use of the %W,
the %w and the %d specifiers after a %E, %I or
%i specifier.
The %i specifier
With the %i specifier you indicate inclusive behavior, and
additionally you indicate that AIMMS must omit the remaining text when
the basic time units (w.r.t. the underlying calendar) of begin and end
slot of the period to which the specifier is applied, coincide. In
practice, the %i specifier only makes sense when used in the
function PeriodToString (see also Converting Time Slots and Periods to Strings), as time
slots in a calendar always have a fixed length.
First example
The period description Monday 12:00-15:00 contains three logical
references, namely to a day, to the begin time in hours, and to the end
time in hours. The day reference is intended to be shared by the begin
and end times.
The day reference is based on the elements of the (predefined) set
AllWeekdays. The corresponding conversion specifier is%Aw|AllWeekDays|The descriptions of the begin and end times both use the conversion specifier
%H:%M. To denote the begin time of the period you must use the%Bperiod reference. For the end time of the period, which is not included in the period, you must use%E.
By combining these building blocks with a few ordinary characters you
get the complete format string %Aw|AllWeekDays| %B%H:%M-%E%H:%M.
With this string AIMMS can correctly interpret the element
Monday 12:00-15:00 within a calendar covering no more than one
week.
Second example
Consider the format “%B%Aw|AllWeekDays|%I -
%Aw|AllWeekDays|” within a calendar with day as its basic time
unit, and covering at most a week. Using this format string AIMMS will
interpret the element Monday - Wednesday as the three-day period
consisting of Monday, Tuesday, and Wednesday.
Support for Time Zones and Daylight Saving Time
Support for daylight saving time
When your time zone has daylight saving time, and you are working with time slots or periods on an hourly basis, you may want to include an indicator into the time slot or period format to indicate whether daylight saving time is active during a particular time slot or period. Such an indicator enables you, for instance, to distinguish between the duplicate hour when the clock is set back at the end of daylight saving time.
Support for time zones
In addition, when your application has users located in different time zones, you may wish to present each user with calendar elements corresponding to their particular time zone. Or, when time-dependent data is stored in a database using UTC time (Universal Time Coordinate, or Greenwich Mean Time), a translation may be required to your own local time representation.
AIMMS support
To support you in scenarios as described above, AIMMS provides
a special time zone conversion specifier, which can modify the representation of calendar elements based on specified time zone and daylight saving time, and
a
TimeslotFormatattribute in unitConventions(see also Globally Overriding Units Through Conventions), which you can use to override the time slot format of every calendar when theConventionis active.
Time zone specifier
With the conversion specifier %TZ, described in
this table, you can accomplish the following
Calendar-related tasks:
create the
Calendarelements between the givenBeginDateandEndDaterelative to a specified time zone, andspecify the indicators that must be added to the
Calendarelements when standard or daylight saving time is active.
Meaning |
translation of calendar element to specified TimeZone, ignoring daylight saving time |
translation of calendar element to specified TimeZone, plus string indicator for standard time (Std) and daylight saving time (Dst) |
Specifying the time zone
The TimeZone component of the %TZ conversion specifier that you
must specify, is a time zone corresponding to the elements in your
Calendar. You must specify the time zone as an explicit and quoted
element of the predefined set AllTimeZones (explained below), or
through a reference to an element parameter into that set. If you do not
specify the Std and Dst indicators, AIMMS will ignore daylight
saving time when generating the time slots, regardless whether daylight
saving time is defined for that time zone. If you do not use the %TZ
specifier to specify a time zone, AIMMS assumes that you intend to use
the local time zone without daylight saving time.
The set AllTimeZones
AIMMS provides you access to all time zones defined by your operating
system through the predefined set AllTimeZones. The set
AllTimeZones contains
the fixed element
'Local', representing the local time zone without daylight saving time,the fixed element
'LocalDST', representing the local time zone with daylight saving time (if applicable),the fixed element
'UTC', representing the Universal Time Coordinate (or Greenwich Mean Time) time zone, andall time zones defined by your operating system.
Daylight saving time indicators
The remaining components of the %TZ specifier are two string
indicators Std and Dst, which are displayed in all generated
Calendar slots or period strings when standard time (i.e. no
daylight saving time) or daylight saving time is active, respectively.
Both indicators must be either quoted strings, or references to scalar
string parameters. In addition, a run time error will occur when both
indicators evaluate to the same string.
Effect on time slots
When you use the %TZ specifier, the date and time components of the
generated time slots of a calendar may differ when you specify different
time zones, but do not modify the reference dates specified in the
BeginDate and EndDate attributes of the calendar. AIMMS always
assumes that reference dates are specified in local time without
daylight saving time (i.e. in the 'Local' time zone). Hence, all
time slots will be shifted by the time differences between the specified
time zone and the 'Local' time zone, plus any additional difference
caused by daylight saving time.
Examples
Consider the following four Calendar declarations.
Calendar HourCalendarLocal {
Index : hl;
Unit : hour;
BeginDate : "2001-03-25 00";
EndDate : "2001-03-25 06";
TimeslotFormat : "%c%y-%m-%d %H:00";
Calendar HourCalendarLocalIgnore {
Index : hi;
Unit : hour;
TimeslotFormat : "%c%y-%m-%d %H:00%TZ('LocalDST')";
Calendar HourCalendarLocalDST {
Index : hd;
Unit : hour;
TimeslotFormat : "%c%y-%m-%d %H:00%TZ('LocalDST')|\"\"|\" DST\"|";
Calendar HourCalendarUTC {
Index : hc;
Unit : hour;
TimeslotFormat : "%c%y-%m-%d %H:00%TZ('UTC')|\"\"|\" DST\"|";
Assuming that the 'Local' time zone has an offset of \(+1\)
hours compared to the 'UTC' time zone, this will result in the
generation of the following time slots for each of the calendars
! HourCalendarLocal HourCalendarIgnore HourCalendarLocalDST HourCalendarUTC
'2001-03-25 00:00' '2001-03-25 00:00' '2001-03-25 00:00' '2001-03-24 23:00'
'2001-03-25 01:00' '2001-03-25 01:00' '2001-03-25 01:00' '2001-03-25 00:00'
'2001-03-25 02:00' '2001-03-25 02:00' '2001-03-25 03:00 DST' '2001-03-25 01:00'
'2001-03-25 03:00' '2001-03-25 03:00' '2001-03-25 04:00 DST' '2001-03-25 02:00'
'2001-03-25 04:00' '2001-03-25 04:00' '2001-03-25 05:00 DST' '2001-03-25 03:00'
'2001-03-25 05:00' '2001-03-25 05:00' '2001-03-25 06:00 DST' '2001-03-25 04:00'
'2001-03-25 06:00' '2001-03-25 06:00' '2001-03-25 07:00 DST' '2001-03-25 05:00'
Note that the time slots generated for HourCalendarLocal and
HourCalendarIgnore are identical (although 'LocalDST' supports
daylight saving time). This is because daylight saving time is ignored
when the %TZ specifier has no Std and Dst indicators. The time
slots generated for HourCalendarUTC do not contain the specified
daylight saving time indicator, because the 'UTC' time zone has no
