Scheduling Problems
Introduction
Resource-constrained scheduling is a key application area of constraint
programming. Most constraint programming systems contain special
syntactical constructs to formulate such problems, allowing the use of
specialized inference algorithms. In Constraints in Constraint Programming we have already
seen two examples of global constraints for scheduling:
cp::SequentialSchedule and cp::ParallelSchedule. For more
complex scheduling problems that contain, for example,
sequence-dependent setup times between activities, or specific
precedence relations, the use of more advanced scheduling algorithms is
advisable. These algorithms cannot be offered by the stand-alone global
constraints cp::SequentialSchedule and cp::ParallelSchedule, but
can be accessed by formulating the problem using activities and
resources in AIMMS.
Activities
Activities correspond to the execution of objects in scheduling problems, e.g., processing an order, working a shift, or performing a loading operation. They can be viewed as the variables of a scheduling problem, since we must decide on their position in the schedule. Common attributes associated to an activity are its begin, end, length, and size. Further, it is often convenient to distinguish mandatory and optional activities, which allows to consider the presence of an activity. In AIMMS, the properties begin, end, length, size, and presence of an activity can be used as variables in other parts of the model. It is also possible to build models using nested activities, where meta-activities group together a number of sub-activities, for example in the context of project planning.
Resources
Resources correspond to the assets that are available to execute the activities, e.g., the capacity of a machine, the volume of a truck, or the number of available employees. Resources can be viewed as the constraints of a scheduling problem. The main attributes of a resource are its capacity, its activity level, and the set of activities that require the resource in order to be executed. That is, during the execution of the schedule, we must ensure that the resource activity level is always within its capacity. Note that while a resource depends on a set of activities, an activity can impact on one or more resources at the same time.
An activity changes the resource activity level
A resource starts with a default activity level of 0, corresponding to full available capacity, or a user-specified initial value. During the execution of the schedule, activities will influence the resource activity level. The viewpoint chosen in AIMMS is that an activity changes the activity level of a resource when it begins, and/or when it ends. This enables one to model many common situations. For example, when an activity corresponds to a loading operation, and the resource corresponds to a truck load, the activity will change the activity level of the resource with the volume of the load at its start, but there is no change in the resource activity level when finishing this activity. For sequential resources the capacity is \(1\), and each activity will change the resource activity level by \(+1\) when it begins, and by \(-1\) when it ends. For example, when an activity corresponds to a visit operation, and the resource corresponds to a truck, the activity level of the resource will be decreased by 1 at the beginning of the visit, and increased by 1 at the end.
Schedule domains
The timeline on which activities are scheduled, is the so-called schedule domain. A schedule domain is a finite set of timeslots. Each activity and resource has its own schedule domain.
The problem schedule domain
The schedule domain of the entire problem, the problem schedule domain, is a named superset of each of these schedule domains. Unless overridden, it is based on the schedule domains of the activities and resources.
Handling schedule domains
An activity is only considered active during a timeslot \(t\) if \(t\) is in the schedule domain of that activity, and it is in the schedule domain of each resource for which it is scheduled. Thus, for each individual activity, AIMMS passes the intersection of these schedule domains to the constraint programming solver.
Additional restrictions
Most scheduling problems contain several side constraints in addition to the resource constraints. Examples include precedence relations between activities, release dates or deadlines, and sequence-dependent setup times. Such constraints can be specified using global scheduling constraints or in the attribute forms of activities and resources. Constraint programming solvers can take an extra algorithmic advantage of such constraints when they are presented in this manner.
Activity
On the one hand, an activity can be seen as consisting of five variables
that can be accessed by the suffixes: .Begin, .End, .Length,
.Size and .Present. These variables represent the begin, end,
length (difference between end and begin), size (number of active slots)
and presence of an activity. These variables can be used inside
constraints, for example myActivity.End <= myDeadLine+1. On the
other hand, an activity is defined using its attributes as presented in
this table. We will first discuss the attributes
of an activity, and then these suffixes in more detail.
Attribute |
Value-type |
See also page |
index-domain |
set range or expression |
expression |
expression |
reference |
string |
comment string |
The ScheduleDomain attribute
The activity is scheduled in time slots in the ScheduleDomain. This
is an expression resulting in a one-dimensional set, or a set-valued
range. The resulting set need not be a subset of the predeclared set
Integers; it can be any one-dimensional set, for instance a
Calendar, see Calendars. Consider the following
examples of the attribute schedule domain:
Activity a {
ScheduleDomain : yearCal;
Comment : {
"a can be scheduled during any period
in the calendar yearCal"
Activity b {
IndexDomain : i;
ScheduleDomain : possiblePeriods(i);
Comment : {
"b(i) can be scheduled only during the
periods possiblePeriods(i)"
Activity c {
IndexDomain : i;
ScheduleDomain : {
{ReleaseDate(i)..PastDeadline(i)}
Comment : {
"c(i) must start on or after ReleaseDate(i)
c(i) must finish before PastDeadline(i)"
The ScheduleDomain attribute is mandatory.
Singleton schedule domain
An activity with a singleton schedule domain and a length of 1 can be
used to model an event. Such an activity is scheduled during the single
element in the schedule domain. Because the schedule domain is a single
element, the value of the suffixes .Begin and .End of the
activity will be set to that single element and the element thereafter
respectively in a feasible solution. Note that this is possible for all
elements except for the last element in the problem schedule domain; a
nonzero length would then require the .End to be after the problem
schedule domain. Consider the following example:
Activity weekendActivities {
IndexDomain : {
d | ( TimeslotCharacteristic( d, 'weekday' ) = 6 or
TimeslotCharacteristic( d, 'weekday' ) = 7 ) and
d <> last( dayCalendar )
ScheduleDomain : {
{ d .. d }
Length : 1;
Comment : "d is an index in a calendar""}
Scheduling the activity weekendActivities in a sequential resource
will block other activities for that resource during the weekend.
The Property attribute
An activity can have the properties Optional, Contiguous and
NoSave.
OptionalWhen an activity has the property
Optional, it may or may not be scheduled. If the propertyOptionalis not specified, then the activity will always be scheduled.ContiguousWhen an activity has the property
Contiguous, all elements from.Beginup to but not including.Endin the problem schedule domain must be in its own schedule domain.NoSaveWhen an activity has the property
NoSave, it will not be saved in cases.
This attribute is not mandatory.
The Length and Size attributes
When an activity is present, the Length attribute defines the length
of the activity, and the Size attribute defines its size. The length
of an activity is the difference between its end and its begin. The size
of an activity is the number of periods, in which that activity is
active from begin up to but not including its end. For example, a
non-contiguous activity which .Begins on Friday, .Ends on
Tuesday, and is not active during the weekend has a
.Lengthof 4 days, and.Sizeof 2 days.
The numeric expressions entered at the Length and Size
attributes may involve other discrete variables. These attributes are
not mandatory.
For a contiguous activity we have that the .Length is equal to the
.Size. Conversely, with a constraint a.Length=a.Size we have
that a is contiguous, but the propagation may be less efficient.
The Priority attribute
The Priority attribute applies to all the discrete variables defined
by an activity. To these variables it has the same meaning as for
integer variables, see page The Priority attribute. This attribute is
not mandatory.
The suffixes of activities
An activity is made up of the following suffixes .Begin, .End,
.Length, .Size and .Present. Each of these suffixes is a
discrete variable and can be used in constraints.
The suffixes .Begin and .End
The suffixes .Begin and .End are element valued variables. When
scheduled, the activity takes place from period .Begin up to but not
including period .End. For a present activity a, in a feasible
solution:
a.Beginis an element in the schedule domain of the activity. The range of this element variable is the smallest named set encompassing the activity schedule domain.a.Endis an element in the schedule domain of the problem, and, depending on the.Lengthofa, with the following additional requirement:When the length of activity
ais zero,a.End=a.Beginholds, and they are both in the activity schedule domain.When the length of activity
ais greater than 0, the element beforea.Endis in the activity schedule domain.
The range of this element variable is the root set of the activity schedule domain.
Comparison of the .Begin and .End suffixes of two activities
a and b inside a constraint definition will take place on the
problem schedule domain, for instance in a constraint like
a.End <= b.Begin. Outside constraint definitions these suffixes
follow the rules of element comparison specified in
Set and Element Comparison.
The suffixes .Length and .Size
The suffixes .Length and .Size are nonnegative integer
variables. The .Length of an activity is defined as .End -
.Begin. The .Size of an activity is the number of timeslots in
the schedule domain of the activity in the range [.Begin, .End).
When the attribute Length or Size is non-empty, AIMMS will
generate a defining constraint for the suffix .Length resp.
.Size like the definition attribute of a variable, see
The Definition attribute. When the schedule domain of an activity is a
calendar or a subset thereof, the unit of each of the .Length and
.Size suffixes is the unit of the calendar.
The suffix .Present
The suffix .Present is a binary variable with default 0. For
optional activities this variable is 1 when the activity is scheduled
and 0 when it is not. For non-optional activities this variable is
initialized with the value 1.
suffixes of absent activities in constraints
The value of one of the suffixes .Begin, .End, .Length, and
.Size is not defined when the corresponding activity is absent.
However, in order to satisfy constraints where such a suffix is used for
an absent activity, a value is chosen: the socalled absent value. For
the suffixes .Length, and .Size, the absent value is 0. For the
suffixes .Begin and .End this depends on the problem schedule
domain:
If the problem schedule domain is a subset of
Integers, the absent value is 0.Otherwise, the absent value of the suffixes
.Beginand.Endis".
To override the absent value use one of the following functions:
Suffixes of optional activities in constraints
The value of the suffix .present is defined for an absent activity
as 0. However the values of the other suffixes of an absent activity are
not defined. To enable the constraining of the values of those suffixes
in constraints several formulation alternatives are available. As an
example of these alternatives, consider an activity act whereby we
want to enforce its length to be 7 if it is present.
Enforce the length constraint conditionally on the presence of activity
act:if act.present then act.length = 7 endif
The
cp::ActivityLengthfunction returns the length of a present activity or its second argument if it is not present:cp::ActivityLength( act, 7 ) = 7
If we simply want to set the value of the
.Lengthor.Sizesuffix, we can use theLengthorSizeattribute as follows.Activity act { ScheduleDomain : ...; Property : optional; Length : 7; }
Each of the above formulation alternatives has its own merits.
The merit of this alternative is that it is general and can also be used to state for instance that the length of
actis 7 or 11 when present:if act.present then act.Length = 7 or act.Length = 11 endif
The merit of this alternative is that it allows the solver to make stronger propagations and thus potentially reduce solution time.
The merit of this alternative is that is does not force the model builder to take the optionality of
actinto account when defining its length. AIMMS will make sure the length definition is translated to alternative 1 or 2 as appropriate.
Solution values of absent activities
The value of the suffixes .Begin, .End, .Length, and
.Size of an absent activity in a feasible schedule are meaningless
and should not be used in further computations.
Absent versus 0-length activities
Even though no work is done for both absent and 0-length activities, there is a difference in their usage. Let us consider the following two examples:
Selection of an activity from alternatives; Consider a collection of activities from which we need to select one. This is easily and efficiently achieved by setting the property
Optionalto the activity. The ones not selected become absent in a solution.Consider two collections of activities, whereby the \(n\) activities in the first collection all need to be completed before the \(m\) activities in the second collection can start. We can model this directly by \(n\times{}m\) precedence constrains. Another way to model this is by introducing an extra activity, say
Milestone, of length zero. With thisMilestonewe only need \(n+m\) precedence constraints.
To facilitate above and other examples of scheduling, the suffixes
.Present and .Length are supported independently.
Relation between suffixes of activities
Please note, for an activity act, the following relation is
implicitly defined:
if act.Present then
act.Begin + act.Length = act.End
endif
if act.Present then
act.Size <= act.Length
endif
Resource
A resource schedules activities by acting as a constraint on the activities it schedules. A feasible resource requires the above implicit constraints on the suffixes of the activities it schedules and the constraints implied by its attributes as discussed below.
Attribute |
Value-type |
See also page |
index-domain |
collection of activities |
a reference to a set |
activity : expression |
index domain : expression |
set of reference pair : expression |
reference |
reference |
set of reference pairs |
unit-valued expression |
numeric range |
reference |
per activity : expression |
string |
comment string |
A resource is defined using the attributes presented in this table.
The Usage attribute
A resource can be used in two ways: Parallel, and Sequential, of
which precisely one must be selected. The resource usage is then as
follows
SequentialDefines the resource to be used sequentially. Such a resource is also known as a unary or disjunctive resource. A sequential resource has the additional attributes
Transition,FirstActivity,LastActivity,ComesBefore, andPrecedes, see Sequential Resources.ParallelDefines the resource to be used in parallel. Such a resource is also known as a cumulative resource. A parallel resource has the additional attributes
LevelRange,InitalLevel,LevelChange,BeginChange, andEndChange, see Parallel Resources.
The Usage attribute is mandatory; either Sequential or
Parallel must be selected.
The resource is affected by activities during the periods set in its schedule domain. This is an expression resulting in a one-dimensional set, or a set-valued range. AIMMS verifies that the schedule domain of the resource matches the schedule domain of all activities it is affected by. Here, two sets match if they have a common super set.
When the intersection of the schedule domain of a resource and the schedule domain of a non-optional activity are empty, the result is an infeasible schedule.
The Activities attribute
The Activities attribute details the activities affecting the
resource. This adheres to the syntax:
activity-selection:
as illustrated in the example below:
Resource myMachine {
ScheduleDomain : H;
Usage : ... ! sequential or parallel;
Activities : {
maintenance, ! Maintenance is scheduled between actual jobs.
simpleJob(i), ! Every simple job can be done on this machine.
specialJob(j) : jobpos(j) ! Only selected special jobs are allowed.
In this example, the activities maintenance and simpleJob can
affect the resource myMachine. However, the activity
specialJob(j) can only affect the resource when jobpos(j) is
non-zero. Only the detailed activities can be used in the attributes
that follow. The Activities attribute is mandatory.
A resource can have the properties: NoSave and
TransitionOnlyNext.
When the property
NoSaveis set, this indicates that the resource data will not be saved in cases.The property
TransitionOnlyNextis relevant to the attributesTransitionandGroupTransitionof sequential resources only, and is discussed after theGroupTransitionattribute below.
The attribute Property is not mandatory.
Sequential resources
Sequential resources are used to schedule activities that are not
allowed to overlap. Those workers and machines that can only handle one
activity at a time are typical examples. A sequential resource has only
one suffix, namely .ActivityLevel. A sequential resource is active
when it is servicing an activity, and then its .ActivityLevel is
1. When a sequential resource is not active, or idle, its
.ActivityLevel is 0. The attributes particular to sequential
resources are discussed below. The .ActivityLevel suffix cannot be
used in constraint definitions.
The Transition attribute
The Transition attribute is only available to sequential resources,
and then only if the GroupSet attribute has not been specified. This
attribute contains a matrix between activities a and b,
specifying the minimal time between a and b if a is
scheduled before b. One example of using this attribute is to model
traveling times, when jobs are executed at different locations. Another
example of using this attribute is to model cleaning times of a paint
machine, when the cleaning time depends on the color used during the
previous job. All entries of this matrix are assumed to be 0 when not
specified. If the schedule domain is a calendar, the unit of measurement
is the time unit of the schedule domain; otherwise the unit of
measurement is unitless. This matrix can, but need not, be symmetric. In
the constraint programming literature, this attribute is also called
sequence-dependent setup times or changeover times. The syntax for
this attribute is as follows:
activity-transition:
An example of a transition specification is:
ScheduleDomain : H;
Usage : sequential;
Activities : acts(a), maintenance;
Transition : {
(acts(a1),acts(a2)) : travelTime(a1,a2),
(maintenance,acts(a1)) : travelTime('home',a1),
(acts(a1),maintenance) : travelTime(a1,'home')
Comment : {
"activities acts are executed on location/site; yet
maintenance is executed at home. Transitions are
the travel times between locations."
The Transition attribute is not mandatory.
The GroupSet attribute
The GroupSet attribute is only available to sequential resources.
The elements of this set name the groups into which the activities can
be divided. This attribute is not mandatory.
The GroupDefinition attribute
The GroupDefinition attribute is only available when the
GroupSet attribute has been specified. It contains a mapping of
activities to group set elements. This mapping is essential for the
GroupTransition attribute and for the intrinsic functions
cp::GroupOfNext and cp::GroupOfPrevious. The syntax is as
follows:
group-definition:
This attribute is mandatory when the GroupSet attribute has been
specified.
The GroupTransition attribute
The GroupTransition attribute is used to specify the transition
times/sequence dependent setup times between activities in a compressed
manner. This attribute is only available when the GroupSet attribute
has been specified. The syntax is:
activity-group-transition:
Consider an application where each city has to be visited by a car on multiple occasions, to bring goods being produced in one city to another city where they are consumed. The first product is consumed before the last product is produced:
Activity VisitCity {
IndexDomain : (car,city,iter);
ScheduleDomain : Timeline;
Property : Optional;
Resource carEnRoute {
Usage : sequential;
IndexDomain : car;
ScheduleDomain : TimeLine;
Activities : VisitCity(car,city,iter);
GroupSet : Cities;
GroupDefinition : VisitCity(car,city,iter) : city;
GroupTransition : (cityFrom,cityTo) : CityDistance(cityFrom,cityTo);
In this example, the group transition matrix is defined for each
combination of cities, which is significantly smaller than an equivalent
transition matrix defined for each possible combination of activities
would have been. This not only saves memory, but may also save a
significant amount of solution time as some Constraint Programming
solvers check whether the triangular inequality holds at the start of
the solution process in order to determine the most effective reasoning
available to that solver. The GroupTransition attribute is not
mandatory.
Property TransitionOnlyNext
The attributes Transition and GroupTransition specify the
minimal time between two activities a1 and a2 if a1 comes
before a2. By specifying the property TransitionOnlyNext, these
attributes are limited to specify only the minimal distances between two
activities a1 and a2 if a1 precedes a2. An activity
a1 precedes a2, if there is no other activity b scheduled
between a1 and a2. In the example that follows, a, b,
and c are all activities of length 1.
Resource seqres {
Usage : sequential;
ScheduleDomain : timeline;
Activities : a, b, c;
Property : TransitionOnlyNext;
Transition : (a,b):1, (b,c):1, (a,c):7;
Precedes : (a,b), (b,c);
Minimizing c.End, the solution is:
a.Begin := 0 ; a.End := 1 ;
b.Begin := 2 ; b.End := 3 ;
c.Begin := 4 ; c.End := 5 ;
By omitting the TransitionOnlyNext property, the minimal distance
between a and c is taken into account, and the solution becomes:
c.Begin := 8 ; c.End := 9 ;
The Sequencing attributes
The attributes FirstActivity, LastActivity, ComesBefore, and
Precedes are collectively called sequencing attributes. They are
used to place restrictions on the sequence in which the activities are
scheduled. These attributes are only available to sequential resources.
FirstActivityWhen specified, this has to be a reference to a single activity. When this activity is present, it will be the first activity in a feasible solution.
LastActivityWhen specified, this has to be a reference to a single activity. When this activity is present, it will be the last activity in a feasible solution.
ComesBeforeThis is a list of activity pairs
(a,b). A pair(a,b)in this list indicates that activityacomes before activitybin a feasible solution. There may be another activitycthat is scheduled betweenaandbin a feasible solution. This constraint is only enforced when bothaandbare present.PrecedesThis is a list of activity pairs
(a,b). A pair(a,b)in this list indicates that activityaprecedes activitybin a feasible solution. There can be no other activitycscheduled betweenaandbin a feasible solution, but a gap betweenaandbis allowed. This constraint is only enforced when bothaandbare present.
The syntax of the attributes FirstActivity and LastActivity is
simply a reference to a single activity and so the syntax diagram is
omitted here. The syntax diagram for the attributes ComesBefore and
Precedes is more interesting:
activity-sequence:
If, following the above syntax diagram, an expression is omitted, it is taken to be 1. An example illustrating all the sequencing attributes is presented below:
ScheduleDomain : H;
Usage : sequential;
Activities : setup(a), finish(a);
FirstActivity : setup('warmingUp');
LastActivity : finish('Cleaning');
ComesBefore : (setup(a1),setup(a2)) : taskbefore(a1,a2);
Precedes : (setup(a),finish(a));
None of the sequencing attributes are mandatory.
Parallel Resources
Parallel resources model and limit the resource consumption and resource production of activities that take place in parallel. Examples of parallel resources could be monetary budget and truck load.
A parallel resource has only one suffix, namely .ActivityLevel. This
suffix is only affected by scheduled activities. The limits on the
.ActivityLevel suffix, its initialization, and how it is affected by
executed activities is discussed below in the parallel resource specific
attributes.
The LevelRange attribute
The LevelRange attribute states the range for the activity level of
a parallel resource. The maximum value represents the capacity of the
resource. It cannot be specified per element in the schedule domain of
the resource. The syntax of this attribute is similar to the syntax of
the Range attribute for bounded integer variables.
IndexDomain : m;
ScheduleDomain : h;
Usage : parallel;
Activities : act(a);
LevelRange : {
{minlev(m) .. maxlev(m)}
The LevelRange attribute is only applicable for parallel resources,
and for such a resource it is mandatory.
The InitialLevel attribute
The InitialLevel attribute defines the initial value of the
.ActivityLevel suffix. if it is not specified, the
.ActivityLevel suffix is initialized to 0. The InitialLevel
Resource AvailableBudget {
ScheduleDomain : Hor;
Usage : parallel;
LevelRange : {0 .. 10000};
InitialLevel : 5000;
Comment : "we have a starting budget of 5000""}
The .ActivityLevel modification attributes
The attributes LevelChange, BeginChange, and EndChange are
collectively called .ActivityLevel modification attributes.
An activity in the
LevelChangeattribute generates a pulse: at the.Beginof the activity the.ActivityLevelof the resource is increased by the indicated amount; at the.Endof the activity that suffix is decreased by the same amount.An activity in the
BeginChangeattribute increases the.ActivityLevelof the resource at the.Beginof the activity by the indicated amount.An activity in the
EndChangeattribute increases the.ActivityLevelof the resource at the.Endof the activity by the indicated amount.
Note that not only can the indicated amount be a positive or negative
integer, it can also be an integer variable. The effect of an activity
on the .ActivityLevel is illustrated in the
Fig. 9. The syntax of these
attributes is as follows:
level-modification:
Fig. 9 Changes to the suffix .ActivityLevel of a resource
The next example illustrates the use of the .ActivityLevel
modification attributes:
Resource Budget {
ScheduleDomain : Days;
Usage : parallel;
Activities : Act(i), Alt_Act(j), Deposit_Act(d);
LevelRange : [0, 100];
LevelChange : Alt_Act(i) : -alt_act_budget(i);
BeginChange : {
Deposit_Act(d): Deposit(d),
Act(i) : -ActCost(i)
EndChange : Act(i) : Profit(i);
In this example, Deposit_Act can be modeled as an activity with a
schedule domain containing only one element (an event), see
Singleton schedule domain. None of the
.ActivityLevel modification attributes are mandatory, but when none
of them is specified the resource is either infeasible or ineffective.
When the .ActivityLevel is outside the range of a parallel resource,
that resource is infeasible.
Activity level and schedule domain
The .ActivityLevel suffix is not affected by holes in the schedule
domain of scheduled activities.
Fig. 10 illustrates the effect of
activities A and B with a level change of 1 on the resource
cash. The activity A has its .Begin set to Friday, its
.End set to Tuesday and it is not scheduled in the weekend. The
activity B is scheduled in the weekend.
Fig. 10 Two activities scheduled on a parallel resource
Functions on Activities and Scheduling Constraints
Precedence constraints
The suffixes of an activity are variables, and they can be used in the
formulation of constraints. Below there follows an example of a simple
linear constraint which states that at least a pause of length
restTime should be observed after activity a is completed before
activity b can start.
a.End + restTime <= b.Begin
Precedence on optional activities
Consider again the inequality above, but now for optional activities
a and b. When a is absent, the minimum value of a.End is
meaningless but its minimum is 0 and b is present, this will enforce
b to start after restTime. This may or may not be the intended
effect of the constraint. Enforcing such constraints only when both
activities a and b are present, the scheduling constraint
cp::EndAtStart(a,b,restTime) can be used. This constraint is
semantically equivalent to:
if a.Present and b.Present then
a.End + restTime = b.Begin
endif
Here restTime is an integer valued expression that may involve
variables. Note that the scheduling constraint can be exploited more
effectively during the solving process than the equivalent algebraic
formulation. A list of available scheduling constraints for precedence
relations is given in
this table.
Precedence Relations |
When activities \(a\) and \(b\) are present |
and for a non-negative integer delay \(d\) |
\(a{\texttt{.Begin}} + d \leq b{\texttt{.Begin}}\) |
\(a{\texttt{.Begin}} + d \leq b{\texttt{.End}}\) |
\(a{\texttt{.End}} + d \leq b{\texttt{.Begin}}\) |
\(a{\texttt{.End}} + d \leq b{\texttt{.End}}\) |
\(a{\texttt{.Begin}} + d = b{\texttt{.Begin}}\) |
\(a{\texttt{.Begin}} + d = b{\texttt{.End}}\) |
\(a{\texttt{.End}} + d = b{\texttt{.Begin}}\) |
\(a{\texttt{.End}} + d = b{\texttt{.End}}\) |
Scheduling Constraints |
Interpretation |
The activity \(g\) spans the activities \(a_i\) |
\(g{\texttt{.Begin}} = \min_i a_i{\texttt{.Begin}} \wedge\) |
\(g{\texttt{.End}} = \max_i a_i{\texttt{.End}}\) |
Activity \(g\) is the single selected activity \(a_i\) |
\(\exists j: g=a_j \wedge \forall k, j\neq k: a_k{\texttt{.present}}=0\) |
If \(g\) is present, all present activities \(a_i\) |
are scheduled at the same time. |
\(g{\texttt{.present}} \Rightarrow (\forall i: a_i{\texttt{.present}} \Rightarrow g=a_i\)) |
Limiting activity suffixes taking absence into account |
\(a\) is the activity |
\(d\) the absence value |
Return begin of activity |
Return end of activity |
Return length of activity |
Return size of activity |
Adjacent Activity |
\(r\) is the resource |
\(s\) is the scheduled activity |
\(e\) is extreme value (when \(s\) is first or last) |
\(a\) is absent value (\(s\) is not scheduled) |
Beginning of next activity |
Beginning of previous activity |
End of next activity |
End of previous activity |
Group of next activity, see also The GroupDefinition attribute |
Group of previous activity |
Length of next activity |
Length of previous activity |
Size of next activity |
Size of previous activity |
Global scheduling constraints
In addition to these precedence constraints and the constraints that are
defined by resources, AIMMS offers several other global constraints that
are helpful in modeling scheduling problems.
this table
presents the global scheduling constraints and functions available in
AIMMS. These constraints are based on activities and can be used to
represent hierarchical planning problems (cp::Span), to schedule
activities over alternative resources (cp::Alternative), and to
synchronize the execution of multiple activities (cp::Synchronize).
Functions on activities
There are several functions available that provide control over the value to be used for the suffixes of activities in the case of absence. In addition, there are functions available for relating adjacent activities on a resource. this table lists the functions available that operate on activities. As an example, consider a model whereby the length of two adjacent jobs is limited:
Set Timeline {
Index : tl;
Set Jobs {
Index : j;
Parameter JobLen {
IndexDomain : j;
Activity doJob {
IndexDomain : j;
Length : Joblen(j);
Resource aWorker {
Usage : sequential;
Activities : doJob(j);
Constraint LimitLengthTwoAdjacentJobs {
IndexDomain : j;
Definition : {
cp::ActivityLength(doJob(j),0) +
cp::LengthOfNext(aWorker,doJob(j)) <= 8
In the constraint LimitLengthTwoAdjacentJobs we take the length of
job via the function cp::ActivityLength and the length of the next
job for resource aWorker via the function cp::LengthOfNext. In
the above constraint, the use of the function cp::ActivityLength is
not essential because activity doJob is not optional. We can use the
suffix notation instead and the constraint becomes:
IndexDomain : j;
Definition : {
doJob(j).Length +
Problem Schedule Domain
The problem schedule domain of a mathematical program is a single named
set containing all timeslots referenced in the activities, resources and
timeslot valued element variables of that mathematical program. For the
activities to be scheduled, we are usually interested in when they take
place in real time; the mapping to real time is an ingredient of the
solution. An exception might be if we are interested in the process of
scheduling instead of its results. In that case, a contiguous subset of
the Integers suffices. Contiguous subsets of Integers are
supported by AIMMS, but not considered in the remainder of this
subsection.
Real world representations
The problem schedule domain represents the period of time on which activities are to be scheduled. This portion of time is discretized into timeslots. Consider the following three use cases for a problem schedule domain.
The first use case is probably the most common one; the distance in time between two consecutive timeslots is constant. This distance is equal to a single unit of time. As an example, consider an application that constructs a maintenance scheme for playing fields. Two consecutive line painting activities should not be scheduled too close or too far from each other. Similarly for other consecutive activities of the same type such as garbage pickup. In this use case the distance in time between two consecutive timeslots is meaningful. A
Calendaris practical for this use case.The second use case is the one in which the distance in time between two consecutive timeslots is not constant. As an example, consider an application that constructs a sequence of practice meetings for teams with a limited number of playing fields available. The set of available dates is based on the team member availability, and the distance in time between two consecutive time slots may vary. An important restriction for this application is that two meetings with the same type of practice should be some number of meetings apart. In addition, we want to avoid, for each team, peaks and big holes in exercise dates by limiting the number of exercise dates skipped between two consecutive exercises.
The third use case is a combination of the other two use cases. The problem schedule domain is again one whereby the distance in time between two consecutive timeslots is constant. In addition, there are subsets of this problem schedule domain which apply to selected activities and resources. As an example, consider an application that schedules both maintenance activities and team practice sessions on a set of playing fields.
The above use cases are illustrated in AIMMS below.
Use case 1: constant distance
In the first use case as illustrated by the example below, the problem
schedule domain is the calendar yearCal. Two consecutive timeslots
in that calendar have the fixed distance of 1 day. The activity
FieldMaintenance models that there are various types of maintenance
activities to be scheduled for the various fields, and each type of
maintenance may occur more than once. The two constraints in this
example restrict the minimal and maximal distance between consecutive
maintenance activities of the same type on the same field.
Calendar yearCal {
Index : d;
Unit : day;
BeginDate : "2012-01-01";
EndDate : "2012-12-31";
TimeslotFormat : "%c%y-%sm-%sd";
Activity FieldMaintenance {
IndexDomain : (pf, mt, occ);
Length : 1[day];
Comment : {
"Maintenance on
playing field pf
maintenance type mt
occurrence occ"
Constraint maintenanceMinimalDistance {
IndexDomain : (pf, mt, occ) | occ <> first( occurrences );
Text : "at least 7 days apart.";
Definition : {
cp::BeginBeforeBegin( FieldMaintenance(pf, mt, occ-1),
FieldMaintenance(pf, mt, occ), 7 )
Constraint maintenanceMaximalDistance {
Text : "at most 14 days apart.";
Definition : {
cp::BeginBeforeBegin( FieldMaintenance(pf, mt, occ),
FieldMaintenance(pf, mt, occ-1), -14 )
Use case 2: varying distance
For the second use case, the same calendar yearCal is declared as in
the first use case, in order to relate to real time. We are interested
in only a selection of the dates available, and a subset exerciseCal
is created from this calendar. In order to remove the fixed distance
from the timeslots, the elements in exerciseCal are copied to
exerciseDates.
Calendar yearCal {
Set exerciseCal {
SubsetOf : yearCal;
Index : yc;
Set exerciseDates {
Index : ed;
Comment : "Constructed in ...""}
A simple way of copying the elements with their names from
exerciseCal to exerciseDates is in the code fragment below.
Empty exerciseDates ;
for yc do
exerciseDates += StringToElement(exerciseDates,
formatString("%e",yc), create:1 );
endfor ;
Now that we have the set of exercise dates without a time unit associated, we can use it to declare exercise activities for each team and enforce a minimal distance between exercises of the same type as illustrated below. This minimal distance will now be enforced using a sequential resource and counting the number of times a particular exercise type occurred.
Set exerciseTypes {
Index : et;
Activity gExerciseTeam {
IndexDomain : (tm,occ);
ScheduleDomain : exerciseDates;
Length : 1;
Comment : {
"occ in Occurrencs, defining the number of times
team tm has to exercise"
Resource teamExercises {
Usage : sequential;
IndexDomain : tm;
Activities : gExerciseTeam(tm, occ);
Precedes : (gExerciseTeam(tm, occ1),gExerciseTeam(tm, occ2)):occ1=occ2-1;
Comment : "Purpose: determine when a team may exercise""}
Activity exerciseTeam {
IndexDomain : (tm,et,occ);
Length : 1;
Constraint oneExerciseType {
Definition : {
cp::Alternative(
globalActivity : gExerciseTeam(tm, occ),
activityBinding : et,
subActivity : ExerciseTeam(tm, et, occ))
Comment : "Purpose: select a single type of exercise""}
Constraint doingAnExerciseTypeAtMostOnceOverOccurrences {
IndexDomain : (tm,et,occ) | occ <> first( occurrences );
Definition : {
sum( occ1 | occ1 <= occ and occ1 < occ + 2,
ExerciseTeam(tm, et, occ).Present ) <= 1
Comment : {
"Purpose: the same type of exercise should be some
exercises apart"
Constraint avoidSmallHolesBetweenExercises {
IndexDomain : (tm,occ) | occ <> first( occurrences );
Text : "at least minHoleSize exercise dates apart.";
Definition : {
cp::EndBeforeBegin( gExerciseTeam(tm, occ-1),
gExerciseTeam(tm, occ), minHoleSize )
Constraint avoidBigHolesBetweenExercises {
Text : "at most maxHoleSize exercise dates apart.":
Definition : {
cp::BeginBeforeEnd( gExerciseTeam(tm, occ),
gExerciseTeam(tm, occ-1), -maxHoleSize )
Use case 3: combination
There can be only one problem schedule domain per mathematical program; we use the one from the first use case as it encompasses the one from the second use case. Thus we need to adapt the schedule domains of selected activities and resources to the following:
ScheduleDomain : exerciseCal ! modified;
Length : 1[day] ! modified;
Resource OneExercise {
Usage : sequential;
IndexDomain : tm;
The constraints oneExerciseType and
doingAnExerciseTypeAtMostOnceOverOccurrences can be left unchanged
as they are not dependent on the distance between timeslots. The
constraints avoidSmallHolesBetweenExercises and
avoidBigHolesBetweenExercises is dependent on the distance between
elements of exerciseDates and will now have to be remodeled. By
using the fact that the .Size refers to the number of elements in
the schedule domain of an activity between its .Begin and .End
and that we can define an activity that encompasses a hole by spanning
the previous exercise and the current one, the remodeling is done as
follows:
Activity encompassHoleBetweenExercises {
IndexDomain : (tm,occ)|occ <> first(occurrences);
ScheduleDomain : exerciseCal;
Constraint defineEncompassHoleBetweenExercises {
IndexDomain : (tm,occ)|occ <> first(Occurrences);
Definition : {
cp::Span(
globalActivity : encompassHoleBetweenExercises(tm, occ),
activityBinding : occ1 | occ1 = occ or occ1 = occ-1,
subActivity : gExerciseTeam(tm, occ1))
Constraint maxSizeEncompassingActivity {
Definition : {
encompassHoleBetweenExercises(tm,occ).size <=
(maxHoleSize + 2)[day]
Constraint minSizeEncompassingActivity {
Definition : {
encompassHoleBetweenExercises(tm,occ).size >=
(minHoleSize + 2)[day]
comparing use cases 2 and 3
Only when the distance in real time is not relevant to an application, the representation chosen for use case 2 has the following advantages over the representation chosen for use case 3:
The limiting of the size of a hole is formulated more directly using the
cp::EndBeforeBeginandcp::BeginBeforeEndthan one using an additional activity leading to a formulation that is easier to understand.We not only lose the power of propagation provided by the global constraints
cp::EndBeforeBeginandcp::BeginBeforeEndin use case 3, but we also introduce another activity, and thus additional variables, which increases the search space thereby decreasing the perfomance further.The set
exerciseDatesis smaller than the setyearCal. It is generally a good idea to keep the sets used as ranges for element variables small including the schedule domain to be considered.
This concludes the discussion on multiple use cases for problem schedule domains.
The attribute ScheduleDomain of a mathematical program
When an application contains activities, the attribute
ScheduleDomain becomes available to a mathematical program declared
in that application. Unlike the attribute with the same name for
activities and resources, only a single named one-dimensional set can be
filled in here. If this attribute is filled in, with, say Timeline,
then AIMMS will ensure that each activity and resource has a schedule
domain that is a subset of Timeline. In addition, for each element
variable with a range say, selectedMoments, where Timeline and
selectedMoments have the same root set, AIMMS will verify that
selectedMoments is a subset of Timeline. In addition, the
problem schedule domain, say Timeline, has to meet one of the
following three requirements:
Timelineis a true subset of the setIntegers. In order to make references forward and backward in time unambiguous, it is required thatTimelineis contiguous.Timelineis a subset of a calendar. Again, in order to make references forward and backward in time unambiguous, it is required thatTimelineis contiguous.Timelineis not a subset ofIntegersnor a subset of a calendar. No additional requirements are placed onTimeline.
Deriving the problem schedule domain
If this attribute is not filled in, then AIMMS will derive the problem schedule domain by finding the smallest common superset of the schedule domains of the activities and resources of the mathematical program. If this set is not a calendar, but a subset thereof, AIMMS chooses to use the calendar instead. This is motivated by the assumption that the length between timeslots is usually relevant in scheduling applications. In scheduling applications in which the subset is more appropriate, copying the elements of a calendar provides an alternative, as illustrated above.
