Constraint Programming Essentials
Variables
In constraint programming, models are built using variables and constraints, and as such is similar to integer programming. One fundamental difference is that, in integer programming, the range of a variable is specified and maintained as an interval, while in constraint programming, the variable range is maintained explicitly as a set of elements. Note that in the constraint programming literature, the range of a variable is commonly referred to as its domain.
Constraints
As a consequence of this explicit range representation, constraint programming can offer a wide variety of constraint types. Most constraint programming solvers allow constraints to be defined by arbitrary expressions that combine algebraic or logical operators. Moreover, meta-constraints can be formulated by interpreting the logical value of an expression as a boolean value in a logical relation, or as a binary value in an algebraic relation. For example, to express that every two distinct tasks \(i\) and \(j\), from a set of tasks \(T\) with respective starting times \(s_i,s_j\) and durations \(d_i, d_j\), should not overlap in time, we can use logical disjunctions:
As another example, we can set a restriction such that no more than half the variables from \(x_1, \dots, x_n\) are assigned to a specific value \(v\) as \(\sum_{i=1}^n (x_i = v) \leq 0.5n\).
Global constraints
In addition, constraint programming offers special symbolic constraints
that are called global constraints. These constraints can be defined
over an arbitrary set of variables, and encapsulate a combinatorial
structure that is exploited during the solving process. The constraint
cp::AllDifferent\((x_1 \dots, x_n)\) is an example of such a
global constraint. This global constraint requires the variables
\(x_1 \dots, x_n\) to take distinct values.
Solving
The solving process underpinning constraint programming combines systematic search with inference techniques. The systematic search implicitly enumerates all possible variable-value combinations, thus defining a search tree in which the root represents the original problem to be solved. At each node in the search tree, an inference is made by means of domain filtering and constraint propagation. Each constraint in the model has an associated domain filtering algorithm that removes provably inconsistent values from the variable domains. Here, a domain value is inconsistent if it does not belong to any solution of the constraint. The updated domains are then communicated to the other constraints, whose domain filtering algorithms in turn become active; this is the constraint propagation process. In practice, the most effective filtering algorithms are those associated with global constraints. Therefore, most practical applications that are to be solved with constraint programming are formulated using global constraints.
Application domains
Constraint programming can be particularly effective with highly combinatorial problem domains, such as timetabling or resource-constrained scheduling. For such problems an integer programming model may be non-intuitive to express. Moreover, the associated continuous relaxation may be quite weak, which makes it much harder to find a provably optimal solution. For example, again consider two tasks \(A\) and \(B\) that must not overlap in time. In integer programming one can introduce two binary variables, \(y_{AB}\) and \(y_{BA}\), representing that task \(A\) must be processed either before or after, task \(B\). The non-overlapping constraint can then be expressed as \(y_{AB} + y_{BA} = 1\), for which a continuous linear relaxation may assign a solution \(y_{AB} = y_{BA} = 0.5\), which is not very informative. In contrast, the non-overlapping requirement can be handled very effectively using a specific ‘sequential resource’ scheduling constraint in constraint programming that effectively groups together all pairwise logical disjunctions in (12) above. Such a constraint is also referred to as a disjunctive or unary constraint in the constraint programming literature.
Designing models
The expressiveness of constraint programming offers a powerful modeling
environment, albeit one that comes with a caveat. Namely, that different
syntactically equivalent formulations may yield quite different solving
times. For example, an alternative to the constraint
cp::AllDifferent\((x_1, x_2, \dots, x_n)\) is its
decomposition into pairwise not-equal constraints \(x_i \neq x_j\)
for \(1
\leq i < j \leq n\). The domain filtering algorithm for
cp::AllDifferent provably removes more inconsistent domain values
than the individual not-equal constraints, which results in much smaller
search trees and faster solution times. Therefore, when designing a
constraint programming model, one should be aware of the effect that
different formulations can have on the solving time. In most situations,
it is advisable to apply global constraints to exploit their algorithmic
power.
Variables in Constraint Programming
Variables of a constraint program
A constraint programming problem is made up of discrete variables and constraints over these discrete variables. A discrete variable is a variable that takes on a discrete value.
AIMMS supports two base types of discrete variables for constraint
programming. The first type of variable is the integer variable; an
ordinary variable with a range formulated such as {a..b} where a
and b are numbers or references to parameters (see Variable and Constraint Declaration).
Such variables can also be used in MIP problems. The second type of
variable is the element variable, which will be further detailed in this
section. This type of variable can only be used in a constraint
programming problem. These two types of variable can be combined in a
third type, called an integer element variable, which supports the
operations that are defined for both the integer variable and the
element variable.
ElementVariable Declaration and Attributes
An element variable is a variable that takes an element as its value. It
can have the attributes specified in
this table. The attributes
IndexDomain, Priority, NonvarStatus, Text, Comment
are the same as those for the variables introduced in Variable and Constraint Declaration.
Attribute |
Value-type |
See also |
index-domain |
named set |
constant-expression |
The Parameter Default attribute, The Variable Default attribute |
expression |
expression |
string |
comment string |
expression |
The Range attribute
The range of an element variable is a one-dimensional set, similar to the range of an element parameter. This attribute must be a set identifier; and this permits the compiler to verify the semantics when element variables are used in expressions. This attribute is mandatory.
The Default attribute
The attribute default of an element variable is a quoted element.
This attribute is not mandatory.
The Definition attribute
The Definition attribute of an element variable is similar to the
definition attribute of a variable, see also
page The Definition attribute, except that its value is an element and
the resulting element must lie inside the range of the element variable.
The Property attribute
The following properties are available to element variables:
- Nosave
When set, this property indicates that the element variable is not to be saved in cases.
- EmptyElementAllowed
‘ When set, this property indicates that in a feasible solution, the value of this variable can, but need not, be the empty element
". When the range of the element variable is a subset of the setIntegers, this property is not available. In the following example, for the element variableeV, not selecting an element fromS, is a valid choice, but this choice forces the integer variableXto 0.ElementVariable eV { Range : S; Property : EmptyElementAllowed; } Constraint Force_X_to_zero_when_no_choice_for_eV { Definition : if eV = '' then X = 0 endif; }
Element translation
Constraint programming solvers only use integer variables, and AIMMS
translates an element variable, say eV with range the set S
containing \(n\) elements into a integer variable, say v, with
range \(\{ 0 .. n-1\}\). By design, this translation leaves no room
for the empty element ", and subsequently, in a feasible solution,
the empty element is no part of it. In order to permit the explicit
consideration of the empty element as part of a solution, the property
EmptyElementAllowed can be set for eV. In that case the range of
v is \(\{ 0 .. n\}\) whereby the value 0 corresponds to the
empty element.
Selecting a Variable Type
Choosing variable type
When there are multiple types of objects, such as integer variables and element variables in AIMMS, the following two questions naturally arise:
How to choose between the various types?
Can these types be combined?
The answers to these questions are as follows:
You may want to base the choice of types of variables on the operations that can be performed meaningfully on these types. Which operation is appropriate for which variable type is described below.
An identifier can have both the ‘integer variable’ and ‘element variable’ types and is then called an ‘integer element variable’. This is created as an element variable with a named subset of the predeclared set
Integersas its range.
Operations on variables
The operations on variables that are interesting in constraint programming are:
Numeric operations, such as multiplication, addition, and taking the absolute value. These operations are applicable to integer variables and to integer element variables.
Index operations; selecting an element of an indexed parameter or variable. An element variable
eVcan be an argument of a parameterPor a variableXin expressions such asP(eV)orX(eV). These operations are applicable to all element variables. In the Constraint Programming literature, such operations are often implemented using so-called element constraints.Compare, subtract, min and max operations. These operations are applicable to all discrete variables, including element variables. For element variables, AIMMS uses the ordering of sets, see Set Declaration and Attributes.
All of the above operations are available with integer element variables.
Contiguous range
In order to limit an element variable to a contiguous subset of its
named range, element valued suffixes .lower and .upper can be
used. In the example below, the assignment to eV.Lower restricts the
variable eV to the contiguous set {c..e}.
Set someLetters {
Definition : data { a, b, c, d, e };
Range : someLetters;
Procedure Restrict_eV {
Body : eV.lower := 'c';
The specification of non-contiguous ranges, informally known as ranges with holes, is detailed in the next subsection.
Constraints in Constraint Programming
Introduction
The constraints in constraint programming allow a rich variety of restrictions to be placed on the variables in a constraint program, ranging from direct domain restrictions on the variables to global constraints that come with powerful propagation algorithms.
Domain restrictions
A domain restriction restricts the domain of a single variable, or of
multiple variables, and is specified using the IN operator. For
example, we can restrict the domain of an element variable eV as
follows:
Constraint DomRestr1 {
Definition : eV in setA;
When we apply the IN operator to multiple variables, we can define a
constraint by explicitly listing all tuples that are allowed. For
example:
Constraint DomRestr2 {
Definition : (eV1, eV2, eV3) in ThreeDimRelation;
Comment : "ThreeDimRelation contains all allowed tuples""}
Constraint DomRestr3 {
Definition : not( (eV1, eV2, eV3) in ComplementRelation );
Comment : "ComplementRelation contains all forbidden tuples""}
In constraint DomRestr2 above, the three element variables are
restricted to elements from the set of allowed tuples defined by
ThreeDimRelation. Alternatively, we can define such a restriction
using the complement, i.e., a list of forbidden tuples, as with
constraint DomRestr3. In constraint programming, these constraints
are also known as Table constraints; the data for these constraints
resemble tables in a relational database.
Algebraic restrictions
The following operations are permitted on discrete variables, resulting in expressions that can be used in constraint programming constraints:
The binary
min(a,b),max(a,b)and the iterativemin(i,x(i)),max(i,x(i))can both be used,multiplication
*, addition+, subtraction-, absolute valueabsand squaresqr,integer division
div(a,b), integer modulomod(a,b),floating point division
/, andindexing: an element variable is used as an argument of another parameter or variable,
P(eV),V(eV),
Note that the operation must be meaningful for the variable type, see Operations on variables.
These expressions can be compared, using the operators <=, <,
=, <>, >, and >= to create algebraic restrictions.
Simple examples of algebraic constraints, taken from Einstein’s Logic
Puzzle, are presented below.
Constraint Clue15 {
Definition : abs( Smoke('Blends') - Drink('Water') ) = 1;
Comment : "The man who smokes Blends has a neighbor who drinks water.""}
Constraint TheQuestion {
Definition : National(eV)=Pet('Fish');
Comment : "Who owns the pet fish? Result stored in element variable eV""}
Combining restrictions
The constraints above can be combined to create other constraints called
meta-constraints. Meta-constraints can be formed by using the scalar
operators AND, OR, XOR, NOT and IF-THEN-ELSE-ENDIF.
For example:
Constraint OneTaskComesBeforeTheOther {
Definition : {
( StartA + DurA <= StartB ) or
( StartB + DurB <= StartA )
In addition, restrictions can be combined into meta-constraints using
the iterative operators FORALL and EXISTS. Moreover,
restrictions can be counted using the iterative operator SUM and the
result compared with another value. Finally, meta-constraints are
restrictions themselves, they can be combined into even more complex
meta-constraints. The following example is a variable definition, in
which the collection of constraints (Finish(i) > Deadline(i)) is
used to form a meta-constraint.
Variable TotalTardinessCost {
Definition : Sum( i, TardinessCost(i) | ( Finish(i) > Deadline(i) ) );
In the following example, the binary variable y gets the value 1 if
each X(i) is greater than P(i).
Constraint Ydef {
Definition : y = FORALL( i, X(i) > P(i) );
From the Steel Mill example, we can model that we do not want more than two colors for each slab by the following nested usage of meta-constraints:
Constraint EnhancedColorCst {
IndexDomain : (sl);
Definition : sum( c, EXISTS (o in ColorOrders(c), SlabOfOrder(o)=sl)) <= 2;
Global constraints
AIMMS supports the global constraints presented in this table. These global constraints come with powerful filtering techniques that may significantly reduce the search tree and thus the time needed to solve a problem.
Global constraint |
Meaning |
The \(x_i\) must have distinct values. \(\forall i,j| i \neq j: x_i \neq x_j\) |
The number of \(x_i\) related to \(c\) is \(y\). \(\sum_i (x_i=c) \otimes y\) where \(\otimes \in \{\leq, \geq, =, >, <, \neq\}\) |
The number of \(x_i\) equal to \(c_j\) is \(y_j\). \(\forall j: \sum_i (x_i=c_j) = y_j\) |
The number of \(x_i\in S\) for each subsequence of length \(q\) is between \(l\) and \(u\). \(\forall i=1..n-q+1:\) \(l \leq \sum_{j=i}^{i+q-1} (x_j\in S) \leq u\) |
Channel variable \(x_i\to J\) to \(y_j\to I\) \(\forall i,j: x_i=j \Leftrightarrow y_j=i\) |
\(x\) is lexicographically before \(y\) \(\exists i: \forall j<i: x_j=y_j \wedge x_i<y_i\) |
Assign object \(j\) of known size \(s_j\) to bin \(a_j \to I\). Size of bin \(i \in I\) is \(l_i\). \(\forall i: \sum_{j \mid a_j = i} s_j \leq l_i\) |
The example below illustrates the use of the global constraint
cp::AllDifferent as used in the Latin square completion problem. A
Latin square of order \(n\) is an \(n\times n\) matrix where the
values are in the range \(\{1..n\}\) and distinct over each row and
column.
Constraint RowsAllDifferent {
IndexDomain : r;
Definition : cp::AllDifferent( c, Entry(r, c) );
Constraint ColsAllDifferent {
IndexDomain : c;
Definition : cp::AllDifferent( r, Entry(r, c) );
Additional examples of global constraints are present in the AIMMS Function Reference. Unless stated otherwise in the function reference, global constraints can also be used outside of constraints definitions, for example in assignments or parameter definitions.
Global constraint vector arguments
These global constraints have vectors as arguments. The size of a vector
is defined by a preceding index binding argument. Further information on
index binding can be found in the Chapter on Index Index Binding.
Such a vector can be a vector of elements, for example the fourth
argument of cp::Cardinality. In a vector of elements, the empty
element " is not allowed; comparison of an element variable against
the empty element is not supported.
Basic scheduling constraints
AIMMS offers support for both basic scheduling and advanced scheduling. Advanced scheduling will be detailed in the next section but, for basic scheduling, AIMMS offers the following two global constraints:
The global constraint
cp::SequentialSchedule(\(j\), \(s_j\), \(d_j\), \(e_j\)) ensures that two distinct jobs do not overlap where job \(j\) has start time \(s_j\), duration \(d_j\) and end time \(e_j\). This constraint is equivalent to:\(\forall i,j,i \neq j:(s_i+d_i\leq s_j) \vee (s_j + d_j \leq s_i)\).
\(\forall j: s_j + d_j = e_j\)
This and similar constraints are also known as
unaryordisjunctiveconstraints within the Constraint Programming literature.The global constraint
cp::ParallelSchedule(\(l\), \(u\), \(j\), \(s_j\), \(d_j\), \(e_j\), \(h_j\)) allows a single resource to handle multiple jobs, within limits \(l\) and \(u\), at the same time. Here job \(j\) has start time \(s_j\), duration \(d_j\), end time \(e_j\) and resource consumption (height) \(h_j\). This constraint is equivalent to:\(\forall t: l\leq\sum_{j|s_j\leq{}t<e_j} h_j\leq u\).
cumulativeconstraints within the Constraint Programming literature.
