Modeling, Solving and Searching
Introduction
In this section we explain how constraint programming models are formulated and solved in AIMMS. We start by explaining how constraint programming formulations are fit into the paradigms of AIMMS like the free objective and units of measurement. We then explain the different mathematical programming types associated to constraint programming, and finally we discuss how a user can modify the search procedure in AIMMS.
The free objective
By design, the objective of any mathematical program in AIMMS is a
free variable, even when it can be deduced that the objective function
is always integer valued for a feasible solution. However, for an
infeasible solution, AIMMS will assign the special value NA to the
objective variable, in order to emphasize that a feasible solution is
not available. Having a single variable for the objective function is
convenient when communicating its value in the progress window and other
places of AIMMS.
Constraint Programming and Units of Measurement
Integer coefficients only
Constraint programming solvers require the coefficients used in
constraints to be integer; fractional values or special values such as
-inf, zero, na, undf, or inf are not allowed. In
applications where the choice of base units is free, fractional values
are easily avoided by choosing the base unit of quantities, and the
units of variables and constraints such that all amounts to be
considered are integer multiples of those base units, as detailed in
Unit-based Scaling of Mathematical Programs. As an example, consider a simple constraint
stating that the integer variable y is 0.9[m] away from the integer
variable x. Both variables are multiples of the derived unit dm,
i.e., 0.1[m]. The variables and constraints are declared as follows:
Variable x {
Range : integer;
Unit : dm;
Variable y {
Range : integer;
Unit : dm;
Constraint y_away_from_x {
Unit : dm;
Definition : y = abs( x - 0.9[m] );
Using the unit m as a base unit, this will lead to fractional
values, as can be seen in the constraint listing:
y_away_from_x .. [ 1 | 1 | before ]
y =
abs((x-0.9)) ****
name lower level upper scale
x 0 0 21474836470.000 0.100
y 0 0 21474836470.000 0.100
The coefficient for distance, 0.9[m], is in meters and the variables
x and y have the same units inside the row. This row is scaled
back to dm afterwards. As a result of all this scaling, the
computations go from the domain of integer arithmetic into the domain of
floating point arithmetic. For constraint programming, we need to avoid
the domain of floating point arithmetic.
Adapted base unit
We will continue the above example, by adapting the base unit such that
all amounts are integral multiples of that base unit; we select dm
as a base unit. This will lead to the following row communicated to the
solver:
y =
abs((x-9)) ****
x 0 0 2147483647
y 0 0 2147483647
Observe that scaling is not needed anymore. Using the scaling based on
dm instead of m will keep all computations during the solution
process in the domain of integer arithmetic.
Quantity based scaling
In the example of the previous paragraph, the base unit was adapted to
the needs of constraint programming; namely to stay within the domain of
integer arithmetic. For multi-purpose applications, freedom of choosing
the base units of quantities according to the needs of a constraint
programming problem is not always available. In order to stay within the
domain of integer arithmetic, we can associate a convention with the
mathematical program and filling in the per quantity attribute, see
also Globally Overriding Units Through Conventions. By filling in the per quantity
attribute, AIMMS will generate the mathematical program where all
coefficients are scaled with respect to the units specified in the
per quantity attribute. Let us continue the example of the previous
paragraph using m as the base unit and adding a convention to the
mathematical program.
Quantity SI_Length {
BaseUnit : m;
Conversions : {
dm -> m : # -> # / 10,
cm -> m : # -> # / 100
Comment : "Expresses the value of a distance.""}
Parameter LengthGranul {
InitialData : 10;
Convention solveConv {
PerQuantity : SI_Length : LengthGranul * cm;
MathematicalProgram myCP {
Direction : minimize;
Constraints : AllConstraints;
Variables : AllVariables;
Type : Automatic;
Convention : solveConv;
Again, AIMMS will generate the constraint such that only integer
arithmetic is needed. The constraint listing of that constraint is
similar to the constraint listing presented in the paragraph adapted
base unit above and not repeated. Note also that with conventions, we
can now use parameters to further control the scaling; if we want to
change the model such that we can use multiples of 20[cm] instead of
multiples of 10[cm], we only need to change the value of
LengthGranul.
Calendar used for timeline
Scheduling applications in which the schedule domain is based on a
calendar, the length of a timeslot is equal to the unit of the calendar,
see Calendars. The time quantity is overridden, as if an
entry in the per quantity attribute of the associated convention is
given, selecting the calendar unit. Even if no convention was associated
with the mathematical program. In short, for scheduling applications,
AIMMS will scale time based data according to the length of a timeslot.
Solving a Constraint Program
Mathematical Programming types
AIMMS distinguishes two types of mathematical programs that are
associated with constraint programming models: COP for constraint
optimization problems, and CSP for constraint satisfaction problems.
Both COP and CSP are exact in that COP provides a proven
optimal solution while CSP provides a solution, or proves that none
exist, if time permits.
Limiting solution time
Constraint programming problems are combinatorial problems and therefore may take a long time to solve, especially when trying to prove optimality. In order to avoid unexpectedly long solution times, you can limit the amount of time allocated to the solver for solving your problem as follows:
solve myCOP where time_limit := pMaxSolutionTime ;
! pMaxSolutionTime is in seconds.
Alternatively, when you are satisfied with the current objective, as presented in the progress window, and not want to wait on further improvements, you can interrupt the solution process by using the key-stroke ctrl-shift-s.
Search Heuristics
Search heuristics
During the solving process, constraint programming employs search heuristics that define the shape of the search tree, and the order in which the search tree nodes are visited. The shape of the search tree is typically defined by the order of the variables to branch on, and the corresponding value assignment. AIMMS allows the user to specify which variable and value selection heuristics are to be used. For example, to decide the next variable on which to branch, a commonly used search heuristic is to choose a non-fixed variable with the minimum domain size, and assign its minimum domain value.
Search phases
The first method offered by AIMMS to influence the search process is
through using the Priority attributes of the variables. AIMMS will
group together all variables that have the same priority value, and each
block of variables will define a search phase. That is, the solver
will first assign the variables in the block with the highest priority,
then choose the next block, and so on. As discussed in
The Priority, Nonvar and RelaxStatus Attributes, the highest priority is the one with the
highest positive value. Defining search phases can be very useful. For
example, when scheduling activities to various alternative resources, it
is natural to first assign an activity to its resource before assigning
its begin.
Variable and value selection
The variable and value selection heuristics offered by AIMMS are
presented in this table.
They can be accessed through the ‘solver options’ configuration window.
As an example, we can define a ‘constructive’ scheduling heuristic that
builds up the schedule from the begin of the schedule domain by using
MinValue as the variable selection, and Min as the value
selection. Indeed, this heuristic will attempt to greedily schedule the
activities as early as possible. Note that both these variable and value
heuristics apply to the entire search process. If no variable priorities
are specified, the variable selection heuristic will consider all
variables at a time. Otherwise, the variable selection heuristic is
applied to each block individually.
Heuristic |
Interpretation |
Variable selection: |
choose the non-fixed variable with: |
use the solver’s default heuristic |
the smallest domain size |
the largest domain size |
the smallest domain value |
the largest domain value |
Value selection: |
assign: |
a uniform-random domain value |
