Model Edit Functions
AIMMS Model Edit Functions
The AIMMS API supports Model Edit Functions allowing external applications to inspect, modify, or even construct AIMMS models. In this section, the model edit functions are introduced using a small example. Subsequently, after briefly describing the relation to runtime libraries plus the conventions used, several tables containing model edit functions, are presented and described. Finally, the limitations of using model edit functions through the AIMMS API are described briefly.
Small example
In the following example, an element parameter nextCity is created
with a simple definition. Model editing is done using model editor
handles. These handles provide access to the identifiers in the model,
and should not be confused with the data handles and procedure handles
described elsewhere in this chapter.
The model editor handle int dsMEH refers to a declaration section,
whereas the model editor handle int ncMEH refers to the parameter
nextCity.
1 AimmsMeCreateNode("nextCity", AIMMSAPI_ME_IDTYPE_ELEMENT_PARAMETER, dsMEH, 0, &ncMEH);
2 AimmsMeSetAttribute(ncMEH, AIMMSAPI_ME_ATTR_INDEX_DOMAIN, "i");
3 AimmsMeSetAttribute(ncMEH, AIMMSAPI_ME_ATTR_RANGE, "Cities");
4 AimmsMeSetAttribute(ncMEH, AIMMSAPI_ME_ATTR_DEFINITION,
"if i == last(Cities) then first(Cities) "
"else Element(Cities,ord(i)+1) endif");
5 AimmsMeCompile(ncMEH);
6 AimmsMeCloseNode(ncMEH);
A line by line explanation of this example follows below. For the sake of brevity, error handling, such as suggested in Raising and Handling Errors, is omitted here.
- Line 1
Creates an element parameter named
nextCity. The fourth argument ofAimmsMeCreateNodeis the position within the section. A 0 indicates that it should be placed at the end of the section.- Lines 2-4
Set the attributes
IndexDomain,Range, andDefinitionof this parameter. Note that only the text is passed, these calls do not use the AIMMS compiler to compile them.- Line 5
Compiles the element parameter
nextCity. Only now is the text of the attributes actually checked and compiled.- Line 6
The function
AimmsMeCloseHandlede-allocates the handlencMEHbut the created identifiernextCityremains in the model.
Relation to runtime libraries
Runtime Libraries and the Model Edit Functions describes the model editing facility available in the AIMMS language using runtime libraries. The advantage of using the AIMMS API, instead of runtime libraries, for model editing is that the entire model can be edited, including the main model, provided that there is no AIMMS procedure active while executing a model edit function from within the AIMMS API. The cost is that multiple languages have to be used.
Conventions for model edit functions
The model edit functions follow the following conventions:
Each function starts with
AimmsMe.These functions return either
AIMMSAPI_SUCCESSorAIMMSAPI_FAILURE.A model editor handle
MEHhas to be closed by eitherAimmsMeCloseNodeorAimmsMeDestroyNode.No distinction is made between identifiers and nodes in the model editor tree, they are both called “nodes”.
String output arguments use the type
AimmsStringas is explained in Passing integer, double or string values.
Model roots
this table lists the functions available for
manipulating model editor roots. The number of roots available for model
editing is stored by the function AimmsMeRootCount(count) in its
output argument count. Note that count is always at least 1,
since there is always the main model. The root
Predeclared identifiers is not included in this count. As the root
Predeclared identifiers and its sub-nodes cannot be changed, it is
not included in this count. To obtain a handle for an existing root, the
function int AimmsMeOpenRoot(pos, MEH) can be used. A model editor
handle is then created and stored in MEH. If pos is 0, the
main model root is opened. If pos is in the range
{ 1 .. count-1 } then a library is opened. If pos equals
count then the predeclared root Predeclared identifiers is
opened. The root Predeclared identifiers and its sub-nodes are read
only. In order to create a new runtime library the function
AimmsMeCreateRuntimeLibrary(name, prefix, MEH) can be used. The
position of the new library is at the end of the existing libraries.
Opening or creating a node
The function AimmsMeNodeExists(name, nMEH, exists) can be used to
test if an identifier exists. This function returns AIMMSAPI_FAILURE
when nMEH does not indicate a valid namespace, or when name is not a
valid identifier name. If the name is a declared identifier in namespace
nMEH, then exists is set to 1, and if not to 0. The function
AimmsMeOpenNode(name, nMEH, MEH) creates a handle to the node with
name name in the namespace determined by the model editor handle
nMEH. If successful, a model editor handle is created and stored in
the output argument MEH. If nMEH equals
AIMMSAPI_NULL_HANDLE_NUMBER, then the namespace of the main model is
used. A new node with name name and type idtype can be created
using the function AimmsMeCreateNode(name, idtype, pMEH, pos, MEH).
The value of idtype must be one of the constants defined in
aimmsapi.h starting with AIMMSAPI_ME_IDTYPE_. The parent node of
the new node is determined by the model editor handle pMEH. The
value pos determines the new position of the node within the parent
node. If pos is outside the range of existing children {1..n}, the
new identifier is placed at the end, otherwise the existing children at
positions pos .. n are shifted to positions pos+1 .. n+1
where n was the old number of children of pMEH.
Closing or destroying a node
this table not only lists the functions to
open or create nodes, but also shows the complementary functions to
close or destroy nodes. The function AimmsMeCloseNode(MEH)
de-allocates the handle MEH but leaves the corresponding node in the
model intact. The function AimmsMeDestroyNode(MEH) destroys the node
corresponding to MEH and all nodes below that node in the model, and
subsequently deallocates the handle MEH.
The name of a node
this table lists the functions that return the
name of a node. The function AimmsMeName(MEH, name) stores the name
of the node to which MEH refers without any prefixes in the output
argument name. The function
AimmsMeRelativeName(MEH, rMEH, rName) stores the name of MEH
such as it should be used from within the node rMEH in the output
argument rName. A fully qualified name is stored in rName when
MEH is the AIMMSAPI_ME_NULL_HANDLE_NUMBER handle.
The type of a node
In addition, this table lists the functions for
the type of a node. The function AimmsMeType(MEH, meType) stores the
type of the node MEH in the output argument meType. The value of
meType refers to one of the constants in aimmsapi.h starting
with AIMMSAPI_ME_IDTYPE_. The function
AimmsMeAllowedChildTypes(MEH, typeBuf, typeBufsize, maxTypes) stores
the types of children allowed below the node MEH in the buffer
typeBuf while respecting its size typeBufsize. The maximum
number of child types below MEH is stored in the output argument
maxTypes. The utility function AimmsMeTypeName(typeNo, tName)
stores the name of the type typeNo in the output argument tName.
The attributes of a node
for handling the attributes of a node. All attributes correspond to
constants in the aimmsapi.h file. These constants start with
AIMMSAPI_ME_ATTR_. The function
AimmsMeGetAttribute(MEH,attr,text) stores the contents of attribute
attr of node MEH in the output argument text. The function
AimmsMeSetAttribute(MEH,attr,txt) sets the contents of attribute
attr of node MEH to txt. This function will fail if
attribute attr is not applicable to identifier MEH, but the text
itself is not checked for errors. The function
AimmsMeAttributes(MEH, attrsBuf, attrBufSize, maxNoAttrs) provides
the applicable attributes for these two functions. It will store the
constants corresponding to the attributes available to node MEH in
attrBuf while respecting the size of that buffer attrBufSize.
The maximum number of attributes available to node MEH is stored in
maxNoAttrs. The function AimmsMeAttributeName(attr, name) stores
the name of attr in name.
Basic node manipulations
The functions that support changing the aspects of a node such as name,
location, and type of a node are also shown in
this table. The function
AimmsMeNodeRename(MEH, newName) changes the name of a node, and the
namechange is applied to the attribute texts that reference this node.
An entry is appended to the name change file if the node is not a
runtime node. The function AimmsMeNodeMove(MEH, pMEH, pos) moves the
node MEH to child position pos of node pMEH. If this results
in a change of namespace, the corresponding namechange is applied to the
attributes that reference this node. In addition, an entry is appended
to the corresponding name change file if this node is not a runtime
node. Moves from one library to another are not supported, nor is a move
in or out of the main model. The function
AimmsMeNodeChangeType(MEH, newType) changes the type of a node. It
will retain available attributes whenever possible. The function
AimmsMeNodeAllowedTypes can be used to query which types, if any, a
particular node can be changed to. The function
AimmsMeNodeAllowedTypes(MEH, typeBuf, typeBufsize, maxNoTypes) will
store all the types into which node MEH can be changed in a buffer
typeBuf that respects the size typeBufsize. The maximum number
of types into which MEH can be changed is stored in maxNoTypes.
Tree walk of the model
this table lists the functions that permit
walking all nodes in the model editor tree. The function
AimmsMeParent(MEH, pMEH) creates a model editor handle to the parent
of MEH, and stores this handle in the output argument pMEH. The
function AimmsMeFirst(MEH, fMEH) creates a model editor handle to
the first child of MEH, and stores this handle in the output
argument fMEH. The function AimmsMeNext( MEH, nMEH) creates a
model editor handle to the node next to MEH, and stores this handle
in the output argument nMEH. If such a parent, first child, or next
node does not exist the AIMMSAPI_ME_NULL_HANDLE_NUMBER handle is
stored in the output argument although the corresponding function does
not fail.
Reading and writing (portions of) a model
The functions that allow the reading of an AIMMS section from a file, or
writing a section to a file are also listed in
this table. They use the Text .ams
file format. The function AimmsMeImportNode(MEH, fn, pwd) reads a
file fn and stores the resulting model structure at node MEH.
The function AimmsMeExportNode(MEH, fn, pwd) writes the model
structure at node MEH to file fn. If MEH does not refer to
an AIMMS section, module, library, or model, the functions
AimmsMeImportNode and AimmsMeExportNode will fail.
Compilation
The model edit functions available for compilation and model status
queries are listed in this table. The
central function AimmsMeCompile (MEH) compiles the node MEH and
all its sub-nodes. The entire application (main model and libraries) is
compiled if the argument MEH equals
AIMMSAPI_ME_NULL_HANDLE_NUMBER. If this compilation step is
successful then the procedures are runnable.
The function AimmsMeIsRunnable(MEH, r) stores 1 in the output
argument r if the procedure referenced by MEH is runnable. The
function AimmsMeIsReadOnly(MEH, r) stores 1 in the output argument
r if the node resides in a read-only library, such as the
predeclared identifiers, or a library that was read from a read only
file.
Limitations
The following limitations apply to model edit functions from within the AIMMS API:
The
SourceFileattribute is not supported.The current maximum number of identifiers is thirty thousand.
Further, when an AIMMS procedure is running, the identifiers in the main application can not be modified as explained in Runtime Libraries and the Model Edit Functions.
