Obtaining Identifier Attributes
Obtaining attributes
For every identifier handle passed to (or created from within) an external function, AIMMS can provide additional attributes that are either related to the declaration of the identifier associated with the handle, or to the particular identifier slice that was passed as an argument in the external function call. this table lists all AIMMS API functions which can be used to obtain these additional attributes.
Identifier name and type
With the functions AimmsAttributeName and AimmsAttributeType you
can request the name and identifier type of the identifier associated
with a handle. AIMMS passes the name of an identifier through an
AimmsString structure (explained below). AIMMS only allows handles
for identifier types with which data can be associated. More
specifically, AIMMS distinguishes the following identifier types:
simple root set,
simple subset,
relation,
indexed set,
numeric parameter,
element parameter,
string parameter,
unit parameter,
variable,
element variable.
When the handle refers to a suffix of an identifier, the suffix type is appended to the identifier name separated by a dot.
Storage type
In addition to the identifier type, AIMMS also associates a storage type
with each handle. It is the data type in which AIMMS expects the data
values associated with the handle to be communicated. The function
AimmsAttributeStorage returns the storage type. The possible storage
types are:
double (
double),integer (
int),binary (
int, but only assuming 0-1 values),string (
char *).
The complete list of identifier and storage type values returned by
these functions can be found in the header file aimmsapi.h.
Default value
With the function AimmsAttributeDefault you can obtain the default
value of the identifier associated with a handle. The default value can
either be a double, integer or string value, depending on the storage
type associated with the handle. Below you will find the convention used
by AIMMS to pass such storage type dependent values back and forth.
Setting and getting units
Through the functions AimmsAttributeGetUnit and
AimmsAttributeSetUnit you can get and set the units of measurement
(see also Units of Measurement) that will be used when passing data from
and to AIMMS. When setting the unit to be used, you can specify both a
unit and a convention. AIMMS will parse the given unit expression and
use the specified convention to compute the appriopriate multiplication
factors between the internal and external representation of the data of
the identifier at hand.
Passing integer, double or string values
All transfer of integer, double or string values takes place through the
record structures AimmsString and AimmsValue defined as follows.
typedef struct AimmsStringRecord {
int Length;
char *String;
} AimmsString;
typedef union AimmsValueRecord {
double Double;
int Int;
struct {
int Length;
char *String;
} AimmsValue;
When value is such a structure, you can obtain an integer, double or
string value through value.Int, value.Double or
value.String, respectively.
Passing string lengths
For strings, you must set value.Length to the length of the string
buffer passed through value.String before calling the API function.
When AIMMS fills the value.String buffer, the actual length of the
string passed back is assigned to value.Length. When the actual
string length exceeds the buffer size, AIMMS truncates the string passed
back through value to the indicated buffer size, and assigns the
length of the actual string to value.Length.
Identifier dimensions
For each handle you can obtain the dimension of the associated
identifier by calling the function AimmsAttributeDimension. The
function returns:
the full dimension of the identifier as given in its declaration, and
the slice dimension, i.e. the resulting dimension of the actual identifier slice associated with the handle.
AIMMS uses tuples of length equal to the full dimension whenever information is communicated regarding the index domain of a handle or its slicing. When explicit data values associated with a handle are passed using the AIMMS API functions discussed in Communicating Individual Identifier Values, AIMMS communicates such values using tuples of length equal to the slice dimension.
Set dimensions
For all data communication with external DLLs AIMMS considers sets to be represented by binary indicator parameters indexed over their respective root sets. For all elements in these root sets, such an indicator parameter assumes the value 1 if a root set element (or tuple of root set elements) is contained in the set at hand, or 0 otherwise. Since the default of these indicator parameters is 0, AIMMS only needs to communicate the nonzero values, i.e. exactly the tuples that are actually contained in the set. In connection with this representation, AIMMS returns the following (full or slice) dimensions for sets:
the dimension of a simple set is 1,
the dimension of a relation is the dimension of the Cartesian product of which the relation is a subset,
the dimension of an indexed set is the dimension of the index domain of the set plus 1.
Identifier domains
The functions AimmsAttributeRootDomain,
AimmsAttributeDeclarationDomain and AimmsAttributeCallDomain can
be used to obtain an integer array containing handles to domain sets for
every dimension of the identifier at hand. These domains play a
different role in the sparse data communication, as explained below.
Root domain handles
The function AimmsAttributeRootDomain returns an array of handles to
the respective root sets associated with the index domain specified in
the identifier’s declaration. You need these handles, for instance, to
obtain a string representation of the element numbers returned by the
data communication AIMMS API functions discussed in
Communicating Individual Identifier Values.
Declaration domain handles
The function AimmsAttributeDeclarationDomain returns an array of
handles to the respective domain sets specified in the identifier’s
declaration. These domain sets can be equal to their corresponding root
sets, or to subsets thereof. AIMMS will only pass data values for
element tuples in the declaration domain, unless you have specified the
raw translation modifier (see also Declaration of External Procedures and Functions)
for a handle argument, or have created the handle yourself with the raw
flag set (see also Managing Identifier Handles).
Call domain handles
The function AimmsAttributeCallDomain returns an array of handles to
the particular subsets of the root sets (as returned in the root domain
of the handle) to which data communication is restricted for this
handle. The call domain can be different from the global domain if an
actual external argument has been restricted to a subdomain of the root
set in an external call (see also Calls to Procedures and Functions), or if you have
created the handle with an explicit call domain yourself (see also
Managing Identifier Handles). AIMMS will only pass data values associated
with element tuples in just the call domain (raw flag set), or in the
intersection of the call and declaration domain (raw flag not set).
Domain restriction
With the function AimmsAttributeRestriction you can obtain a handle
to the global domain restriction of an indexed identifier as specified
in its declaration and (dynamically) maintained by AIMMS as necessary.
You may want to use this handle in conjunction with raw handles
(explained in Communicating Individual Identifier Values) to verify whether a particular
element satisfies its domain restriction.
Example
Consider the following set and parameter declarations.
Set S_0 {
Index : i_0;
Set S_1 {
SubsetOf : S_0;
Index : i_1, j_1;
Set S_2 {
SubsetOf : S_1;
Index : i_2;
Parameter p {
IndexDomain : i_0;
Parameter q {
IndexDomain : (i_1, j_1) | p(i_1);
A handle to (in AIMMS notation) q(i_1, i_2) will return handles to
S_0andS_0for the respective root domains,S_1andS_1for the respective declaration domains,S_1andS_2for the respective call domains, andp(i_1)for the domain restriction.
Slicing
As discussed in Calls to Procedures and Functions, the actual arguments in a
procedure or function call can be slices of higher-dimensional
identifiers within your model. When the slice dimension of a handle in
an external call is less then its full dimension, you can use use the
function AimmsAttributeSlicing to find out which dimensions of the
associated AIMMS identifier have been sliced, and to which elements. The
function returns an integer array containing, for every dimension, the
element number (within the associated root set) to which the
corresponding domain has been sliced, or the number
AIMMSAPI_NO_ELEMENT if no slicing took place.
Domain permutations
Through the function AimmsAttributePermutation you can obtain the
permutation of a permuted handle created with the function
AimmsAttributeHandleCreatePermuted. The output permutation
argument must be an integer array of length equal to the full dimension
of the identifier. AIMMS returns the following values:
if a dimension of the handle is sliced, the corresponding position in the
permutationarray will be 0,if a dimension is not sliced, the corresponding position in the
permutationarray will contain the sliced position (starting at 1, and numbered from 1 to the handle’s slice dimension)in which AIMMS will store elements of the corresponding dimension in a
tuplereturned by the functionsAimmsValueNextandAimms ValueNextMulti, orin which AIMMS expects such elements in calls to the functions
AimmsValueSearchandAimmsValueRetrieve.
Getting ordered, special, raw and read-only flags
By specifying the input-output type and the ordered,
retainspecials, elementsasordinals or raw translation
modifiers for arguments in an external call (see also
Declaration of External Procedures and Functions), you can influence the manner in which
data is passed to an external function. With the AIMMS API function
AimmsAttributeFlagsGet you obtain the active set of flags
indicating whether
the data associated with a handle is passed ordered (
orderedflag),special values are passed unchanged or are translated (
retainspecialsflag),element tuples are passed by their element numbers (
elementsasordinalsflag),inactive data is passed (
rawflag), andyou can make assignments to the handle (input-output type).
The result is the bitwise or function of the individual flag values as
defined in the aimmsapi.h header file.
Setting flags
Through the function AimmsAttributeFlagSet you can modify the flag
settings for an existing handle. Note that the result of calls to
AimmsValueNext may become unpredictable after modifying the
ordered flag. In such a case, you are advised to reset the handle
through the function AimmsHandleReset.
Element range
When a handle is associated with an element parameter within your
application, you can use the function AimmsAttributeElementRange to
obtain a handle to the set constituting the element range of the element
parameter. You need this handle, for instance, when you want to obtain a
string representation of the element numbers within the element range
communicated by AIMMS in the AIMMS API functions discussed
