Passing Errors and Messages
Passing errors and messages
The AIMMS API functions in this table let you send error and warning messages to AIMMS and get the current AIMMS status. In addition, you can obtain the error number and description of the last AIMMS API error.
With the function AimmsAPIPassMessage you can send error and warning
messages to the end-user of your DLL in AIMMS. Such errors and warnings
are displayed to the end-user in the AIMMS message window. For every
message you must indicate a severity code, the complete list of which is
included in the aimmsapi.h header file. When AIMMS receives a
message with error severity, a run-time error is generated. The end-user
of an application can set execution options to filter out those warning
messages which are below a certain severity threshold.
Setting CurrentErrorMessage
If a function in your DLL is called from within an AIMMS project, and
you want to pass back an error message to the model without
automatically opening the AIMMS message window, you should not use the
function AimmsAPIPassMessage, but instead assign the message to the
predefined AIMMS string parameter CurrentErrorMessage. To assign a
value to it, you should create a handle to it via the function
AimmsIdentifierHandleCreate and assign the message using the
function AimmsValueAssign. It is then up to the model developer
calling your function, whether the message stored in
CurrentErrorMessage should be displayed (e.g. in the AIMMS message
window).
Obtaining the execution status
Through the function AimmsAPIStatus you can obtain the current
status of the AIMMS execution engine, such as executing, solving, ready,
etc. The complete list of possible status codes and their meaning is
Obtaining API errors
Whenever a call to an AIMMS API function fails, the function returns
AIMMSAPI_FAILURE as its return value. In such a case, you can obtain
the precise error code and a message describing the error through the
function AimmsAPILastError. The complete list of error codes is
contained in the aimmsapi.h header file. By modifying the
API-related execution options, you can also enforce that every API error
is listed in the AIMMS message window.
