Thread Synchronization
Multiple threads
The AIMMS API allows multiple DLLs to be active within the context of a single project. While some of these DLLs may only be useful when called from within your AIMMS project itself, you may want other DLLs to run independently in a separate thread of execution. Such behavior may be necessary, for instance, when
you want to link AIMMS to an online data source, where an independent DLL collects the online data and passes it on to AIMMS whenever appropriate, or
you want to call AIMMS as an independent optimization engine from within your own program and need to pass data to AIMMS whenever necessary.
AIMMS thread
When you open an AIMMS project by calling the function
AimmsProjectOpen from within your own application, AIMMS will create
a new thread. This AIMMS thread will deal with
all end-user interaction initiated from within the AIMMS end-user interface (which is created as part of opening the project), and
all asynchronous execution requests that are initiated either from within your application, another external DLL linked to your AIMMS project, or from within the model itself.
Thread initialization
Whenever you want to call AIMMS API functions from within a thread started by yourself, you must make sure that the thread is well-equipped to do so by calling the AIMMS thread (un)initialization functions listed in this table.
Initializing threads…
Prior to calling any other AIMMS API function from within a newly
created thread, you should call the function AimmsThreadAttach. It
will make sure that any thread-specific initialization required for
calling the AIMMS execution engine is performed properly. Similarly, you
should call the function AimmsThreadDetach just prior to exiting the
thread.
… includes COM initialization
Among others, a call to AimmsThreadAttach will initialize the
Microsoft COM library in a manner compatible with the COM apartment
model employed by AIMMS. Therefore, if you are using COM interfaces
within your thread, you should not call the COM SDK functions
CoInitialize (or CoInitializeEx) and CoUninitialize directly
to initialize the COM library, but rather call AimmsThreadAttach and
AimmsThreadDetach.
Thread synchronization
Whenever an AIMMS project runs in a multi-threaded environment, synchronization of the execution and data retrieval requests becomes of the utmost importance. By default, AIMMS will make sure that no two execution or data retrieval requests initiated from different threads are dealt with simultaneously. However, this default synchronization scheme does not preclude that the execution of two subsequent requests from one thread is interrupted by a request from another thread.
Obtaining exclusive control
When the proper functioning of your application requires that your execution and data retrieval requests to AIMMS are not interrupted by requests from competing threads, you can use the functions listed in this table to obtain exclusive control over the AIMMS execution engine.
Obtaining and releasing control
With the function AimmsControlGet you can restrict control over the
current AIMMS session exclusively to the thread calling
AimmsControlGet. Execution and data retrieval requests from any
thread other than this controlling thread (including the AIMMS thread
itself) will block until the controlling thread has released the
control. The function AimmsControlRelease releases the exclusive
control over the AIMMS session. Note that every successful call to
``AimmsControlGet`` must be followed by a corresponding call to
``AimmsControlRelease``, or AIMMS will be inaccessible to all other
threads for the remainder of the session. AimmsControlRelease fails
when the calling thread does not have exclusive control.
Waiting for the control
When another thread has exclusive control over AIMMS, either obtained
explicitly through a call to AimmsControlGet or implicitly through
an execution or data retrieval request, the function AimmsControlGet
will block timeout milliseconds before returning with a failure. By
choosing a timeout of WAIT_INFINITE, the function
AimmsControlGet will block until it gets exclusive control.
Nonblocking execution
If you want to make sure that a subsequent execution request will never block, you can
call
AimmsControlGetwith a timeout of 0 milliseconds,perform the execution request when successful, and
subsequently release the control.
The call to AimmsControlGet has the effect of verifying that no
other thread is using AIMMS at the moment. If you cannot get exclusive
control, you must store the request for later execution.
