Managing Identifier Handles
Creation and data control
AIMMS offers the capability to dynamically create and delete handles to any desired identifier slice over any desired local subdomain from within a DLL. In addition, a subset of the AIMMS data control operators (as discussed in Data Control) can be called from within external DLLs. this table lists all available AIMMS API functions for creating handles and performing data control operations.
Creating a handle
You can use the function AimmsIdentifierHandleCreate to dynamically
create a handle to (a slice of) an AIMMS identifier or a suffix thereof
within an external function or procedure. You can restrict the scope of
a handle by
specifying a call domain to which you want to restrict the handle, or
by slicing one or more dimensions of the identifier.
Obtaining a suffix
If you want a handle to an identifier itself, the name passed to
AimmsIdentifierHandleCreate should just be the identifier name. If
you want a handle to a suffix of an identifier, you should pass the name
of the identifier followed by a dot and the suffix name. Thus, for
instance, you should pass the name "Transport.ReducedCost" if you
want a handle to the reduced costs of the variable Transport.
Specifying a call domain
When you want to create a handle over the full root domain, you can
simply pass a null pointer for the domain argument. If you want to
specify an additional call domain, you must pass an integer array of
length equal to the identifier’s full dimension, each element containing
a handle to the set to which you want to restrict the domain. If the raw
flag is not set, passing a null pointer for the domain handle will
effectively restrict the declaration domain of the identifier at hand,
because of the semantics of the raw flag (see also
Obtaining Identifier Attributes and Communicating Individual Identifier Values).
Specifying a slice
When you want to create a handle over the full dimension of an
identifier, you can simply pass a null pointer for the slicing
argument. If you want to create a handle to a slice, you must pass an
integer array of length equal to the identifier’s full dimension, each
element containing either a null element for all the domains that you do
not want to slice, or the element number of the element to which you
want to slice.
Modification flags
With the flags argument in a call to AimmsIdentifierHandleCreate
you can specify which modification flags should be set for the handle to
be created. The format of the flags argument is the same as in the
function AimmsAttributeFlags discussed in the previous section.
Creating a permuted handle
With the function AimmsIdentifierHandleCreatePermuted you can obtain
a handle to a multidimensional identifier, for which the order in which
element tuples are returned is permuted. Handles created by
AimmsIdentifierHandle CreatePermuted are always read-only,
i.e. cannot be used in the functions AimmsValueAssign and
AimmsValueAssignMulti. The permutation argument must be
specified according to the rules explained for the function
AimmsAttributePermutation.
Example
Consider an identifier p(i,j,k,l) for which you want to retrieve the
values as if the identifier were defined as p(k,i,l,j). To retrieve
all values of p in this order, the permutation array must be
specified as [2,4,1,3].
Deleting handles
With the function AimmsIdentifierHandleDelete you can delete a
dynamically created handle that is no longer needed. The function fails
when you try to delete a handle that was passed as an argument to the
DLL. After deletion the handle can no longer be used in conjunction with
any AIMMS API function.
Empty, cleanup and update handles
The AIMMS API functions
AimmsIdentifierEmpty,AimmsIdentifierCleanup, andAimmsIdentifierUpdate
can be called to perform the identical actions on a set or identifier
(slice) from within an external DLL as can be accomplished by the data
control operators EMPTY, CLEANUP and UPDATE from within
AIMMS, respectively. The function AimmsIdentifierEmpty will empty
the particular slice and subdomain of the identifier associated with the
handle. The other two functions will cleanup or update the entire data
set of the identifier associated with the handle, regardless of the
specified slicing and local domain.
Data version
For every identifier within your model AIMMS maintains a version number
of the data associated with the identifier. This number is incremented
each time a data value of the identifier has been changed. You can use
the function AimmsIdentifierDataVersion to retrieve this version
number, for instance, to verify whether the data has changed relative to
the last time you retrieved it.
Checking for global data changes
When you apply the function AimmsIdentifierDataVersion to the
predefined handle value AIMMSAPI_MODEL_HANDLE, AIMMS will return a
data version number based on the cases and datasets currently active
within the model. AIMMS will update this number as soon as the combined
configuration of the active case and/or datasets within the model has
changed, as well as after a call to the CLEANDEPENDENTS operator. A
change in this global data version number is a good indication that the
contents of all or a number of domain sets may have changed, and must be
retrieved again.
