Runtime Libraries and the Model Edit Functions
Runtime libraries and the AIMMS Model Edit Functions permit applications to adapt to modern flexibility requirements of the model; at runtime you can create identifiers and subsequently use them. A few use cases, in which the need for flexibility in the model grows, are briefly outlined below.
Use case: automating modeling tasks
You may want to improve the maintainability of your application by
Generating similar statements that act on dynamic selections of identifiers, or
Generate necessary parameters and database table identifiers with their mapping attributes by querying a relational database schema when setting up a database link with your model.
Use case: Cooperative model development
Another example, in cooperative model development, a model is developed together with the users of that model. For instance, an existing application framework is demonstrated to the users and, subsequently, the suggestions from these users are taken into account. A suggestion might be to add structural nodes or arcs, or might be to add a particular restriction on existing nodes and arcs.
Use case: Proprietary user knowledge
Further, not all structural information may be available at the time of model development; some users may need to add their proprietary knowledge to the model at runtime. Examples of such proprietary knowledge are:
Pricing rules for the valuation of portfolios.
Blending rules for the prediction of property values of blends.
Use case: ad hoc user queries
A final example of a modern flexibility requirement is a user who has additional questions only when the results are actually presented. Such a user wants to question the model in order to understand a particular result. This person is only able to formulate the question after the unexpected result presents itself.
Runtime editing of identifiers
In the above use cases, applications create, manipulate, check, use, and destroy AIMMS identifiers at runtime. Such operations are performed by the Model Edit Functions. Such applications need to:
Have a place to store these AIMMS identifiers and to retrieve them from. Such a place is called an AIMMS runtime library.
Have functions and procedures available to create, modify, check, and destroy these AIMMS identifiers. Together, these functions and procedures form the Model Edit Functions.
Have a way to use these identifiers inside the model.
And be able to continue execution in the presence of errors. This fourth requirement is an essential aspect of all the other requirements and is central to the design of the AIMMS Runtime libraries and AIMMS Model Edit Functions. Global and local error handling is described in Handling Errors.
Runtime identifiers and libraries
The identifiers created, modified, checked, used, and destroyed at runtime are called runtime identifiers. These runtime identifiers are declared within a runtime library. A runtime library is itself also a runtime identifier: it can also be created, modified, checked, used, and destroyed at runtime. A runtime identifier can have any AIMMS type, except for quantity.
Separation between main application and runtime libraries
Model edit functions are only allowed to operate on runtime identifiers. Runtime identifiers exist at runtime but do not yet exist at compile time. The names of runtime identifiers can only be used in the main model in procedures specificaly designated for this, by specifying the ‘Uses runtime libs’ attribute. Such procedures will be compiled runtime, and recompiled upon change in the runtime libraries specified. Such procedures are not allowed to use model editing functionality themselves. This enforces a separation between identifiers in the main application and runtime identifiers as depicted in Fig. 16. On the left side of this architecture there is a main application consisting of a main model and zero, one or more libraries. On the right there are zero, one or more runtime libraries. Compilation errors can occur within runtime libraries at runtime. The identifiers inside the main application are not affected by such an error; that is, provided it has local error handling, any procedure inside the main application can continue execution in the presence of compilation errors on identifiers in a runtime library. This is an important advantage of the separation: for several of the use cases presented above, this separation enables continuation in the presence of errors.
Fig. 16 Separation between main application and runtime libraries
Example of using a runtime identifier directly
In this example, a runtime identifier is used directly. This yields the same result as the next example. This feature is very convenient to get access to runtime identifiers or procedures that are exposed to the model by generic libraries extending AIMMS functionality such as CDM or DEX.
Procedure DisplayDataOfRuntimeIdentifierTabular {
Uses runtime libs: mr1;
Body {
display { mr1::P }
This example illustrates that by specifying the prefix mrl the body of the procedure
can reference the identifiers in that runtime library.
Example of creating an identifier
In this example, a runtime procedure rp is created and its body
specified. This procedure is created in the runtime library
MyRuntimeLibrary1 with prefix mrl. The purpose of the runtime
procedure rp is to write out the runtime parameter P declared in
the same runtime library. This example assumes that both the runtime
library MyRuntimeLibrary1 and the runtime parameter P already
exist.
ElementParameter erp {
Default : 'MainExecution';
Range : AllIdentifiers;
StringParameter str;
ElementParameter err {
Range : errh::PendingErrors;
ElementParameter err2 {
Body {
1 block
2 erp := me::Create("rp", 'procedure', 'MyRuntimeLibrary1', 0);
3 me::SetAttribute(erp, 'body', "display { P } ;");
4 me::Compile(erp);
5 me::Compile('MyRuntimeLibrary1');
6 Apply(erp);
7 me::Delete(erp);
8 onerror err do
9 if erp then
10 block
11 me::Delete(erp);
12 onerror err2 do
13 if errh::Severity(err2) = 'Severe' then
14 DialogMessage(errh::Message(err2) +
15 "; not prepared to handle severe errors " +
16 "and halting execution");
17 halt ;
18 else
19 errh::MarkAsHandled(err2) ;
20 endif ;
21 endblock ;
22 erp := '' ;
23 endif ;
24 errh::MarkAsHandled(err);
25 DialogMessage("Creating and executing rp failed; " + errh::Message(err) );
26 endblock ;
A line by line explanation of this example follows below.
- Lines 1, 8, 25
In order to handle the errors during a group of model edit actions, a
BLOCKstatement with anONERRORclause is used.- Lines 2 - 7
Contain the calls to the model edit functions. Note that these are formulated without any concern for errors because these errors are handled in line 9 - 25.
- Line 2
Create the procedure
rpas the final procedure in the runtime libraryMyRuntimeLibrary1. The prefix of the library will be prefixed to the name of the identifier created; and after this statement the value of the element parametererpis'mrl::rp'.- Line 3
Sets the contents of the body of that procedure. Here it is to display the parameter
Pin tabular format.- Line 4
Checks the procedure
mrl::rpfor errors.- Line 5
Compiles the entire runtime library
MyRuntimeLibrary1which will make the procedures inside that library runnable.- Line 6
Executes the procedure just created.
- Line 7
Delete the procedure just created.
- Lines 9 - 23
Try to delete
erp(mrl::rp) if it has not already been deleted.- Lines 13 - 20
Ignore all errors during the deletion except for severe internal errors.
- Line 24
Mark the error
err2as handled.- Line 25
Finally notifies the application user that something has gone wrong.
Model editing is available from within the language itself with
intrinsic functions and procedures to view, create, modify, move,
rename, compile, and delete identifiers. An intrinsic function or
procedure that modifies the application is called a Model Edit Function.
These functions and procedures reside in the predeclared module
ModelEditFunctions with the prefix me. The table below lists the
Model Edit Functions and briefly describes them.
Creating and deleting
this table lists the Model Edit Functions. A new runtime
library can be created using the function me::CreateLibrary. if
successful this function returns the library as an element in
AllSymbols. The function me::Create creates a new node or
identifier with name name of type type in section ep_sec at
position pos. The return value is an element in AllSymbols. If
inserted at position \(i\) (\(i>0\)), the declarations
previously at positions \(i\) .. \(n\) are moved to positions
\(i+1\) .. \(n+1\). If inserted at position 0, the identifier is
placed at the end. The procedure me::Delete can be used to delete
both a runtime library and a runtime identifier in a library. All
subnodes of ep in the runtime library are also deleted.
Reading and writing
The procedure me::ImportNode reads a section, module, or library
into node ep. If ep is a runtime library, an entire library is
read, replacing the existing prefix. me::ExportNode writes the
contents of the model editor tree referenced by ep to a file. These
two procedures use the text .ams file format.
Inspecting the tree
The function me::Parent(ep) returns the parent of ep, or the
empty element if ep is a root. The function
me::Children(ep, epc(i)) returns the children of ep in
epc(i) in which i is an index over a subset of Integers.
Node types
The function me::ChildTypeAllowed(ep, et) returns 1 if an identifier
of type et is allowed as a child of ep. The function
me::TypeChangeAllowed(ep, et) returns 1 if the identifier ep is
allowed to change into type et. The procedure
me::TypeChange(ep,et) performs a type change while attempting to
retain as many attributes as possible.
Attributes
The function me::GetAttribute(ep, attr) returns the contents of the
attribute attr of identifier or node ep. The complementary
procedure me::SetAttribute (ep,attr,str) specifies these contents.
The function me::AllowedAttribute(ep, attr) returns 1 if attribute
attr of identifier ep is allowed to have text.
Changing name or location
The procedure me::Rename(ep, newname) gives ep a new name
newname. The text inside the library is adapted, but a corresponding
entry in the namechange file is not created. The procedure
me::Move(ep, ep_p, pos) moves an identifier from one location to
another. When an identifier changes its namespace, this is a change of
name, and the text in the runtime library is adapted correspondingly,
but no entry in the namechange file is created. Runtime identifiers can
not be moved from one runtime library to another.
Querying runtime library status
The function me::IsRunnable(ep) returns 1 if ep is inside a
succesfully compiled runtime library.
Compilation
The function me::Compile(ep) compiles the node ep and all its
subnodes. If ep is the empty element, all runtime libraries are
compiled. See also Working with the Set AllIdentifiers on working with
AllIdentifiers.
Runtime identifiers are like data
To the main application, runtime identifiers are like data. Data operations such as creation, modification, destruction, read, and write are also applicable to runtime identifiers. When saving a project, the runtime libraries are not saved. Runtime libraries, including the data of runtime identifiers, can be saved in two ways: as separate files or in cases.
Storing runtime libraries in separate files
The runtime libraries themselves can be saved in text or binary model
files using the function me::ExportNode. They can subsequently be
read back using the functions me::ImportLibrary and
me::ImportNode (see the function reference for more details on these
functions). The data of the runtime identifiers can be written using a
write to file statement and be read back using a read from file
statement, see also Simple Data Transfer.
Storing runtime libraries in cases
When saving a case, a snapshot of the data in a model, or a selection
thereof (casetype), is saved. The data of a model include the runtime
libraries. However, the names of the runtime identifiers can vary and
therefore they cannot be part of a casetype. Whether runtime libraries
are saved in a case is controlled by a global option, named
Case contains runtime libraries. When loading a case saved with this
option switched on, the previously created runtime libraries will be
first destroyed and then the stored runtime libraries will be recreated,
both their structure and data. When loading a case saved while this
option was off, or a case saved with AIMMS 3.10 or earlier, any existing
runtime libraries will be left intact. Datasets never contain runtime
libraries.
The NoSave property
When the NoSave property is specified for a runtime library, this
runtime library will not be saved in cases.
The AIMMS model explorer
To the AIMMS model explorer, the runtime libraries are read only; it can copy runtime identifiers into the main application, but it cannot modify runtime identifiers. This is because, if the AIMMS model explorer could modify runtime identifiers, the state information maintained by the main application regarding the runtime identifiers might become inconsistent with the actual state of these runtime identifiers.
Visualizing the data of runtime identifiers
When AIMMS is in developer mode, data pages of the runtime identifiers can be opened, just like data pages of ordinary identifiers. The data of runtime identifiers can also be visualized on the AIMMS pages in the following two ways:
The safest way is to create a subset of containing the selected runtime identifiers, and use this subset as “implicit identifiers” in a pivot table. If the runtime identifiers referenced in this set do not yet exist, they will simply not be displayed.
The runtime identifiers can also be directly visualized in other page objects. Care should then be taken that the visualized runtime identifiers are created with the proper index domain before a page is opened containing these identifiers; if an identifier does not exist, a page containing a reference to such an identifier will not open correctly. In order to avoid the inadvertent use of runtime identifiers on pages, they are not selectable using point and click in the identifier selector, but the identifier selector accepts them when typed in.
Access to Runtime Identifiers in non-runtime Procedures
Starting from the version AIMMS 4.82, procedures, with an exception of predefined procedures, have a new attribute: The Uses Runtime libs attribute.
A procedure with this attribute specified enables developers to use runtime identifiers in the body of that procedure without the need to having them explicitly already available during modeling; If this attribute is not specified, a compilation error will occur making this impossible.
This attribute is intended to enable a procedure persistent in a model code to refer to identifiers from runtime libraries that do not exist at model compile-time. Thus, this new attribute is not required for runtime procedures referring to identifiers from other runtime libraries.
Limitation: The uses runtime libs attribute only permits to reference runtime identifiers
in the body of a procedure, it does not permit to reference runtime identifiers from the
attributes of local identifiers in that procedure.
Limitations of Runtime Libraries
The following limitations apply:
Local declarations are not supported; only global identifiers corresponding to elements in
AllIdentifiers.It is possible, however, to move identifiers local to a procedure or function, see Runtime Functions with Arguments
Quantities are not supported.
The
source file,module codeanduser dataattributes are not supported.It is possible, however, to persist a runtime library, see Create a Static AIMMS Library from a Runtime Library
The current maximum number of runtime identifiers is 30000.
