Executing AIMMS Procedures
Running AIMMS procedures
The AIMMS API allows you to execute procedures contained in the AIMMS model from within an external application. Both procedures with and without arguments can be executed, and scalar output results can be directly passed back to the external application. this table lists the AIMMS API functions offered to obtain procedure handles, to execute AIMMS procedures or to schedule AIMMS procedures for later execution.
Obtaining procedure handles
With the function AimmsProcedureHandleCreate you can obtain a handle
to a procedure with the given name within the model. In addition, AIMMS
will return the number of arguments of the procedure, as well as the
type of each argument. The possible argument types are:
one of the storage types double, integer, binary or string (discussed in Obtaining Identifier Attributes) for scalar formal arguments, or
a handle for non-scalar formal arguments.
In addition to indicating the storage type of each argument, the
argtype argument will also indicate whether an argument is input,
output, or input- output. Through the function
AimmsProcedureHandleDelete you can delete procedure handles created
with AimmsProcedureHandleCreate.
Calling procedures
You can use the function AimmsProcedureRun to run the AIMMS
procedure associated with a given handle. If the AIMMS procedure has
arguments, then you have to provide these, together with their types,
through the arglist and argtype arguments. The (integer) return
value of the procedure (see also Return value and
Using the return value) is returned through the result argument. If
AIMMS is already executing another procedure (started by another
thread), the call to AimmsProcedureRun blocks until the other
execution request has finished. Thread Synchronization explains how to
prevent this blocking behavior by obtaining exclusive control over
AIMMS.
Passing arguments
For each argument of the AIMMS procedure you have to provide both the
type and value through the argtype and arglist arguments in the
call to AimmsProcedureRun. You have the following possibilities.
If the argument is scalar, the argument type can be
the storage type returned by the function
AimmsProcedureHandleCreate, in which case the argument value must be a pointer to a buffer of the indicated type containing the argument, ora handle, in which case the argument value must be a handle associated with a scalar AIMMS identifier (slice) that you want to pass.
If the argument is non-scalar, the argument type can only be a handle, and the argument value must be a handle corresponding to the identifier (slice) that you want to pass.
If you pass an argument as an identifier handle, this can either be a
handle to a global identifier defined within the model, or a local
argument handle obtained through a call to the function
AimmsProcedureArgumentHandleCreate (see below).
Output values
When the input-output type of one or more of the arguments is inout
or output, AIMMS will update the values associated with any handle
argument, or, if a buffer containing a scalar value was passed, fill the
buffer with the new value of the argument.
Obtaining argument handles
Through the function AimmsProcedureArgumentHandleCreate you can
obtain a handle to the local arguments of procedures within your model.
After creating these handles you can pass them as arguments to the
function AimmsProcedureRun. The following rules apply.
After creation, handles created by
AimmsProcedureArgumentHandleCreatehave no associated data.If the handle corresponds to an
Inputargument of the procedure, you can supply data prior to calling the procedure, and AIMMS will empty the handle after the execution of the procedure has completed.If the handle corresponds to an
InOutorOutputargument of the procedure, AIMMS will not empty the handle after completion of the procedure. If you want to supply data to a handle corresponding to anInOutargument in subsequent calls, you have to make sure to empty the handle (through the functionAimmsIdentifierEmpty) prior to supplying the input data.
Requesting asynchronous execution
With the function AimmsProcedureAsyncRunCreate you can request
asynchronous execution of a particular AIMMS procedure. The function
returns an integer request handle for further reference. AIMMS will
execute a requested procedure as soon as there are no other execution
requests currently being executed or waiting to be executed. Note that
you should make sure that the ``AimmsValue`` array passed to AIMMS stays
alive during the asynchronous execution of the procedure. Failure to do
so, may result in illegal memory references during the actual execution
of the AIMMS procedure. This is especially true when the array contains
references to scalar integer, double or string InOut or Output
buffers within your application to be filled by the AIMMS procedure.
Obtaining the status
Through the function AimmsProcedureAsyncRunStatus you can obtain the
status of an outstanding asynchronous execution request. The status of
such a request can be
pending,
running,
finished,
deleted, or
unknown (for an invalid request handle).
When the request is in the finished state, the return value of the AIMMS
procedure will be returned via the result argument.
Deleting a request
You should make sure to delete all asynchronous execution handles
requested during a session using the function
AimmsProcedureAsyncRunDelete. Failure to delete all finished
requests may result in a serious memory leak if your external DLL
generates many small asynchronous execution requests. If you delete a
pending request, AIMMS will remove the request from the current
execution queue. The function will fail if you try to delete a request
that is currently being executed.
Interrupting an existing run
When an AIMMS procedure has been started by a separate thread in your
program you can interrupt it using the function
AimmsExecutionInterrupt. This function returns AIMMSAPI_SUCCESS
when AIMMS was idle and AIMMSAPI_FAILURE was executing a procedure.
