Raising and Handling Errors
Raising and handling errors
The error passing described in the previous section is retained in AIMMS 3 in order not to break existing applications. The use of the error handling described in this section, however, is encouraged as it is more in line with the error handling framework described in Raising and Handling Warnings and Errors. In addition, all errors, including all their parts, can be retrieved. The AIMMS API functions in this table enable the raising and handling of errors and retrieving the current AIMMS status.
Global error collector manipulation
The functions AimmsErrorStatus, AimmsErrorCount,
AimmsErrorGet, AimmsErrorDelete and AimmsErrorClear all
manipulate the global error collector. The global error collector is
described in Raising and Handling Warnings and Errors. The function AimmsErrorStatus
scans the contents of the global error collector and returns
AIMMSAPI_SEVERITY_CODE_NEVERif the global error collector is empty,
AIMMSAPI_SEVERITY_CODE_WARNINGif it contains only warnings, or
AIMMSAPI_SEVERITY_CODE_ERRORif it contains at least one error.
The function AimmsErrorCount does not return a status code, instead
it directly returns the number of errors and warnings in the global
error collector. With the functions AimmsErrorMessage,
AimmsErrorSeverity, AimmsErrorCategory, AimmsErrorCode,
AimmsErrorNumberOfLocations, AimmsErrorLine, AimmsErrorNode,
AimmsErrorAttributeName, AimmsErrorFilename,
AimmsErrorColumn, and AimmsErrorCreationTime actual error
information is obtained. In these functions the errNo argument
should be in the range {1..AimmsErrorCount()} and the pos
argument should be in the range
{1..AimmsErrorNumberOfLocations(errNo)}.
Example for API calls
None of the AIMMS API functions throws an exception, nor do any of them
let an exception pass through. The example below serves as a simple
template to call AimmsProcedureRun and handle all errors occurring
during that execution run.
int ErrCount, errNo, apr_stat ;
apr_stat = AimmsProcedureRun( procHandle, ... );
ErrCount = AimmsErrorCount();
if ( ErrCount ) {
for ( errNo = 1 ; errNo <= ErrCount ; errNo ++ ) {
// Handle the error; replace the next line as
// appropriate for the application at hand.
printf( "Error %d: %s\n", errNo, AimmsErrorMessage(errNo) );
AimmsErrorClear();
} else if ( apr_stat == AIMMSAPI_FAILURE ) {
printf("Aimms failed for an unknown reason.\n");
Raising an error
The function AimmsErrorRaise(severity, message, code) can raise
errors and warnings. These errors will be handled by the currently
active error handler as described in Raising and Handling Warnings and Errors. If there is
no currently active error handler, the error is directly placed in the
global error collector. The call to this function is similar to the
RAISE statement, see Raising Errors and Warnings. The code
argument is optional. The severity argument should be either
AIMMSAPI_SEVERITY_CODE_WARNINGindicating a warning or
AIMMSAPI_SEVERITY_CODE_ERRORindicating an error.
The category of an error raised by AimmsErrorRaise is fixed to
'User'.
