LibraryModule Declaration and Attributes
LibraryModule declaration and attributes
LibraryModule nodes create a separate tree in the model tree along
with a separate namespace for all identifier declarations in that
subtree. The model contents associated with a LibraryModule is
always stored in a separate source file. Contrary to Section and
Module nodes, the name of this source file cannot be specified in
the LibraryModule declaration. Rather, it is specified when you add
the library to your project using the Library Manager, as discussed
in Library projects and the library manager. The
attributes of LibraryModule nodes are listed in
the following table.
Attribute |
Value-type |
See also page |
identifier |
identifier-list |
quantity::unit-list |
comment string |
Library modules and namespaces
Like a normal module, each LibraryModule is supplied with a separate
namespace. Compared to normal modules, however, the visibility rules for
identifiers in a library modules are different. They are more in line
with the intended use of libraries, i.e. to enable a single developer to
work independently on the model source of a library.
The Interface attribute
Through the Interface attribute of a LibraryModule you can
specify the list of identifiers in the module that you want to be part
of its public interface. Only identifiers in the library interface can
be accessed in model declarations, pages and menu items that are not
part of the library at hand. Library identifiers not in the interface
are strictly private to the library, and can never be used outside of
the library.
The Prefix attribute
With the mandatory Prefix attribute of a LibraryModule node,
you must specify a module-specific prefix to be used in conjunction with
the :: operator. The value of the Prefix attribute should be a
unique name within the main model.
The Required Units attribute
It is recommended to declare all quantities and units at one place in the main model, and thus
not declare quantities in a library as this could lead to a model where the same quantities and units are
declared multiple times. With the Required Units attribute of a LibraryModule node,
you can specify the units that are used in the library and thus should be
present in the model that includes this library. If the required units
are SI units, then they will be added automatically to the model that includes this library.
The value of this attribute is a list of quantity::unit specifications. For example:
SI_Time_Duration::hour, SI_Length::inch.
No propagation to global namespace
Even though identifiers in the interface of the library are visible
outside of the library, AIMMS always requires the use of the library
prefix to reference such identifiers. Library modules do not support the
Public attribute of ordinary modules to propagate identifiers to the
global namespace.
Library initialization and termination
When creating a new library, AIMMS will automatically add
LibraryInitialization, PostLibraryInitialization,
PreLibraryTermination and LibraryTermination procedures to it.
These procedures will be executed during the initialization and
termination of your model. The distinction between these steps are
explained in more detail in Model Initialization and Termination.
