Model Declaration and Attributes
Model declaration and attributes
The Model node defines the root node of the entire model tree
associated with an AIMMS modeling project. The attributes of the main
Model node are listed in this table. All
attributes of the Model node have a global impact on the entire
modeling project.
Attribute |
Value-type |
See also page |
convention, element-parameter |
comment string |
The Convention attribute
With the Convention attribute you can indicate that all I/O with
respect to identifiers in your model is to take place according to the
unit convention specified in this attribute. The value of this attribute
must be either a direct reference to a convention declared in your
model, an element parameter into the set AllConventions or a string
parameter holding the name of a convention within your model. You can
find more detailed information about unit conventions and their usage in
Globally Overriding Units Through Conventions
