Tabular Expressionsļ
Tables for initialization
For multidimensional quantities the table format often provides the most
natural structure for data entry because elements are repeated less
often. Tables can be used in text data files and in the InitialData
attribute inside the declaration of an identifier.
Two-dimensional views
A table is a two-dimensional view of a multidimensional quantity. The index tuple of the quantity is split into two parts: row identifiers and column identifiers. Indices may not be permuted.
Example
The following example illustrates a simple example of the table format.
Distance(i,j) := DATA TABLE
Rotterdam Antwerp Berlin Paris
Amsterdam 85 170 660 510
Rotterdam 100 700 440
Antwerp 725 340
Berlin 1050
The first line of a table (after the keyword DATA TABLE) contains
the column identifiers. Each subsequent line contains a row identifier
followed by the table entries.
Multidimensional entries
Row and column identifiers may be set elements, tuples of elements, or tuples containing element ranges. As a result, multidimensional identifiers can still be captured within the two-dimensional framework of a table.
Proper spacing
Column identifiers must be separated by at least one space. AIMMS keeps track of the column width by maintaining the first and last position used by each column identifier. Any entry must intersect only one column and is understood to be part of that column. AIMMS will reject any entry that intersects two columns, or falls between them.
Continuation of tables with +
Even though the table format is a convenient way to enter data, the
number of columns is always restricted by the width of a line. However,
by placing a + on a new line you can continue a table by repeating
the table format. Row identifiers and column identifiers can be repeated
in each block separated by the + sign, but must be unique within a
block.
Example
The following table illustrates a valid example of table continuation, equivalent with the previous example.
Rotterdam Antwerp
Amsterdam 85 170
Rotterdam 100
Berlin Paris
Amsterdam 660 510
Rotterdam 700 440
Antwerp 725 340
Berlin 1050
Data and membership tables
Tables can be used for the initialization of both parameters and sets.
When used for parameter initialization, table entries are either blank
or contain explicit numbers, quoted or unquoted set elements and quoted
strings. Entries in tables used for set initialization are either blank
or contain a * denoting membership.
Syntax
The detailed syntax of a table constant is given by the following diagram, where the symbol ā\(\backslash\)nā stands for the newline character.
table:
table-header:
table-row:
