Creating Timetables
Timetables
A timetable in AIMMS is an indexed set, which, for every period in a Horizon, lists the corresponding time slots in the associated Calendar. Timetables play a central role during the conversion from calendar data to horizon data and vice versa.
The procedure CreateTimeTable
Through the predefined procedure CreateTimeTable, you can request AIMMS to flexibly construct a timetable on the basis of
  • a time slot in the calendar and a period in the horizon that should be aligned at the beginning of the planning interval,
  • the desired length of each period in the horizon expressed as a number of time slots in the calendar,
  • an indication, for every period in the horizon, whether the length dominates over any specified delimiter slots,
  • a set of inactive time slots, which should be excluded from the timetable and, consequently, from the period length computation, and
  • a set of delimiter time slots, at which new horizon periods should begin.
Syntax
The syntax of the procedure CreateTimeTable is as follows:
  • CreateTimeTable(timetable, current-timeslot, current-period, period-length, length-dominates, inactive-slots, delimiter-slots)
The (output) timetable argument of the procedure CreateTimeTable must, in general, be an indexed set in a calendar and defined over the horizon to be linked to the calendar. Its contents is completely determined by AIMMS on the basis of the other arguments. The current-timeslot and current-period arguments must be elements of the appropriate calendar and horizon, respectively.
Element parameter as timetable
In the special case that you know a priori that each period in the timetable is associated with exactly one time slot in the calendar, AIMMS also allows the timetable argument of the CreateTimeTable procedure to be an element parameter (instead of an indexed set). When you specify an element parameter, however, a runtime error will result if the input arguments of the call to CreateTimeTable give rise to periods consisting of multiple time slots.
Several possibilities
You have several possibilities of specifying your input data which influence the way in which the timetable is created. You can:
  • only specify the length of each period to be created,
  • only specify delimiter slots at which a new period must begin, or
  • flexibly combine both of the above two methods.
Period length
The period-length argument must be a positive integer-valued one-dimensional parameter defined over the horizon. It specifies the desired length of each period in the horizon in terms of the number of time slots to be contained in it. If you do not provide delimiter slots (explained below), AIMMS will create a timetable solely on the basis of the indicated period lengths.
Inactive slots
The inactive-slots argument must be a subset of the calendar that is specified as the range of the timetable argument. Through this argument you can specify a set of time slots that are always to be excluded from the timetable. You can use this argument, for instance, to indicate that weekend days or holidays are not to be part of a planning period. Inactive time slots are excluded from the timetable, and are not accounted for in the computation of the desired period length.
Delimiter slots
The delimiter-slots argument must be a subset of the calendar that is specified as the range of the timetable argument. AIMMS will begin a new period in the horizon whenever it encounters a delimiter slot in the calendar provided no (offending) period length has been specified for the period that is terminated at the delimiter slot.
Combining period length and delimiters
In addition to using either of the above methods to create a timetable, you can also combine them to create timetables in an even more flexible manner by specifying the length-dominates argument, which must be a one-dimensional parameter defined over the horizon. The following rules apply.
  • If the length-dominates argument is nonzero for a particular period, meeting the specified period length prevails over any delimiter slots that are possibly contained in that period.
  • If the length-dominates argument is zero for a particular period and the specified period length is 0, AIMMS will not restrict that period on the basis of length, but only on the basis of delimiter slots.
  • If the length-dominates argument is zero for a particular period and the specified period length is positive, AIMMS will try to construct a period of the indicated length, but will terminate the period earlier if it encounters a delimiter slot first.
Timetable creation
In creating a timetable, AIMMS will always start by aligning the current-timeslot argument with the beginning of the current-period. Periods beyond current-period are determined sequentially by moving forward time slot by time slot, until a new period must be started due to hitting the period length criterion of the current period (taking into account the inactive slots), or by hitting a delimiter slot. Periods prior to current-period are determined sequentially by moving backwards in time starting at current-timeslot.
Adapting timetables
As a timetable is nothing more than an indexed set, you still have the opportunity to make manual changes to a timetable after its contents have been computed by the AIMMS procedure CreateTimeTable. This allows you to make any change to the timetable that you cannot, or do not want to, implement directly using the procedure CreateTimeTable.
Example
Consider a timetable which links the daily calendar declared in Calendars and the horizon of Horizons, which consists of 10 periods named p-01 …p-10. The following conditions should be met:
  • the planning interval starts at period p-02, i.e. period p-01 is in the past,
  • periods p-01…p-05 have a fixed length of 1 day,
  • periods p-06…p-10 should have a length of at most a week, with new periods starting on every Monday.
To create the corresponding timetable using the procedure CreateTimeTable, the following additional identifiers need to be added to the model:
  • an indexed subset TimeTable(h) of DailyCalendar,
  • a subset DelimiterDays of DailyCalendar containing all Mondays in the calendar (i.e. '01-01-96', '08-01-96', etc.),
  • a subset InactiveDays of DailyCalendar containing all days that you want to exclude from the timetable (e.g. all weekend days),
  • a parameter PeriodLength(h) assuming the value 1 for the periods p-01 … p-05, and zero otherwise,
  • a parameter LengthDominates(h) assuming the value 1 for the periods p-01 … p-05, and zero otherwise.
To compute the contents of the timetable, aligning the time slot pointed at by CurrentDay and period IntervalStart, one should call
CreateTimeTable( TimeTable, CurrentDay, IntervalStart,
                 PeriodLength, LengthDominates,
                 InactiveDays, DelimiterDays );
If all weekend days are inactive, and CurrentDay equals '24/01/96' (a Wednesday), then TimeTable describes the following mapping.
Period
Calendar slots
Period
Calendar slots
p-01
23/01/96 (Tue)
p-06
30/01/96 - 02/02/96 (Tue-Fri)
p-02
24/01/96 (Wed)
p-07
05/01/96 - 09/02/96 (Mon-Fri)
p-03
25/01/96 (Thu)
p-08
12/01/96 - 16/02/96 (Mon-Fri)
p-04
26/01/96 (Fri)
p-09
19/01/96 - 23/02/96 (Mon-Fri)
p-05
29/01/96 (Mon)
p-10
26/01/96 - 01/03/96 (Mon-Fri)
The function TimeslotCharacteristic
The process of initializing the sets used in the delimiter-slots and inactive-slots arguments can be quite cumbersome when your model covers a large time span. For that reason AIMMS offers the convenient function TimeslotCharacteristic. With it, you can obtain a numeric value which characterizes the time slot, in terms of its day of the week, its day in the year, etc. The syntax of the function is straightforward:
  • TimeslotCharacteristic(timeslot, characteristic[, timezone[, ignoredst]])
The characteristic argument must be an element of the predefined set TimeslotCharacteristics. The elements of this set, as well as the associated function values are listed in this table.
Characteristic
Function value range
First
century
0, …, 99
year
0, …, 99
quarter
1, …, 4
month
1, …, 12
January
weekday
1, …, 7
Monday
yearday
1, …, 366
monthday
1, …, 31
week
1, …, 53
weekyear
0, …, 99
weekcentury
0, …, 99
hour
0, …, 23
minute
0, …, 59
second
0, …, 59
tick
0, …, 99
dst
0, 1
Day and week numbering
Internally, AIMMS takes Monday as the first day in a week, and considers week 1 as the first week that contains at least four days of the new year. This is equivalent to stating that week 1 contains the first Thursday of the new year. Through the 'week', 'weekyear' and 'weekcentury' characteristics you obtain the week number corresponding to a particular date and its corresponding year and century. For instance, Friday January 1, 1999 is day 5 of week 53 of year 1998.
Example
Consider a daily calendar DailyCalendar with index d. The following assignment to a subset WorkingDays of a DailyCalendar will select all non-weekend days in the calendar.
WorkingDays := { d | TimeslotCharacteristic(d,'weekday') <= 5 } ;
Calendar-calendar linkage
You can also use the function TimeslotCharacteristic to create a timetable linking two calendars (e.g. to create monthly overviews of daily data). As an example, consider the calendars DailyCalendar and MonthlyCalendar declared in Calendars, as well as an indexed set MonthDays(m) of DailyCalendar, which can serve as a timetable. MonthDays can be computed as follows.
MonthDays(m) := { d | TimeslotCharacteristic(d,'year') =
                            TimeslotCharacteristic(m,'year') and
                      TimeslotCharacteristic(d,'month') =
                            TimeslotCharacteristic(m,'month')    };
A check on the 'year' characteristic is not necessary if both calendars are contained within a single calendar year.
Time zone support
Through the optional timezone argument of the function TimeslotCharacteristic, you can specify with respect to which time zone you want to obtain the specified characteristic. The timezone argument must be an element of the predefined set AllTimeZones (see also Support for Time Zones and Daylight Saving Time). By default, AIMMS assumes the local time zone without daylight saving time.
Daylight saving time
When you specify a time zone with daylight saving time, you can retrieve whether daylight saving time is active through the 'dst' characteristic. With the optional argument ignoredst (default 0) of the function TimeSlotCharacteristic, you can specify whether you want daylight saving time to be ignored. With ignoredst set to 1, or in a time zone without daylight saving time, the outcome for the 'dst' characteristic will always be 0.
