Implementing a Model with a Rolling Horizon
Rolling horizons
The term rolling horizon is used to indicate that a time-dependent model is solved repeatedly, and in which the planning interval is moved forward in time during each solution step. With the facilities introduced in the previous sections setting up such a model is relatively easy. This section outlines the steps that are required to implement a model with a rolling horizon, without going into detail regarding the contents of the underlying model.
Two strategies
In this section you will find two strategies for implementing a rolling
horizon. One is a simple strategy that will only work with certain
restrictions. It requires just a single aggregation step and a single
disaggregation step. The other is a generic strategy that will work in
all cases. This strategy, however, requires that aggregation and
disaggregation steps be performed between every two subsequent SOLVE
statements.
Simple strategy
The simple strategy will work provided that
all periods in the horizon are of equal length, and
the horizon rolls from period boundary to period boundary.
It is then sufficient to make the horizon sufficiently large so as to cover the whole time range of interest.
Algorithm outline
The algorithm to implement the rolling horizon can be outlined as follows.
Select the current time slot and period, and create the global timetable.
Aggregate all calendar-based data into horizon-based data.
Solve the optimization model for a planning interval that is a subset of the complete horizon.
Move the current period to the next period boundary of interest, and repeat from steps until the time range of interest has passed.
Disaggregate the horizon-based solution into a calendar-based solution.
Assumptions
The examples below that illustrate both the simple and generic strategy make the following assumptions.
The model contains the daily calendar
DailyCalendar, the horizonModelPeriodsand the timetableTimeTabledeclared in Calendars, Horizons and Creating Timetables, respectively.The model contains a time-dependent mathematical program
TimeDependentModel, which produces a plan over the planning interval associated withModelPeriods.The planning horizon, for which the model is to be solved, rolls along from
FirstWeekBegintoLastWeekBeginin steps of one week. Both identifiers are element parameters inDailyCalendar.
Code outline
The outline of the simple strategy can be implemented as follows.
CurrentDay := FirstWeekBegin;
CreateTimeTable( TimeTable , CurrentDay , IntervalStart,
PeriodLength, LengthDominates,
InactiveDays, DelimiterDays );
Aggregate( DailyDemand, Demand, TimeTable, 'summation' );
! ... along with any other aggregation required
repeat
solve TimeDependentModel;
CurrentDay += 7;
IntervalStart += 1;
break when (not CurrentDay) or (CurrentDay > LastWeekBegin);
endrepeat;
Disaggregate( Stock , DailyStock , TimeTable, 'interpolation', locus: 1 );
Disaggregate( Production, DailyProduction, TimeTable, 'summation' );
! ... along with any other disaggregation required
Generic strategy
The simple strategy will not work
whenever the lengths of periods in the horizon (expressed in time slots of the calendar) vary, or
when the start of a new planning interval does not align with a future model period.
In both cases, the horizon-based solution obtained from a previous solve will not be accurate when you move the planning interval. Thus, you should follow a generic strategy which adds an additional disaggregation and aggregation step to every iteration.
Algorithm outline
The generic strategy for implementing a rolling horizon is outlined as follows.
Select the initial current time slot and period, and create the initial timetable.
Solve the mathematical program.
Disaggregate all horizon-based variables to calendar-based identifiers.
Move the current time slot forward in time, and recreate the timetable.
Aggregate all identifiers disaggregated in step 4 back to the horizon using the updated timetable.
Repeat from step 2 until the time range of interest has passed.
Code outline
The outline of the generic strategy can be implemented as follows.
repeat
CurrentDay += 7;
Aggregate( DailyStock , Stock , TimeTable, 'interpolation', locus: 1 );
Aggregate( DailyProduction, Production, TimeTable, 'summation' );
endrepeat;
