Syntax of the READ and WRITE Statements
READ and WRITE statements
In READ and WRITE statement you can specify the data source
type, what data will be transferred, and in what mode. The syntax of the
statements reflect these aspects.
Syntax
read-write-statement:
selection:
Data sources
The data source of a READ or WRITE statement in AIMMS can be
either
a
Filerepresented by eithera
Fileidentifier,a string constant, or
a scalar string reference,
a
TABLErepresented by eithera
DatabaseTableidentifier,an element parameter with a range that is a subset of the predeclared set
AllDatabaseTables
Strings for file data sources refer either to an absolute path or to a relative path. All relative paths are taken relative to the project directory.
Examples
Assuming that UserSelectedFile is a File identifier, and
UserFilename a string parameter, then the following statements
illustrate the use of strings and File identifiers.
read from file "C:\Data\Transport\initial.dat" ;
read from file "data\initial.dat" ;
read from file UserFileName ;
read from file UserSelectedFile ;
Specifying a selection
The selection in a READ or WRITE statement determines which
data you want to transfer from or to a text file, or database table. A
selection is a list of references to sets, parameters, variables and
constraints. During a WRITE statement, AIMMS accepts certain
restrictions on each reference to restrict the amount of data written
(as explained below). Note, however, that AIMMS does not accept all
types of restrictions which are syntactically allowed by the syntax
diagram of the READ and WRITE statements.
Default selection
If you do not specify a selection during a READ statement, AIMMS
will transfer the data of all identifiers stored in the table or file
that can be mapped onto identifiers in your model. If you do not specify
a selection for a WRITE statement to a text
file, all identifiers declared in your model will be written. When writing to a database table, AIMMS will write data for all columns in the table as long as they can be mapped onto AIMMS identifiers.
Filtering the selection
You can apply the following filtering qualifiers on READ and
WRITE statements to restrict the data selection:
the
FILTERINGorCHECKINGclauses restrict the domain of all transferred data in both theREADandWRITEstatements, andan arbitrary logical condition can be imposed on each individual parameter and variable in a
WRITEstatement.
FILTERING versus CHECKING
You can use both the FILTERING and CHECKING clause to restrict
the tuples for which data is transferred between a data source and
AIMMS. During a WRITE statement there is no difference in semantics,
and you can use both clauses interchangeably. During a READ
statement, however, the FILTERING clause will skip over all data
outside of the filtering domain, whereas the CHECKING clause will
issue a runtime error when the data source contains data outside of the
filtering domain. This is useful feature for catching typing errors in
text data files.
Examples
The following examples illustrate filtering and the use of logical conditions imposed on index domains.
read Distance(i,j) from table RouteTable
filtering i in SourceCities, (i,j) in Routes;
write Transport( (i,j) | Sum(k, Transport(i,k)) > MinimumTransport )
to table RouteTable ;
Advanced filtering on records
If you need more advanced filtering on the records in a database table, you can use the database to perform this for you. You can
define views to create temporary tables when the filtering is based on a non-parameterized condition, or
use stored procedures with arguments to create temporary tables when the filtering is based on a parameterized condition.
The resulting tables can then be read using a simple form of the
READ statement.
Merge, replace or backup mode
READ or WRITE statement, AIMMS
will transfer the data in replace mode by default, with one exception:
when reading from a case difference file that was generated by
CaseCreateDifferenceFile function with diffTypes argument
equal to elementReplacement, elementAddition or
elementMultiplication, the file is always read in merge mode, so
that the diffTypes can be applied in a sensible way.Reading in merge mode
When AIMMS reads data in merge mode, it will overwrite existing elements for all read identifiers, and add new elements as necessary. It is important to remember that in this mode, if there is no data read for some of the existing elements, they keep their current value.
Writing in merge mode
When AIMMS writes data in merge mode, the semantics is dependent on the type of the data source.
If the data source is a text file, AIMMS will append the newly written data to the end of the file.
If the data source is a database table, AIMMS will merge the new values into the existing values, creating new records as necessary.
Reading in replace mode
When AIMMS reads data in replace mode, it will empty the existing data of all identifiers in the identifier selection, and then read in the new data.
Writing in replace mode
When AIMMS writes data in replace mode, the semantics is again dependent on the type of the data source.
If the data source is a text file, AIMMS will overwrite the entire contents of the file with the newly written data. Thus, if the file also contained data for identifiers that are not part of the current identifier selection, their data is lost by the
WRITEstatement.If the data source is a database table, AIMMS will either empty all columns in the table that are mapped onto identifiers in the identifier selection (default,
REPLACE COLUMNSmode), or will remove all records in the table not written by this write statement (REPLACE ROWSmode). TheREPLACE COLUMNSandREPLACE ROWSmodes are discussed in more detail in Database Table Restrictions).
Writing in insert mode
Writing in insert mode is only applicable when writing to databases. Essentially, what it does is writing the selected data to a database table using SQL INSERT statements. In other words, it expects that the selection of the data that you write to the table doesn’t match any existing primary keys in the database table. If it does, AIMMS will raise an error message about duplicate keys being written. Functionally, the insert mode is equivalent to the replace rows mode, with the non-existing primary keys restriction. Especially when writing to database tables which already contain a lot of rows, the speed advantage of the insert mode becomes more visible.
Writing in backup mode
When you are transferring data to a text file, AIMMS supports writing in backup mode in addition to the merge and replace modes. The backup mode lets you write out files which can serve as a text backup to a (binary) AIMMS case file. When writing in backup mode, AIMMS
skips all identifiers on the identifier list which possess a nonempty definition (and, consequently, cannot be read in from a datafile),
skips all identifiers for which the property
NoSavehas been set, andwrites the contents of all remaining identifiers in such an order that, upon reading the data from the file, all domain sets are read before any identifiers defined over such domain sets.
Backup mode is not supported during a READ statement, or when
writing to a database.
Writing data in a dense mode
Writing in dense mode is only applicable when writing to databases. Data
in AIMMS is stored for non-default values only, and, by default, AIMMS
only writes these non-default values to a database. In order to write
the default values as well to the database table at hand, you can add
the dense keyword before most of the WRITE modes discussed above.
This will cause AIMMS to write all possible values, including the
defaults, for all tuple combinations considered in the WRITE
statement. Care should be taken that writing in dense mode does not
lead to an excessive amount of records being stored in the database. The
mode combination merge and dense is not allowed, because it is
ambiguous whether or not a non-default entry in the database should be
overwritten by a default value of AIMMS.
For the same reason, the mode combination insert and dense is also not allowed.
Replacing sets
Whenever elements in a domain set have been removed by a READ
statement in replace mode, AIMMS will not cleanup all identifiers
defined over that domain. Instead, it will leave it up to you to use the
CLEANUP statement to remove the inactive data that may have been
created.
Domain filtering
For every READ and WRITE statement you can indicate whether or
not you want domain filtering to take place during the data transfer. If
you want domain filtering to be active, you must indicate the list of
indices, or domain conditions to be filtered in either a FILTERING
of CHECKING clause. In case of ambiguity which index position in a
parameter you want to have filtered you must specify indices in the set
or parameter reference.
Example
The following READ statements are not accepted because both
Routes and Distance are defined over Cities \(\times\)
Cities, and it is unclear to which position the filtered index i
refers.
read Routes from table RouteTable filtering i ;
read Distance from table RouteTable filtering i ;
This ambiguity can be resolved by explicitly adding the relevant indices as follows.
read (i,j) in Routes from table RouteTable filtering i ;
read Distance(i,j) from table RouteTable filtering i ;
Semantics of domain filtering
When you have activated domain filtering on an index or index tuple, AIMMS will limit the transfer of data dependent on further index restrictions.
During a
READstatement only the data elements for which the value of the given index (tuple) lies within the specified set are transfered. If no further index restriction has been specified, transfer will take place for all elements of the corresponding domain set.During a
WRITEstatement only those data elements are transferred for which the index (tuple) is contained in the AIMMS set given in the (optional)INclause. If no set has been specified, and the data source is a database table, the transfer is restricted to only those tuples that are already present in the table. When the data source is a text filethe latter type of domain filtering is not meaningful and therefore ignored by AIMMS.
READ example
In the following two READ statements the data transfer for elements
associated with i and (i,j), respectively, is further
restricted through the use of the sets SourceCities and Routes.
read Distance(i,j) from table RouteTable filtering i in SourceCities ;
read Distance(i,j) from table RouteTable filtering (i,j) in Routes ;
WRITE example
In the following two WRITE statements, the values of the variable
Transport(i,j) are written to the database table RouteTable for
those tuples that lie in the AIMMS set SelectedRoutes, or for which
records in the table RouteTable are already present, respectively.
write Transport(i,j) to table RouteTable filtering (i,j) in SelectedRoutes ;
write Transport(i,j) to table RouteTable filtering (i,j) ;
The FILTERING clause in the latter WRITE statement would have
been ignored by AIMMS when the data source was a text data file.
Writing selected suffices using the WHERE clause
Using the WHERE clause of the WRITE statement you can instruct
AIMMS, for all identifiers in the identifier selection, to write the
data of either a specified suffix or a set of suffices to file, rather
than their level values. The WHERE clause can only be specified
during a WRITE statement to a FILE, and the corresponding set or
element expression must refer to a subset of, or element in, the
predefined set AllSuffixNames.
Example
The following WRITE statement will write the values of the
.Violation suffix of to the file ViolationsReport.txt for all
variables in the project.
write AllVariables to file "ViolationsReport.txt" where suffix = 'Violation';
