The PUT Statement
Customized text reports
AIMMS provides two statements to create a customized text output report
in either a file or in a text window in the user interface. They are the
PUT and the DISPLAY statements. The result of these statements
must always be directed to either a single file or a window.
Basic steps
The following steps are required to create a customized text report:
direct the output to the appropriate
Fileidentifier, andprint one or more strings, set elements, numerical items, or tabular arrangements of data to it.
These basic operations are the subject of the subsequent subsections. At the end of the section, an extended example will illustrate most of the discussed features.
Stream versus page mode
AIMMS can produce text reports in two modes. They are:
stream mode, in which all lines are printed consecutively, and
page mode, where the report is divided into pages of equal length, each consisting of a header, a footer and a data area.
Most aspects, such as opening files, output direction, and formatting, are the same for both reporting modes. Only the structuring of pages is an extra aspect of the page mode, and is discussed in Structuring a Page in Page Mode.
Opening Files and Output Redirection
Opening files
Disk files and windows are opened automatically as soon as output is
written to them. You can send output to a particular file by providing
the associated File identifier as the first argument of a PUT
statement, which designates the file as the current file.
PUT without file identifier
If you use the DISPLAY statement or any of the PUT operators
listed in this table without a file identifier,
AIMMS will direct the output to the current file, i.e., the file last
opened through the PUT statement.
Undirected output
When you have not yet selected a current file yet, AIMMS will send the
output of any PUT or DISPLAY statement to the standard listing
file associated with your model.
Example
The following statements illustrates how to send output to a particular file.
PUT ResultFile ;
PUT "The model results are:" ;
DISPLAY Transport ;
PUTCLOSE;
The first PUT statement sets the current file equal to
ResultFile, causing the output of the subsequent PUT and
DISPLAY statements to be directed to it. The final PUTCLOSE
statement will close ResultFile.
File identifiers only
Unlike other statements like READ and WRITE which allow you to
represent files by strings or string parameters as well, the PUT
statement requires that you use a File identifier to represent the
output file. The way in which output to a file is generated by the
PUT statement is completely controlled by the suffices associated
with the corresponding File identifier (see also
Structuring a Page in Page Mode).
Accessing the current file
AIMMS has two pre-defined identifiers that provide access to the current file. They are
the element parameter
CurrentFile(into the setAllIdentifiers) containing the currentFileidentifier, andthe string parameter
CurrentFileName, containing the file name or window title associated with the current file identifier.
The parameter CurrentFileName is output only.
Changing the current file
To select another current file, you can use either of two methods:
use the
PUTstatement to (re-)direct output to a different file, orset the identifier
CurrentFileto theFileidentifier of your choice.
Closing external files
Closing an external file can be done in two ways:
automatically, by quitting AIMMS at the end of a session, or
manually by calling “
PUTCLOSEfile-identifier” during execution.
Files left open
If you leave a file open during the execution of a procedure, AIMMS will
temporarily close it at the end of the current execution, and re-open it
in append mode at the beginning of a subsequent execution. This
enables you to inspect the PUT files in between runs.
Formatting and Positioning PUT Items
Besides selecting the current file, the PUT statement can be used to
output one or more individual strings, numbers or set elements to an
external text file or window. Each item can be printed in either a
default or in a customized manner. The syntax of the PUT statement
follows.
Syntax
put-statement:
PUT operators
All possible variants of the PUT operator are listed in
this table. The PUT and PUTCLOSE
operators can be used in both stream mode and page mode. The operators
PUTHD, PUTFT and PUTPAGE only make sense in page mode, and
are discussed in Structuring a Page in Page Mode.
Statement |
Description |
Stream mode |
Page mode |
Direct output or write output |
\(\bullet\) |
\(\bullet\) |
\(\bullet\) |
\(\bullet\) |
Write in header area |
\(\bullet\) |
Write in footer area |
\(\bullet\) |
\(\bullet\) |
Put items are always scalar
All PUT operators only accept scalar expressions. For each scalar
item to be printed you can optionally specify a format field, with
syntax:
Syntax
format-field:
Format fields
With the format field you specify
whether the item is to be centered, left aligned or right aligned,
the field width associated with an identifier, and
the precision.
Customized default values for the justification, field width and
precision can be specified through PUT-related options, which can be
set via the Options menu. The following table shows a number
of examples of format fields, where \(m\) and \(n\) are
expressions evaluating to integers.
Justification |
Field width (characters) |
Precision |
item |
default |
default |
default |
item |
default |
\(m\) |
default |
item |
default |
\(m\) |
\(n\) |
item |
left |
\(m\) |
\(n\) |
item |
right |
\(m\) |
\(n\) |
item |
centered |
\(m\) |
\(n\) |
Interpretation of precision
For numerical expressions the precision is the number of decimals to be displayed. For strings and set elements the precision is the maximum number of characters to be displayed. The numbers or characters are placed into a field with the indicated width, and are positioned as specified.
Using the FormatString function
The PUT syntax for formatting and displaying multiple items on a
single line is somewhat similar to the reporting syntax in programming
languages like FORTRAN or PASCAL. If you are a C programmer,
you may prefer to construct and format a single line of text using the
FormatString function (see also Formatting Strings).
In this case you only need the PUT statement to send the resulting
string to a text report or window.
Position determination
For advanced reporting the PUT statement allows you to directly
position the cursor at a given row or column. The syntax is shown in the
following syntax diagram.
position-determination:
How to position
There are three special arguments for the PUT statement that can be
used to position printable items in a file:
the
@operator-for horizontal positioning on a line,the
#operator-for vertical positioning, andthe newline operator
These three operators are explained in this table, where the symbols \(k\) and \(l\) are expressions evaluating to integers.
Operator |
Meaning |
Start printing the next item at column \(k\) of the current line. |
Goto line \(l\) of current page (page mode only). |
Goto new line. |
Page mode only
Using the vertical positioning operator # only makes sense when you
are printing in page mode. When printing in stream mode all lines are
numbered consecutively from the beginning of the report, and added to
the output file or window as soon as AIMMS encounters the newline
character /. In page mode, AIMMS prints pages in their entirety, and
lines are numbered per page. As a result, you can write to any line
within the current page.
Extended Example
Example
This example builds upon the transport model used throughout the manual.
The following group of statements will produce a text report containing
the contents of the identifiers Supply(i), Demand(j) and
Transport(i,j), in a combined tabular format separated into right
aligned columns of length 12.
The statements
! Direct output to ResultFile
put ResultFile ;
! Construct a header for the table
put @13, "Supply":>12, @30, "Transport":>12, /, @30 ;
for ( j ) do put j:>12 ; endfor ;
put // ;
! Output the values for Demand
put "Demand", @30 ;
for ( j ) do put Demand(j):>12:2 ; endfor ;
put // ;
! Output Supply and Transport
for ( i ) do
put i:<12, Supply(i):>12:2, @30 ;
for ( j ) do put Transport(i,j):>12:2 ; endfor;
put / ;
endfor ;
! Close ResultFile
putclose ResultFile ;
The produced report
For a particular small data set containing only three Dutch cities, the above statements could result in the following report being generated.
Supply Transport
Amsterdam Rotterdam Den Haag
Demand 5.00 10.00 15.00
Amsterdam 10.00 2.50 2.50 5.00
Rotterdam 12.50 2.50 5.00 5.00
Den Haag 7.50 0.00 2.50 5.00
