The File Declaration
External file names that you want to use for reporting must be linked to
AIMMS identifiers in your model. In this way, external file names become
data. Whenever you want to send output to a particular external file,
you must refer to its associated identifier. This linking is achieved
using a File declaration, the attributes of which are given in
this table.
Attribute |
Value-type |
See also page |
string-expression |
an element in |
string |
comment string |
convention |
The Convention attribute, Globally Overriding Units Through Conventions |
The Name attribute
With the Name attribute you can specify the actual name of the disk
file or window that you want to refer to. If the file identifier refers
to a disk file, the Name will be the file name on disk. If it refers
to a window the Name attribute will serve as the title of the
window. If you do not specify a name, AIMMS will construct a default
name, using the internal identifier name as the root and .put as
the extension.
The Device attribute
The Device attribute can have three values
disk(default),window, andvoid.
You can use it to indicate whether the output should be directed to an
external file on disk, a window in the graphical user interface, or
whether no output should be generated at all. This latter void
device is very convenient, for instance, to hide output statements in
your code that are useful during the development of your model but
should not be displayed in an end-user version.
The Mode attribute
You can use the Mode attribute to specify whether the file or window
should be overwritten (replace mode, default), or appended to
(merge mode). The graphical window in the user interface differs
from a file in that it can be closed manually by the user. In this case,
its contents are lost and AIMMS starts writing to a new instance
regardless of the mode.
Example
The following File declarations illustrate the declaration of a link
to the external file result.dat in the Output subdirectory of
the project directory, and a text window that will appear with the title
Model results. The contents of ResultFile will be overwritten
whenever it is opened, while the window ResultWindow will be
appended to whenever possible.
File ResultFile {
Device : disk;
Mode : replace;
File ResultWindow {
Name : "Model results";
Device : window;
Mode : merge;
The Encoding attribute
In the Encoding attribute of a file, a specific character encoding
can be specified for that file, either as a specific element of the set
AllCharacterEncodings or as an element parameter with the set
AllCharacterEncodings as its range. Encodings are explained in
Paragraph Text files on Page Character encoding used in text files. In the example
below, the attribute Encoding states that code page WINDOWS-1252
should be used for the file WindmillLocations.txt. This code page is
not uncommon in the Netherlands.
File WindMillLocs {
Encoding : 'WINDOWS-1252';
The statement Write to file WindMillLocs ; will subsequently write
the file "WindmillLocations.txt" using the character encoding
WINDOWS-1252. When the Encoding attribute is not specified, the
statements Read from file and Write to file will
use the encodings specified by the options
default_input_character_encoding and
default_output_character_encoding respectively. The default of these
options is the preferred encoding UTF8. The Encoding attribute
is ignored when reading from files which start with a Unicode BOM (Byte
Order Mask).
With the Convention attribute you can indicate that AIMMS must
assume that the data in the file is to be stored according to the units
provided in the specified convention. If the unit specified in the
convention differs from the unit in which AIMMS stores its data
internally, the data is scaled just prior to data transfer. For the
declaration of Conventions you are referred to
Globally Overriding Units Through Conventions.
