Composite Tables
Multiple identifiers
A composite table is a bulk form of initialization, and is similar in structure to a table in a database. Using a composite table you can initialize simple sets, relations, parameters, and variables in a single statement. Composite tables always form a single block, and can only be used in text data files.
Format
The first line of a composite table contains column identifiers that define the index columns and the quantity columns. The subsequent lines contain data entries. Like in a tabular expression, entries in a composite table may be either blank or contain explicit numbers, quoted or unquoted set elements and quoted strings, depending on the type of the identifier associated with a column. Blank entries in the quantity columns are treated as “no assignment.”, while blank entries in the index columns are not allowed. All data entries must lie directly below their corresponding column identifier as in regular tables.
Indices must come first
The full index space is declared in the first group of column identifiers, and is comparable to the primary key in a database table. The remaining column identifiers declare various quantities that must share the identical index space. Note that, unlike in tabular expressions, index columns in a data entry row of a composite table cannot refer to tuples or ranges of elements, but only to single set elements.
Example
The following statement illustrates a valid example of a composite
table. It initializes the relation Routes, as well as the parameters
Distance and TransportCost, all of which are defined over the
index space (i, j).
COMPOSITE TABLE
i j Routes Distance TransportCost
Amsterdam Rotterdam * 85 1.00
Amsterdam Antwerp * 170 2.50
Amsterdam Berlin 660 10.00
Amsterdam Paris * 510 8.25
Rotterdam Antwerp * 100 1.20
Rotterdam Berlin * 700 10.00
Rotterdam Paris 440 7.50
Antwerp Berlin * 725 11.00
Antwerp Paris * 340 5.00
Berlin Paris 1050 17.50
Syntax
The detailed syntax of the composite table is given by the following
diagram, where the symbol \n stands for the newline character.
composite-table:
composite-header:
composite-row:
