Library projects and the library manager
AIMMS library projects
AIMMS library projects allow you to divide a large AIMMS project into a number of smaller sub-projects. Library projects are especially useful if you intend to share parts of an application between multiple projects. Each library project in AIMMS provides
  • a tree of model declarations,
  • a page tree,
  • a template tree, and
  • a menu tree.
In addition, a library project may provide its own collection of user project files, user colors and fonts.
Shared templates
Besides enabling multiple developers to work in a single project, library projects can also be used to define a common collection of templates that define the look-and-feel of multiple projects. In this manner, you change the look-and-feel of multiple applications just by changing the templates in the shared library project.
Warning
The AIMMS WinUI is deprecated, please refer to AIMMS Product Lifecycle. You may use the WebUI instead, and share your developments via a library, see Pages In Library Support
Adding libraries to a project
By adding a library project to the main AIMMS project, the objects defined by the library, such as identifiers, pages, templates, etc., become available for use in the main project. In addition, if a library project is writable, the contents of the library can also be edited through an AIMMS project in which it is included.
The library manager
You can add libraries to an AIMMS project in the AIMMS Library Manager dialog box illustrated in Fig. 9. You can open the library manager through the File-Library Manager… menu.
The **AIMMS Library Manager**
Fig. 9 The AIMMS Library Manager
Using the library manager AIMMS allows you to
  • create new libraries,
  • add existing libraries to your project,
  • add system libraries (contained within the AIMMS version installed on your computer)
  • add a library from the Library Repository
Library storage
Each library project in AIMMS will be stored in a separate directory, containing the following files and folders:
  • the Project.xml file holding a reference to the project’s main model source file (with an .ams extension), as well as all additional model source files included in the main model source file, together containing all identifier declarations, procedures and functions that are relevant to the project,
  • PageManager.xml, TemplateManager.xml and MenuBuilder.xml files describing the page, template and menu tree defined in the project, with all individual pages and templates being stored in the Pages and Templates subfolders,
  • Settings and Tools subfolders containing the saved settings for user colors, fonts, and the various tools in the AIMMS IDE, and
  • the User Files folder for storing all user files that you store within the project.
These files will be automatically created by AIMMS when you create a new library project. To add an existing library to an AIMMS project, you just need to select its library project file.
Library prefix
To avoid name clashes between objects in the library and the main project or other libraries, all the object names in a library are stored in a separate namespace. Outside of the library, a global prefix associated with the library has to be used to access the library objects. When you create a new library project, AIMMS will come up with a default library prefix based on the library name you entered. For an existing library project, you can view and edit its associated library prefix in the library manager.
Using library projects
After you have added one or more library projects to your main AIMMS project, AIMMS will extend
  • the model tree in the Model Explorer,
  • the page tree in the Page Manager,
  • the template tree in the Template Manager, and
  • the menu tree in the Menu Builder
with additional root nodes for every library project added to your project. In general, within any of these tools, you are free to move information from the main project tree to any of the library trees and vice versa. In addition, the AIMMS dialog boxes for user project files, user colors and fonts allow you to select and manage objects from the main project or any of the libraries. The precise details for working with library projects in each of these tools are discussed in full detail in the respective chapters discussing each of the tools.
