Scalar Object in User Mode
Editing the values in a scalar object is quite intuitive, except maybe for some small details:
If the object uses a display style that does not show the edit field permanently (i.e. the styles Value(s) only, Text – Value, or Value Text), then you can enter a completely new value by simply start typing this new value. If you want to modify the current value, you should first press the F2 or Ins key.
If the scalar object has the Multiple Line Edit Field style, then you should press Ctrl-Enter to insert a line break within the text. Pressing the Enter key alone accepts the current text.
If you press the Esc key, your current edits will be discarded and the original value is put back.
You can only change the value of an identifier if the scalar object is not read-only and if the identifier is in the set CurrentInputs, which generally means that the identifier should not have a definition.
How to …
Learn more about
